Over the past few days the oil light has come on when stopping at roundabouts etc. so I bought it with the view to just topping it up.
When my old man showed me how to oil change a car years ago it was a case of showing me how to see if the oil needed topping up via the dipsticks readings, oil filters weren't mentioned!![]()
You can even chuck your spare down on the kerb & drive up onto it ***** style no jack or owt.![]()
Ok, I think I might have to get a garage to do this, don't see how I'm gonna get this all done with just a wheel jack!
Yeah I've seen one or two informative youtube vids on it now, the process is easy, it's just that I only have one wheel jack so would have to jack one side of the car up and would feel unsafe under my car like that.
(if you even need to raise it)Don't work under your car if it's just jacked up - not worth the risk, get some axle stands(if you even need to raise it)
My question is do I need to drain the old oil as it's a different type (semi vs fully)
Not sure if it would be any different with cars or not but at work the oil drums (one regular oil, one synthetic) have a big sign by them warning not to put synthetic oil in Scanias as the oil won't mix properly and causes - apparently - turbo problems.
interesting.................
My dad was told, when he bought my last lot of oil from his ford buddies, not to mix the old ford semi synth with new ford fully synth.
Didn't say why, I would imagine there must be a difference in densities, which would cause poor mixing.
Anyone got some semi and fully synthetic they can test?![]()
