Hi,
I've been building computers for years professionally but have never needed to put together a watercooled setup. I now want to get better performance out of my i7 and reduce my case temp while playing games.
I will probably eventually end up with a watercooled card in the loop but I have a GTX295 with a dual pcb and it seems impossible to find blocks for them anymore.
I was looking at the V12 kit which looks nice and future proof. I have a Cooldermaster Silencio which I loath to get rid of as its pretty new and I like the drive bay in the front.
So my plan was to cut the top of the case to accommodate the radiator, this will have to go either on top of the case or inside the top depending on where is will fit. I'm fine with doing this, got the dremel etc. I would then mount the pump in the bottom and the res in the 5.25" bay.
My main question is; will having the res below the radiator likely cause a lot of air to get trapped in the radiator. If so then I probably need a new case to mount them at the same level but would rather hack mine about if possible.
Thanks in advance
Thanks in advance
