Call of Duty: Modern Warfare 3
Ooh I see why the MP9 is beast now the damage multiplier is 2.0 for the head. That's 2 shots on close range damage. I think Stalker does something to sensitivity, but what level are you using now? You might find it unmanageable with the perk boost then.
Hmmmm I don't know either guessing you are on about - Quick Draw which lets you ADS quicker? If not then Sleight of hand is reload quicker, Stalker lets you move quicker while ADS?
If it any of those then nothing you can do to sensitivity to get them to happen quicker as they are all on buttons or limited by the game.
I havr to agree with Gashman though, the Type 95 while powerful is a burst gun so should be a little bit more powerful than the fully automatic AR's due to needing to accurate with the burst rather being able to spray and pray. Quick scoping could be seriously decreased if you couldn't fire until you can see through the scope as now you get killed with the scope halfway to ADS which is pathetic. Or even removing the ability to have sleight of hand / quick draw on the sniper rifles would help. Everyone knows the problems with fmg9's though.
The thing I do not understand though is how did they not forsee this. Surely in the alpha/beta stages it was obvious how easy QSing was? considering how easy it was in mw2.
It is when I am ADS that it is quicker, I am currently on the default sensitivity setting.
Was just an idea, but I get you mean by boosting the sensitivity in game may make it harder when you have the ADS boost as well.
Maybe I should up the sensitivity and not use the perk. Although I do love the delayed trip on equipment.
The only thing quicker with stalker is your strafe with the movement stick whilst ADS. It doesnt affect the aim sensitivity.
Yep just tested it to be sure 16 seconds to 360 with an LMG on sensitivity level 1. Almost impossible to strafe and track a target with stalker on that setup so you definitely need a higher sensitivity level with stalker imo.
I'm confused now.
You saying I need to set my sensitivity higher than 2? :confused:
2 is to slow anti - I play at 3 but as soon as I am quick enough I'll be going up to 4. Bare in mind I'm a Rusha & loaded out to suit.
2 was to slow for me, It may be great for ADS/Sniping etc but I steam around looking to get the drop on people. On 3 I can flick look left & right checking my corners & can spin with enough time to get shots off, 4 will be better though as I reckon that's up there with mouse for speed/twitching.
Exactly, 2 would be perfect for camping but running around I'd need min 4.
I don't camp though.
I did go up a level higher than the default one in MW2 and got on ok with that, might have to increase the setting to a level higher.
Stalker lets you walk around quicker while ADS, as far as I am aware it has no effecg on how fast you can move your aim around as that is down to personal sensitivity options.
