There is a list of all compatible things
here, from monitors, to gpu's
(Quick reference):
It does say 3d is not recommended for gaming with that GPU, but it is fine for everything else.
that link was Nividia.com this is from nvidia uk site and it states 3d vision supported :
GPU Engine Specs:
96CUDA Cores
550MHzGraphics Clock (MHz)
1340MHzProcessor Clock (MHz)
Memory Specs:
1700 MHz GDDR5, 1000MHz GDDR3, 900MHz DDR3MHzMemory Clock (MHz)
512 MB, 1 GBStandard Memory Config
128-bitMemory Interface Width
54.4 GB/secMemory Bandwidth (GB/sec)
Feature Support:
4.0OpenGL
PCI-E 2.0 x 16Bus Support
YesCertified for Windows 7
DirectX 11,
3D Vision, CUDA, PhysXSupported Technologies
Display Support:
YesMulti Monitor
2560x1600Maximum Digital Resolution
2048x1536Maximum VGA Resolution
YesHDCP
YesHDMI
DVI, VGA, HDMIStandard Display Connectors
InternalAudio Input for HDMI
Standard Graphics Card Dimensions:
6.6 inches (168mm)Length
4.376 inches (111 mm)Height
Single-slotWidth
Thermal and Power Specs:
105C CMaximum GPU Temperature (in C)
69 WMaximum Graphics Card Power (W)
300 WMinimum System Power Requirement (W)
