Caporegime
- 13 May 2003
- Warwickshire
Hi, not sure what section's best so let's try here...
As per sig I'm running a S775 board and CPU and I decided I wanted 8GB of RAM for BF3. The board doesn't support 8GB of DDR2, so the only way for me to achieve this, was to buy DDR3.
I can post at 3.6GHz / 1.4V indicated with a FSB of 450, however I have to run the memory 1:1 at 900MHz in order to get it to work at standard timings, when the memory is rated at 1333MHz.
Does anyone know if this is likely to be a limitation of the board and something I'll have to put up with? The P35C-DS3R supports 1333 memory / FSB so I'm slightly confused as to why I can't run a higher divider on the RAM. There aren't that many people I can find running DDR3 in a P35C and that have encountered this problem, so I'm more hoping for some general advice on what might be going on.
I haven't played with the NB / FSB voltages or the RAM voltage. I have the latest BIOS. The RAM is Corsair XMS3 1333.
Thanks very much for any thoughts.
