Slight overclock.
30 Dec 2009
Wigan Lancs
I have just OC'd my Q9300 CPU from 2.5 to 2.8ghz. it seems to be running OK at this with very little temperature increase (about 67c) even when gaming.
I have not adjusted any voltage settings.
If i tried going for 3.0ghz would this be too much?
The processor is only using the standard cooler at the moment.
Thanks.
Thanks.
Try it but just watch those temps.
OK thanks. I am also considering getting a QX9650 3ghz Extreme processor and OC,ing that to give my pc a bit of a boost.
I think you will be wasting your money as 775 is old now and if you sold your 775 stuff now for about £150 then you could spend around £400 on i5, board and ram. That would cost you about ~£250. and to upgrade to a QX9650 it would probley cost you around ~£150. You would probley get about ~4.2GHz. The I5 would be much much faster.
I have thought about upgrading but i am perfectly happy with my current system so will do a full upgrade in the future.
I recently missed out on a brand new QX9770 going cheap so a QX9650 will do me for now.
