Want some electronic components with cheap/free shipping
Thanks but it's ok, ill try to sort something out.
Yeah, i found one, would it be possible to have a diode and resistor to drop the voltage?
Just google the line . . . .
They are using the diodes just to drop the voltage, its easier than trying to work outthe correct value of resistor, maybe it needs too high a wattage to work correctly.
Hmm, i did see that but thought it only had the wrong ones, also it appears to be free delivery in the basket but says £2.99 on all orders under £35, confusing.
Free shipping is a limited offer.
Personally I would use 0.5w 3.3v Zener diode to clip the voltage.
Grr I threw out a load of electronic components along with stripboard/etching board a few weeks ago... :(
Actually i have some other diodes that look like the ones you posted above, i don't know what they are though, i have a diode setting on my multimeter, never tested them though, what do i need to know?
The part number :)
They all look like that, you could test the clipped voltage in a small circuit. Hardly worth the effort.
