Spec me a £400 pc
26 Mar 2009
UK
Hi peeps was looking for some help any chance you guys could squeeze the most outta £400 for my wife's new desktop, Graphics don't have to be to hot she only plays at best minecraft Cheers
need a keyboard but that can be off budget, got mouse got monitor and got a sata harddrive in laptop but really wannna use that a spare to be fair
is the i3 2100 better and quicker than the phenom II x6 1055t at a little extra cost
With reapers build. You have the option to drop in an i5 or i7 later on down the line. AMD are dead in the water and any investment into an AMD board is a bit pointless as it leaves the upgrade path non existent.
The cable management on the Coolermaster 430 is quite literally non existent. So a modular PSU will really help out with that. Just makes sure your wife wants blue leds and a see through side panel? If she wants something more conservative.... Fractal do a nice case within your budget.
ahh ok cheers for that ill prob stick with reapers build then or something very similar cheers again peeps
