no its not, your an watch live tv through a laptop as long as you don't have it plugged in at the same time, see above![]()
Your own quote says it's not.
"Your parents' TV Licence will not cover you while you are away at university unless you only use a device that's powered solely by its own internal batteries. You must not plug it into the mains when using it to receive TV"
That shows that you don't need a TV license to watch live TV online. The completely ridiculous fact that it has to be powered by its own internal battery still means you don't need a TV license to watch BBC live streams.
It's a ridiculous exception, but it's there. Legality depends completely on if your laptop's charger is connected, complete arsetalkery.
Only if you have a second home with a tv license. Which means it pretty much only applies to students.
Soit's garbage except in limited cases.
