I've not been playing for long. Around a year and half. I don't play in a band or live. I just enjoying playing the guitar and making music.
I'll look into the Marshall, it could be a possible Christmas present!
Thanks for the information.
Ok that is excellent information to go on and basically you want to play in your bedroom and have the best sounds at your disposal.
Most amps/combo's will be a duo sound: overdrive & clean as in the case of the Marshall I linked to which doesn't give a lot of scope.
There are a lot of amps out there that are called modelling amps.
Imagine you want to learn loads of styles so you want an emulated Metallica sound, Guns N Roses sound, classic 70's sound, blues sound and so on, the modelling amp will get you close.
To actually have the right sound goes a long way to playing the guitar better.
In the house I use a Line 6 Toneport plugged into my PC which gives me an array of different amps, speakers and effects units and my guitar is also able to emulate 37 of the worlds greates guitars - I'm in heaven guitar & tone wise.
Line 6 do many modelling amps (and so do other companies) so I would look into these amps/combo's or you could get a Line 6 Toneport and save a few quid by plugging into your PC.
You could still use the Marshall (or similar) combo but for different sounds you could get a pedal that emulates these sounds and put the Marshall (or similar) on a clean channel.
This is exactly how I do it on stage: I put my Marshall TSL602 on a clean sound and let my Boss ME70 take care of all the sounds I need.
