I did not put my mobo oon my sig because its asrock and im ashamed! But i was looking at something a tad better than this 7300, which isnt hard....when i made this box 3 years back or so, the only reason i used it was the limited budget, and literally it just meant not using ram on shared gfx, but now i wouldn't mind something at least slightly better ... this card is pathetic
The new cards, i was mainly looking at nvidia just because i used to use them more often, and this mobo has nvidia chipset , would you reccomend i buy maybe just a 8800 gtx 9xxx gtx? or maybe a newer one , but lower end ...*i allways thought a little older higher end ican be better*
Also little things like popular brands of card, which are this or which are that, bad good ect , just general guidelines, any advice will be used wisely
cheers
