Today we are offering large storage, and lightning fast performance storage. You can now get a 2TB hard drive for your Christmas Build for under £100 which has been the best price for weeks!!
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £69.98 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £69.98 inc VAT.
ORDER NOW
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) @ £99.98 inc VAT
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
- Direct Attached Storage devices–USB/FireWire/eSATA
- Network Attached Storage devices and Windows storage servers
- Eco friendly PCs
- High-capacity desktop storage
Features
- A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
- Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle–no utilities, no extra steps.
- The SATA 6Gb/s interface and 64MB cache maximize performance.
- Low power consumption combined with leadership in the use of environmental compliance materials means you don't have to sacrifice environmental stewardship for performance.
- Cool, quiet operation
- Capacity: 2TB
- Interface: SATA 6Gb/s
- Spindle speed: 5900RPM
- Cache size: 64MB
- Warranty: 3 Years
Only £99.98 inc VAT.
ORDER NOW
- Capacity: 60GB
- Warranty: 3 Years
ORDER NOW
- Eco friendly PCs
Features
- Capacity: 2TB
- Cache size: 64MB
- Warranty: 3 Years
ORDER NOW
