Blower bust
  • Thread starter Thread starter mjt
  • Start date Start date
mjt
mjt
31 Aug 2007
Don't you just love old BMWs? :rolleyes:
So the vents/heater/fan/whatever was going brrrrrr this morning which I thought was odd as it's not normally noisy.
Then it starts working intermittently, and now it's packed up. All in the space of 15 minutes.
Before it died, there was a pause before it kicked into life.
Now it doesn't work at all. This is perfect timing considering the windows are fogged up when I get in in the morning!
So yeah, diagnosis?
Final stage resistor was the cause of my work colleague's E46 M3 doing the exact symptoms in the OP.
Well I say exact, it died within a day not 15 minutes, but still.
Very unusual then - it normally causes a blower with a mind of its own, meaning the buttons don't do anything to control it anymore and it'll do random things like come on in the middle of the night and flatten the battery.
When I had exactly the symptoms of the OP - a blower that was a bit noisy and then flat out refused to work - it was the heater blower motor itself.
Makes sense to try the FSU first as it's cheap and easy, though.
If years of racing electric RC cars has taught me anything, motors make groaning noises when they aren't recieving enough power to quite turn through the magnetic field. The FSU can cause exactly this.
I'm not saying it won't be the motor itself, but those symptoms could quite as easily be caused by something controlling power flow to the motor.
Knowing my luck it'll be both :p
Recently (maybe a few weeks ago? more than once) that I turned it on and nothing happened.
Then I turned it off (position 0) and back on and it kicked into life.
There's always been a bit of noise, but it's more whistling than anything, so I thought it was just the air in the vents somewhere.
Just before it died, the knob didn't do anything, and it did have a mind of its own, but literally only for a few seconds before I turned it off, and it wouldn't come back on.
Update: it worked on the way home fine.
Popped out again now, and it's broken.
The heater works though as I can feel warm air hovering out of the vents at speed.
It's all very odd :p
Replaced it last week (what a complete faff removing the wiper arms was!!) and assumed all was well.
Come this morning and it stutters and groans, before not working.
Gave the centre console a disapproving smack and it kicked into life.
Was this a dash-out job in the E39 too?
Not looking forward to the bill for this job. They'll need the car for 3 days :(
