Wheres the release notes?
AMD HD3D technology support enhancement
Enables support for AMD HD3D technology in conjunction with AMD CrossFireX configurations
Delivers a new Stereo 3D mode over HDMI 1.4a connections - 1080p at 30Hz is now enabled on supported displays.
AMD Catalyst Control Center / Vision Engine Control Center enhancements – Application Profiles
AMD Catalyst 12.1 Preview driver enables users to create per application profiles to individually control 3D and CrossFireX settings for Direct3D applications
Please be sure to select the “Restore Factory Defaults” option under the Catalyst Control Center Preferences menu before using the new application profiles feature – this ensures there are no compatibility issues between previous drivers and the new AMD Catalyst 12.1 Preview driver with regards to application profiles
AMD Catalyst Control Center / Vision Engine Control Center enhancements – Video UI improvements
AMD Catalyst 12.1 Preview driver includes user interface enhancements to simply adjustment of video color and video quality controls
Performance highlights of the AMD Catalyst™ 12.1 Preview driver (in addition to the AMD Catalyst 11.11c performance driver)
Improves performance (10%) in Elder Scrolls: Skyrim when Multi-Sample Anti-Aliasing is enabled on the AMD Radeon™ HD 6900 Series for single GPU and AMD CrossFireX configurations
KNiVES have you set your TV to "scan only" mode in picture options?
My ATI card for connecting via HDMI always underscanned until I realised it was a picture mode setting on the TV.
Certainly a step in the right direction, the lack of options (especially for Crossfire) really frustrated me when I had my 5850s. It would be great if they integrated something along the lines of the Visual Indicator Bar in SLI, which I've found useful for testing.
It's in the OP Link.
So in other words there's no point bothering with 11.12? Explains why Saints Row 3 and Skyrim got worse with then. I'm sure it's no easy task keeping their drivers performing well and more often than not they do seem to be playing catchup, but some of their decisions are just baffling.Going to give these a try tonight. Apparently 11.12 doesn't have all the optimised settings from 11.11c so amd are recommending either 11.11c or 12.1.
Is it possible to export these custom profiles in 12.1?
