- 3 Feb 2011
Entered :>
it does if your looking at the right card.
its the OVERCLOCKED TEMPRATURE
theres 2 of the card one standard clocks and then the tempratures for oced
All I can assume is that the question has been worded wrongly, I am incredibly stupid, the question is VERY misleading in some way, or rounded answers have been provided (like I said earlier).
I'm sorry to have to tell you bud, it's not your 1st, 3rd or 4th option above.
Try reading the question again, it's very straight forward. No rounding up is required in the temperature question.
Entered, Good luck to everyone who has entered![]()
i dont get these people either
the GTX560 448 core OC temp clearly fits the answer
.Not the exact result as I noticed that too, still obvious which was the answer.I just realised after waking up what an epic facepalm moment I had.
I misread the original post as the FOURTH question and not the third.
So in response if you apply what I was saying to the fourth question, you will see what I mean by that the exact result you get is not an answer in the question.
entered
sorry for the dumb question, but what is the bottom temperature bar for? is it idle temperature or something? (55C seems quite high for idle temps though)
