** MENTAL GAMING LAPTOP DEAL - MSI GT780 WITH GTX 570 ONLY £999 +VAT (£1199.99 Inc. VAT)!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have had MSI build us our own specification of laptop. We all known that for gaming performance the graphics card is the crucial aspect and having larger hard drives, 16GB of RAM or mental powerful I7 quad core processors won't actually improve gameplay that much as its the graphics card which adds the most FPS to your games and visual effects. :)
As such I present you this truly amazing deal:-
MSI GT780DX-603UK 17.3" WLED TFT Intel I5-2430M, 8GB DDR3, 750GB HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,199.99 inc VAT
What do gamers desire most? MSI knows best! In GT780DX, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT780DX provides you the best gaming experience!
GT780DX has a 17-inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT780DX is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
In order to present the best sound effects, the GT780DX speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
The exterior design of the GT780DX combines the classic, succinct appearance of a limousine with the aerodynamic contour of a spacecraft creating a low-key composure but powerful image. The black casing of the GT780DX is specially covered with brushed aluminum, coupled with the silver msi logo, it makes the GT780DX a symbol of the coexistence of textural quality and ultimate performance.
To avoid accidentally touching the touch pad while gaming, the GT780DX is equipped with a control switch for the touch pad on the side of the keyboard
Features:-
- Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- The Latest 2nd Generation Intel® Core™ i5 Processor
- High-end NVIDIA® GeForce GTX 570M discrete graphics card (with GDDR5 1.5GB VRAM) provides great detail images quality
- Best gaming keyboard designed by SteelSeries
- Exclusive TDE technology to speed up the performance
- Sound by Dynaudio for extreme audio performance
- Exclusive DDR3 SO-DIMM x 4 slot design easily upgrades memory capacity
- THX TruStudio Pro provides excellent surround sound
- Latest & fastest data transfer technology USB 3.0
Specification:-
- CPU Intel® Core™ i5-2430M Processor (3M Cache, 2.40 GHz) (3.0GHz Turbo Mode)
- OS Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- Chipset Intel HM67
- 8GB Memory DDR3 1333 MHz ,Slot : 4
- LCD Size 17.3" Full HD (1920x1080) LED backlight
- Graphics nVidia GeForce GTX 570M
- Graphics VRAM 1.5GB GDDR5
- HDD: 750GB (7200rpm) HDD
- Optical Drive: DVD Super Multi
- Audio 2.1 channels speakers, Sound by Dynaudio, THX TruStudio Pro, 7.1ch output
- Webcam HD type (30fps@720p)
- Card Reader SD(XC/HC)/MMC/MS(PRO)/xD
- LAN 10/100/1000
- Wireless LAN 802.11 b/g/n
- Bluetooth Bluetooth v3.0 + HS
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- eSATA/USB Combo N/A
- Mic-in/Headphone-out 1/1
- Line-in 1(line in)/1(line out)
- Express Card N/A
- Modem port N/A
- Keyboard 102-key keyboard by SteelSeries
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Power Management Turbo Battery+
- Dimension 428 x 288 x 55mm(WxDxH)
- Weight (KG) 3.9
- UK Model does *NOT* have backlit keyboard
- UK Model comes with FREE Dirt 3 PC Game
- Steelseries UK Keyboard layout (No Backlight)
- Supplied with Dirt 3, New gaming mouse, 17" Gaming bag
- 2yr Warranty
Was [£1299.99] Inc. VAT
Only £1,199.99 inc VAT. SAVE £100 (Valid only between 09/12/2011 too 01/01/2012)
ORDER NOW
This is an incredible price for a laptop with a GTX 570 graphics card in it as to put it simply this laptop is capable of playing any game including the latest Battlefield 3 smoothly. Even more so if you order between now and the 1st of January 2012 you will save £100. So what are you waiting for, get your wallets out! :D
i5 cpu? Seriously? Doesn't seem to be the right cpu for this machine. Should be a quad core imo.
Its a gaming machine, the most important aspect is the graphics card and an I5 Dual Core CPU that runs at 3.00GHz in Turbo mode is more than ample enough for games.
For example you could have the same laptop with an I7 Quad core but with a GTX 560M to try and balance out the cost, but the I5 machine would still be quicker in games.
If your doing some kind of decoding work or more CPU intensive task then of course an I7 is beneficial. But these laptops are sold as gaming laptops and designed for gaming, the most important aspect of gaming is the graphics card. As such you can now get a laptop which will play games extremely well with a GTX 570M for an incredibly low price. :)
Can this laptop easy replaced to 2.5" solid state (sata 3) ? or remain on sata 2 ?
I believe it is SATA3. :)
There is capacity for 2 drives in this laptop, so you can just add an SSD as the boot and still hold onto the 750GB storage drive. :)
