Dual Monitor Question
11 Oct 2011
UK
Hi,
I have a GTX 460 and I have:
One of the DVI ports going to my monitor (U2412M)
The mini HDMI going to my TV
Question is how can I make it so the PC recognises when the TV is on/off
The issue is that when the TV is off (I only use PC with TV sometimes, mainly use the U2412M), the mouse still goes over onto the TV ... even though it is off
Hope that makes sense
So what I want to know is how to make it so that the mouse stays on the U2412M when the TV is off, and stretches to the TV when it is on
Hope that all made sense,
Thanks in advance,
Although it wont automatically detect whether the TV is on or not you could press "Windows+P" and set it to computer only when you're not using the TV.
Do you want extended desktop, where both will display different images, or do you just want them cloned?
Yes, I want it extended :)
That sounds good enough for me if it works. I will try it and let you know :D
