I7 - 2630QM Boost Question
25 Oct 2011
London
I have i7-2630QM processor 2.00 GHz with Turbo Boost 2.0 up to 2.90 GHz
The most ive seen it boost to is 2.60 GHz and thats even opening Photoshop CS 5 with a large Jpeg photograph , or am i missing something :confused:
Any help
So i have 4 cores at it turbos to 2.6ghz ? is that a bad or good thing ? :confused:
I never see it over 2.6ghz on the turbo monitor
depends how many cores a program usses, if the program uses only a sinlge core then it can turbo that core to 2.9ghz from 2.0ghz but if the program uses 2 cores it can turbo to 2.8ghz.
it does this as at 2.00ghz it uses less power and runs cooler then if it was working at 2.9ghz all the time and it only goes to 2.9ghz if it needs to.
you might not be seeing it at 2.9ghz becouse A its using more then one core to run the program you are using or B it dosent need to use that much power and only needs 2.6ghz to run it.
yeah a great idea for a cpu in my view ! i have the i7 2.2ghz which boosts up to 3.10ghz and its amazing ! seen it go to 3ghz once so to answer that yes they do work and yours is fine :)
