Corsair 600T, How silent/quiet are these cases?
8 Jan 2007
London & Dubai
Thinking of moving my rig over to a Corsair 600T, anyone here know how quiet they are?
Thinking of getting the white version with the window
my 600t is in the front room, it sits there quietly in the background. I have a push pull config too with the water cooled H50, so thats 5 fans (including the case ones and the graphics card). Its a superb case, like the post above - as quiet as you want it to be.
Using just standard fans and coolermaster V8 in mine, hardly makes a peep. A slight hum when you have no sound on but otherwise pretty quiet.
What fans are you using on the H50?
Hi Van, im using 2 different fans (120mm) on either side of the H50, the Noctua NF-P12 & Akasa Viper. I have set the fans to slient in the Asus BIOS - just make sure they are blowing in the same direction. The Corsair stock fans that come with the graphite 600t are slightly louder. I just have then turned to min on the fan control knob.
You wont regret buying this case, not sure about the Thermalright cpu fan cooler - i take it you have it already?
I would strongly recommend a water cooler kit - a CPU fan cooler is generally louder.. my old one was like a jet engine when playing a Battlefield game.
The plan was to move away from watercooling for a while. I've got a couple of Noctua & some Scythe S-FLEX fans that remain completely inaudible inside the computer enclosure.
Will see how it goes, I've also got tons of watercooling kit so the option is available to me.
