The best media player gets even better!
Can be downloaded here: http://www.xvidvideo.ru/media-playe...er-classic-homecinema-x86-x64-1-5-3-3847.html
Black edition looks superb, especially when used with the logo I made
Change : update ffmpeg, remove old AMR decoder and use latest.;
Change : some code cleanup;
Fix : debug build crash;
Change : Add info in MediaType about AMR codec;
embed the manifest files directly via the rc files;
remaked "Select shaders..." dialog (thanks to judelaw);
Fix : MPEGSplitter, when switch tracks - do not switch the other tracks, if it related to the new program;
Change : comment some ASSERT() for the easy debugging;
update buildmingwlibs.sh (/tags/v1.0.2);
Change : modify patch for MinGW64 to compile libmingwex.a with GCC 4.6.x
fixed a typo in the buildmingwlibs.sh;
Fix : issue with black screen on Haali render at file open, thanks to judelaw;
Fix : MPEGSplitter, incorrect parse video stream on old QuickTime MPEG4 files;
Change : modify event on Mouse DBLClick;
Fix : Cursor does not hide when he does not need to hide with multi-monitor configuration - patch by judelaw.
