Western Digital Caviar Green 3TB SATA 6Gb/s 64MB Cache - OEM (WD30EZRX) @ £209.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 3TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £229.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Hitachi Deskstar 5K3000 3TB SATA 6Gb/s 64MB Cache 5900RPM - OEM @ £199.99 inc VAT
The Deskstar™ 5K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 5900 RPM performance in a standard 3.5-inch form factor. The 5K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 5900RPM
- Bootable with Sandybridge P67/H67/Z68 Motherboards
- Warranty: 2 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Was £209.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Toshiba MK5076GSX 500GB 5400RPM SATA-II 8MB Cache - OEM @ £64.99 inc VAT
The MK5076GSX 5,400 RPM, 2.5-inch hard disk drives offers one-half terabyte in capacity with quiet acoustics and enhanced durability, providing a solid storage solution for mobile and stationary PCs, game consoles, printers, external storage devices as well as set top boxes, personal video recorders and surveillance systems.
- 2.5"
- 500GB of Storage Capacity
- 5,400 RPM Spin Speed
- Serial ATA 3.0 Gbps and Extended SATA Features
- Light-weight, Standard 9.5 mm-High Design
- Super-quiet Seek Technology
- Eco-Conscious and Low Power Design
Was £89.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Samsung SpinPoint M7 500GB 5400RPM SATA-II 8MB Cache - OEM (HM500JI) @ £84.98 inc VAT
The Spinpoint M7 utilizes Samsung’s proprietary SilentSeek and NoiseGuard technologies to minimize noise-levels during drive operation. The new M7 drive offers a shock resistance level of 400G (2ms) in operation mode and 900G (1ms) when the power is off. An optimized system-on-chip controller reduces the power consumption in both seek and idle modes to the lowest level among comparable drives.
- Capacity: 500GB
- Cache: 8MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 12.0ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £71.99 inc VAT
nonl2brAs the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
<br><br>
- Capacity: 60GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 525MB/sec<br>
- Maximum Write: 475MB/sec<br>
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- Warranty: 3 Years<br>
<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/rF5PdfFGomw" frameborder="0" allowfullscreen></iframe>
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £67.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 Years
Was £80.99 Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
OCZ Vertex 3 60GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-60G) @ £89.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br><br>
- Maximum Read: 535MB/sec<br>
- Maximum Write: 480MB/sec<br>
- Sustained Write: 455MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/CKMODN3kIpE" frameborder="0" allowfullscreen></iframe>
Was £99.98 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
OCZ Synapse Cache 64GB SATA-3 Solid State Hard Drive (SYN-25SAT3-64G) @ £103.99 inc VAT
OCZ Synapse Cache Solid State Drives accelerate workstation and desktop computing applications with an innovative hardware-meets-software design and advanced caching feature-set.
The OCZ Synapse Series integrates the benefits of SSD performance and HDD capacity with Dataplex™ caching software to dynamically manage the use of both SSD and HDD for superior overall storage performance. This combination creates an environment where the most frequently used "hot" data stays on the ultra-fast SSD, while the "cold" data remains on the larger capacity HDD (sold separately). Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user, maximizing productivity for the most demanded programs and applications. Synapse Series integrates seamlessly within any modern PC platform, ensuring optimal compatibility along with performance gains.
High Performance SSD Architecture
- Maximizes performance with SATA 6 Gb/s interface
- Unleashes the full potential of today’s leading platforms
- OS/application bootable with TRIM support
- Easy-to-deploy 2.5” solution for multiple drive bays
Integrated Dataplex™ Caching Software
- Intelligently manages HDD and SSD simultaneously
- “Hot” data managed on Synapse SSD for highest performance, access, and bandwidth
- “Cold” data routed to HDD for highest capacity usage
- No data migration or OS installation required
- Delivers up to 80,000 IOPS
- Bandwidth up to 550 MB/s
- Usable SSD capacity up to 32GB on 64GB Model
- Manages and accelerates full HDD capacity
Was £119.99 Inc. VAT
Only £103.99 inc VAT.
ORDER NOW
OCZ Agility 3 240GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-240G) @ £259.99 inc VAT
<br><br>
- Capacity: 240GB<br>
- Maximum Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 45,000 IOPS (4KB File)<br>
<br>
<br>
Was £289.99 Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
OCZ Octane 128GB 2.5" SATA-3 Solid State Hard Drive (OCT1-25SAT3-128G) @ £152.99 inc VAT
nonl2brCombining high-speed data transfer rates with record-breaking access times, OCZ Octane SSDs are designed to provide a superior user experience and improved application performance. Octane leverages the cutting-edge Indilinx Everest platform and is optimized for the complete spectrum of file types and sizes, with proprietary page mapping algorithms mirroring real world conditions across a wide range of applications. The Octane series also includes advanced features unique to Indilinx, including latency reduction technology to enhance system responsiveness and enable instant-on boot-ups. Octane SSDs also deliver the energy efficiency, durability, and reliability that traditional hard drives cannot provide.<br>
<br><br>
- Capacity: 128GB<br>
- Controller: Indilinx Everest<br>
- Maximum Write: 170MB/sec<br>
- Max I/O Per Second (IOPS): 37000 IOPS (4KB File)<br>
- 2.5" to 3.5" SSD adaptor included<br>
<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/Ct2mt3wTXms" frameborder="0" allowfullscreen></iframe>
Was £155.99 Inc. VAT
Only £152.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £158.99 inc VAT
<br>
- Capacity: 120GB<br>
- Maximum Read: 550MB/sec<br>
- Sustained Write: 500MB/sec<br>
<br>
Was £172.99 Inc. VAT
Only £158.99 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £349.99 inc VAT
- Maximum Write: 520MB/sec<br>
- Sustained Write: 520MB/sec<br>
<br>
Was £379.99 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
OCZ Synapse Cache 128GB SATA-3 Solid State Hard Drive (SYN-25SAT3-128G) @ £169.99 inc VAT
- Usable SSD capacity up to 64GB on 128GB Model
Was £194.99 Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 120GB PCI-E SSD - (RVD3-FHPX4-120G) @ £299.99 inc VAT
The OCZ RevoDrive 3 PCI-Express Solid State Drive Series was designed with power users and multimedia designers in mind and gives enthusiasts the cutting-edge storage they crave. Eliminating the SATA bottleneck, the PCIe-based Revo3 delivers ground-breaking 1GB/s of bandwidth and 130,000 4KB random write IOPS making this an ideal SSD for high performance applications, multimedia, and workstations. Along with unprecedented performance, the Revo3 features OCZ’s proprietary Virtualized Controller Architecture (VCA) 2.0 which provides features including TRIM support and SMART data monitoring, something previously unheard of with PCIe solutions. In addition, the Revo3’s SuperScale storage accelerator enables scalable SSD performance and significantly reduces the host CPU burden inherent to competing PCIe storage offerings. The RevoDrive 3 series is a premium feature rich storage solution that delivers superior performance and reliability through innovative design.
- Capacity: 120GB
- Controller: Dual SandForce SF-2281 (RAID)
- Maximum Read: 975MB/sec
- Maximum Write: 875MB/sec
- Max I/O Per Second (IOPS): 130,000 IOPS (4KB File)
- Interface: PCI-Express x4
- Warranty: 3 Years
Was £323.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 240GB PCI-E SSD - (RVD3-FHPX4-240G) @ £439.99 inc VAT
- Capacity: 240GB
- Maximum Read: 1000MB/sec
- Maximum Write: 900MB/sec
- Warranty: 3 Years
Was £479.99 Inc. VAT
Only £439.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 480GB PCI-E SSD - (RVD3-FHPX4-480G) ** PRE-ORDER** @ £1,139.99 inc VAT
- Capacity: 480GB
- Maximum Write: 925MB/sec
- Warranty: 3 Years
NOTE
** All RevoDrive3/RevoDrive3 X2 will be ordered on receipt of purchase. **
** Allow 5-10 working days for delivery **
Released Mid July
Was £1,199.99 Inc. VAT
Only £1,139.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 X2 240GB PCI-E SSD - (RVD3X2-FHPX4-240G) @ £539.99 inc VAT
The OCZ RevoDrive 3 X2 PCI-Express Solid State Drive Series was designed with power users and multimedia designers in mind and gives enthusiasts the cutting-edge storage they crave. Eliminating the SATA bottleneck, the PCIe-based Revo3 X2 delivers ground-breaking 1.5GB/s of bandwidth and 230,000 4KB random write IOPS making this an ideal SSD for high performance applications, multimedia, and workstations. Along with unprecedented performance, the Revo3 X2 features OCZ’ proprietary Virtualized Controller Architecture (VCA) 2.0 which provides features including TRIM support and SMART data monitoring, something previously unheard of with PCIe solutions. In addition, the Revo3 X2’s SuperScale storage accelerator enables scalable SSD performance and significantly reduces the host CPU burden inherent to competing PCIe storage offerings. The RevoDrive 3 X2 series is a premium feature rich storage solution that delivers superior performance and reliability through innovative design.
- Capacity: 240GB
- Controller: Quad SandForce SF-2281 (RAID)
- Maximum Read: 1500MB/sec
- Maximum Write: 1250MB/sec
- Max I/O Per Second (IOPS): 230,000 IOPS (4KB File)
- Warranty: 3 Years
Was £569.99 Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 X2 480GB PCI-E SSD - (RVD3X2-FHPX4-480G) @ £1,289.99 inc VAT
- Capacity: 480GB
- Warranty: 3 Years
Was £1,349.99 Inc. VAT
Only £1,289.99 inc VAT.
ORDER NOW
OCZ RevoDrive HYBRID 1TB PCI-E SSD Hard Drive - (RVDHY-FH-1T) @ £374.99 inc VAT
nonl2brUnique Hybrid Storage Solution for Performance and Value<br>
<br>
OCZ RevoDrive Hybrid is the next step in the evolution of storage technology for power users, multimedia designers and game enthusiasts. The PCI-ebased RevoDrive Hybrid not only eliminates the SATA bottleneck to unleash groundbreaking bandwidth and landmark IOPS performance, but it also includes a high-capacity harddisk drive and intelligent software that integrates SSD and HDD into a single high-performance and high-capacity storage solution. <br>
<br>
The OCZ RevoDrive Hybrid comes bundled with intelligent caching software that dynamically manages the use of the SSD with the 1TB HDD for superior overall storage performance. The most frequently/recentlyused “hot” data stays on the ultra-fast SSD while “cold” data remains on the slower but larger capacity disk. Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user. Welcome to the next generation storage from OCZ Technology.<br>
<br>
Highest Performing Hybrid Drive on the Market!<br>
- Completecaching solution on a single card<br>
- SSD performance withoutsacrificing a low cost per gigabyte<br>
- Delivering an exceptional all-in-one solution for power users, multimedia designers, and computing enthusiasts<br>
<br>
OCZ SuperScale Storage Accelerator<br>
- Facilitates scalable performance for intensive workloads<br>
- Unique complex command queuing structure (CCQS) with queue balancing algorithms (QBA)<br>
- Higher performance and reduced burden on the host CPU<br>
<br>
OCZ Virtualized Controller Architecture<br>
- VCA 2.0 presents as a complete storage subsystem for superior data management<br>
- Only virtualization layer in the industry with TRIM and SCSI unmapsupport<br>
- Enables SMART monitoring for system administrators<br>
<br>
Intelligent Caching Software<br>
- Simultaneously manages HDD and SSD, learning individual user behavior to adapt storage policies<br>
- “Hot” data managed on Synapse SSD for highest performance, access, and bandwidth<br>
- “Cold” data routed to HDD for highest capacity usage<br>
<br>
<br>
- Capacity: 1TB total storage with 2 x Sandforce 2281 based drives (100GB) acting as cache<br>
- Nand: 25nm MLC<br>
- Storage: 1TB 5400rpm HDD<br>
- Weight: 289g<br>
- Interface: PCI-Express Gen. 2 x4<br>
- MAX Read: up to 910MB/s<br>
- MAX Write: up to 810MB/s<br>
- MAX 4KB Random Write: 120,000 IOPS (475MB/s)<br>
- Sequential Read: up to 290MB/s<br>
- Sequential Write: up to 130MB/s<br>
- 4KB Random Write: 32,000 IOPS (120MB/s)<br>
- Product: RevoDrive Hybrid<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/jEhid7qFWBk" frameborder="0" allowfullscreen></iframe>
Was £399.98 Inc. VAT
Only £374.99 inc VAT.
ORDER NOW
Acoustic Energy Aego M 2.1 Speaker System - White @ £118.99 inc VAT
The Aego M-System builds on the strengths of the award winning Aego 2, offering a pair of heavy-alloy satellite speakers and a compact subwoofer for a full range sound that embodies AE’s sound quality principles. The sleekly styled satellites have smoother treble and a funky rounded design while potent amplifiers are built into the subwoofer to drive all three loudspeakers. The package gives room-filling sound from devices like the iPod™, PSP™ or MP3 mobile phones. With just one cable the M-System turns any personal music device into the heart of a home entertainment system. In the living room, in the bedroom, away at college or simply for a spontaneous party, the M-System delivers a big sound form the smallest devices. Better still, the M-System’s gorgeous looks, high quality sound and plug and play simplicity won’t cost a fortune as it remains just as affordable as the best selling AE Aego 2.
- Easy to setup and use
- Hi-fidelity, high volume sound
- Instant home entertainment
- Big hi-fi sound from the smallest devices
- Outstanding value for money
- Inputs: 3 x RCA Phono - Line level, 1 x Stereo Mini jack - Line level
- Outputs: 3 x Speaker terminals
- Controls: 1 x Volume / Power pot, 1 x Bass switch (3 Position), 1 x Centre input switch (2 Position)
- Power ratings: 120V Model - 120V @ 60Hz; 80VA, 240V Model - 240V @ 50Hz; 80VA, 90 Watts RMS total system power rating
- Frequency response: Sub is 50Hz-250Hz and the satellites are 250Hz-16KHz
- Dimensions: Sub Woofer - 265 x 190 x 350mm, Satellites - 68mm x 103mm x 90mm
- Weight: 9 Kg
Was £123.98 Inc. VAT
Only £118.99 inc VAT.
ORDER NOW
Asus Xonar D2 7.1 PCI Sound Card @ £86.99 inc VAT
ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- Unprecedented SNR Up to 118db reaching the limit of PC sound clarity
- High-definition audio processing at 192KHz/24Bit for all Input and outputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theatre System
Was £89.99 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Asus Xonar D2X 7.1 PCI-E Sound Card @ £83.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Was £88.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £18.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
**Supplied with Driver disk, Manual, Low profile PCI bracket and Xonar DG card - All thats missing is the box!**
Was £20.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium 7.1 Sound Card - OEM (30SB088200000) @ £56.99 inc VAT
Creative's Sound Blaster X-Fi Titanium is the essential audio upgrade for maximum PC gaming and entertainment. Whether you use Windows XP or Vista, its PCI Express design guarantees total compatibility, plus hardware-accelerated EAX 5.0 and OpenAL support for maximum gaming performance. With X-Fi CMSS-3D for accurate and immersive 3D positional audio even over headphones, this card will give you the edge over the competition! THX certified, it also features onboard Optical I/O and real-time Dolby Digital encoding for single cable connectivity to your surround sound decoder. The supplied PowerDVD software works with X-Fi technology to let you play Dolby and DTS movies in incredible surround sound over headphones or speakers.
- Sound Blaster X-Fi PCI Express chipset is designed for the latest PCs.
- Hardware-accelerated EAX 5.0 and OpenAL gaming for ultra-realistic cinematic in-game audio. Creative ALchemy software restores EAX surround sound to Windows XP games under Windows Vista.
- Delivers accurate and immersive X-Fi CMSS-3D surround sound over headphones for on-line or late-night gaming sessions.
- On-board optical I/O with Dolby Digital real-time encoding, for single cable connection to your surround sound decoder.
- UAA (Universal Audio Architecture) design ensures maximum compatibility under Windows Vista.
Was £67.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Creative Inspire T10 2.0 Speaker System (51MF1600AA001) @ £26.99 inc VAT
Creative Inspire T10 speakers give a high-quality performance of all your digital music. Compact and sleek, in glossy black, they combine advanced engineering with good looks to deliver better audio with your PC, notebook or MP3 player. They create a true ‘Hi-Fi' sound stage, using separate tweeters for high-end perfection, precision drivers for accurate mid-tones and BasXPort technology for strong lows without a subwoofer. Separate controls for volume and bass enable you to optimise playback with any kind of music, and you can position Inspire T10s close to PC monitors and TV screens thanks to their magnetic shielding. They include a headphone socket for private listening.
- Elegant 2.0 design with separate 1-inch tweeter and 3-inch mid-range drivers in each satellite for improved highs and mid-tones.
- BasXPort feature in each satellite adds strong bass to complete the sound stage, without requiring a separate subwoofer.
- Separate tone and volume/power controls enable output to be adjusted to suit personal taste.
- Can be connected to MP3 players as well as PCs and notebooks. Headphone port for private listening.
- Magnetic shielding enables speakers to be positioned close to PC monitors, notebooks and other equipment.
Was £32.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Creative Inspire A520 5.1 Speaker System (51MF4110AA008) @ £39.98 inc VAT
Give your games, music and movies a much-needed boost with the Creative A520 5.1 speaker system. Given their contemporary style and ease of use, they are the perfect choice for immersive multi-channel surround sound, bringing to you all the benefits of Creative’s leadership in audio technology. The five satellites make use of the two-inch drivers for crisp dialogue and impressive effects, while the large subwoofer with a flared port tube and separate bass control provides you with the freedom to adjust your bass level and deliver the extra impact and oomph for all of your entertainment needs. The system also includes a wired remote for easy-to-reach and convenient control.
- Speaker Power: 5Watts RMS per channel (5 channels)
- Subwoofer: 12Watts RMS
- Frequency Response: 40Hz ~ 20kHz
- Signal-to-Noise Ratio (SNR): 75dB
- Product Weight: 3.5 kg
- Dimensions (HxWxD): Speaker (144x80x104)mm, Subwoofer (235x192x192) mm
Was £49.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Hitachi Deskstar 7K3000 2TB SATA 6Gb/s 64MB Cache 7200RPM - OEM (0F12115) (HDS723020BLA642) @ £169.99 inc VAT
The 7K3000 is the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB Cache Buffer delivers a big boost to performance over the previous generation product.
The Deskstar 7K3000 is designed to allow users to leverage the benefits of the latest components and operating systems to deliver high-performance, high-capacity, power-efficient systems.
- 2TB
- 64MB Cache
- 7200 RPM performance
- 6Gb/s SATA interface for improved performance over previous generation product
- Eco-friendly, Halogen-free design
- Designed to leverage new platforms and modern operating systems
Was £199.99 Inc. VAT
ORDER NOW
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) @ £104.99 inc VAT
The F3 operates at 7200RPM with offerings of up to 1TB data storage capacity by using two 500GB per platter disks. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 1TB
- Cache: 32MB
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £104.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £94.99 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 1TB
- Cache: 32MB
- Warranty: 2 Years
Was £109.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Western Digital VelociRaptor 600GB 10000RPM SATA 6Gb/s 32MB Cache - OEM (WD6000HLHX) @ £204.98 inc VAT
WD VelociRaptor hard drives offer twice the capacity of the previous generation while delivering higher performance and cool quiet operation for gaming, workstations, and low-end servers. With a superbly engineered combination of 10,000 RPM spin speed, SATA 6Gb/s interface and a 32MB cache, these drives are truly an evolution in performance. The IcePack mounting frame encloses the 2.5" WD VelociRaptor in a backplane-ready 3.5" enterprise-class mounting frame with a built-in heatsink that keeps this powerful little drive extra cool when installed in high-performance desktop chassis.
- Capacity: 600GB
- Cache: 32MB
- Spin Speed: 10000RPM
- Seek Time: 3.6ms
- Warranty: 5 Years
Was £249.98 Inc. VAT
Only £204.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 500GB SATA 6Gb/s 32MB Cache - OEM (WD5002AALX) @ £99.98 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 32MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it.
- Capacity: 500GB
- Cache: 32MB
- Warranty: 5 Year
Was £111.98 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) @ £69.98 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) @ £84.98 inc VAT
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
ORDER NOW
Samsung SpinPoint F4 320GB SATA-II 16MB Cache - OEM (HD322GJ) @ £76.99 inc VAT
The Spinpoint F4 features 7200rpm speed rotation, advanced areal density technology and a SATA 3.0 Gbps interface. Equipped with Samsung's exclusive dynamic balancing technology, the drive's overall stability and reliability is optimized as a high performing solution. Samsung's proprietary SilentSeek and NoiseGuard technologies are incorporated in the drive to offer ultra quiet operation. With a one-head platform design and fewer mechanical parts, the reliability and acoustic features of the Spinpoint F4 have been improved. The drive delivers 10% increased read/write performance and 7% lower power consumption than the Spinpoint F1. The superior performance and high-reliability Spinpoint F4 is engineered for high-end computing in PCs, Macs, high-end workstations and server applications.
- Capacity: 320GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £83.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
Samsung SpinPoint F3 250GB SATA-II 16MB Cache - OEM (HD253GJ) @ £69.98 inc VAT
The F3 operates at 7200RPM with offerings 250MB data storage capacity. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 250GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £77.99 Inc. VAT
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £163.99 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Only £163.99 inc VAT.
ORDER NOW
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £122.99 inc VAT
<br><br>
<br>
<br>
Was £129.98 Inc. VAT
Only £122.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £249.98 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £269.99 Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £124.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="728" height="90"><param name="movie" value="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf" /><param name="quality" value="high" vmode=transparent /><embed src="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Was £149.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £99.98 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £161.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £251.99 inc VAT
- SR0DG MALAY Stepping
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
Was £265.99 Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £839.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.30GHz (3.90GHz TURBO)
- Multiplier: 33x (Unlocked Multiplier)
- L2 Cache: 6x 256KB
- L3 Cache: 15MB
- TDP: 130W
- DOES NOT INCLUDE COOLER
- 3yr Warranty
Was £851.99 Inc. VAT
Only £839.99 inc VAT.
ORDER NOW
AMD Athlon II X3 Tri Core 455 3.30GHz (Socket AM3) - Retail @ £65.99 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Tri Core Technology
- 3.30GHz Clock Speed
- AM3 Socket
- 3x 512KB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £71.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail @ £89.99 inc VAT
We call it the new AMD FX 4-Core Processor Black Edition and it's unlocked for your overclocking pleasure. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Quad Core Technology
- 3.60GHz Clock Speed
- 3.80GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 4MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 95W
- Voltage: 0.925v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- 3 Year Warranty
Was £94.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £29.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/12GX) @ £53.99 inc VAT
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Capacity: 6GB (4GBx3)
Type: 240-pin DIMM
Warranty: Lifetime
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £59.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-10-9-27 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) @ £40.79 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £44.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (KHX1600C9D3K4/16GX) @ £65.99 inc VAT
Kingston proudly introduces HyperX DDR3 memory, the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2.
This dual/quad-channel HyperX memory kit is Intel XMP-Certified, and runs at a latency timing of 9-9-9-27 at 1.50-1.60V operating voltage for Intel dual/quad-channel Sandy Bridge P67, X79 or Z68 platforms.
Model Name: KHX1600C9D3K4/16GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67, INTEL X79
Capacity: 16GB (4GBx4)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Warranty: Lifetime
Was £74.99 Inc. VAT
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £23.99 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was £25.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 900MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 3 Years
Was £299.99 Inc. VAT
Only £287.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £224.99 Inc. VAT
ORDER NOW
Titan Decimator MKII Intel Core i7 980 3.33GHz @ 4.00GHz DDR3 Hex Core System @ £1,023.97 inc VAT
Harnessing the power of the Intel Core i7 980 Six core CPU. With six processing cores and triple channel DDR3 memory the "Titan Decimator MKII" provides an excellent basis for a workstation, gaming and home cinema system, with power to spare. With a choice of the latest DX11 graphics, the "Titan Decimator MKII" is proven performer.
Why You Should Buy This System
- True DX11 gaming performance available from a choice of compatible graphics cards
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- SATA 6GB/s and USB 3.0 for next gen computing
System Specification
- Case: BitFenix Shinobi Case - Black
- Power Supply: OCZ ZS 550w PSU
- CPU: Intel Core i7 980 3.33GHz @ 4.00GHz
- Motherboard: Gigabyte G1 Guerilla Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: OcUK H2 Flo Extreme
- RAM: 6GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Choice of the latest DX11 Graphics cards
- Sound: Realtek Creative 7.1 Gaming Audio (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
For when nothing but pure power is required, the "Titan Decimator MKII" has it by the bucket load.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £1,073.96 Inc. VAT
Only £1,023.97 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Dirt 3 PC Game** @ £199.99 inc VAT
- Core Clock: 800MHz
- Memory Clock: 5000MHz (Effective)
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with Dirt 3 Download coupon
ORDER NOW
"Titan Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Quad Core System @ £523.98 inc VAT
Strong, resolute, powerful, the "Titan Triceratop" the natural enemy of the T-Rex. Providing immense graphical power and CPU processing speed. The "Titan Triceratop" has a ludicrous 4.40GHz overclock, which enables you to power through the latest games and applications. Own your game with the "Titan Triceratop"!
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Coolermaster Elite 334 Case - Black
- Power Supply: OCZ ZS 650w PSU
- CPU: Intel Core i5 2500K 3.30GHz Sandybridge overclocked to 4.40GHz
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Xigmatek Red Scorpion CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Sound: Realtek 7.1 Channel Sound (On-Board)
Service Package
Powerful and reliable. The two qualities you need to get you through your game, the "Titan Triceratops" lauches you into the next generation of computing.
Was £559.98 Inc. VAT
Only £523.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £119.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 3 Years
Was £127.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6870 OC 1024MB GDDR5 PCI-Express Graphics Card @ £143.99 inc VAT
Immerse yourself with AMD Eyefinity technology and expand your games across multiple displays. Experience ultra-realistic visuals and explosive HD gaming performance in true ?EyeDefinition with AMD’s second generation graphics featuring full Microsoft DirectX® 11 support. Enable incredible video quality and enhanced application performance with AMD EyeSpeed visual acceleration technology.Get unrivalled graphics. Get Radeon™ in your system.
- Core Clock: 920MHz
- Memory Clock: 4200MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Only £143.99 inc VAT.
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card **Lowest Price DX11 Graphics Card in UK** @ £23.99 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Core Clock: 650MHz
- Memory: 512MB GDDR3
- Memory Interface: 64-Bit
- Memory Clock: 1066MHz (Effective)
- Processing Cores: 80
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was £25.99 Inc. VAT
ORDER NOW
MSI GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card @ £719.99 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 2yr Warranty
IMPORTANT: The supplied Geforce Drivers 267.52 for Geforce GTX 590 will not stop the card from overheating when overclocking. Please use newer versions from the Nvidia website and stay away from 267.52.
Was £799.99 Inc. VAT
Only £719.99 inc VAT.
ORDER NOW
"Ultima Tyrannosaur" Intel Core i7 2700K 3.50GHz @ 4.80GHz DDR3 Quad Core System @ £1,549.98 inc VAT
The "Ultima Tyrannosaur" is the our Sandybridge flagship system. Named after the fearsome Dinosaur, strike fear into the hearts of your enemies with the ferocious power the "Ultima Tyrannosaur" has to offer. Equipped with the powerful GTX 580 graphics card delivering cinematic DX11 graphics and smashing through even the most demanding of games. The heart of the system is powered by the brand new Intel Core i7 2700K CPU overclocked to a massive 4.80GHz. With 4 cores and hyperthreading you will experience a seamlessly smooth computing experience. A choice of SSDs allows you to increase the speed of your system by ten fold. A massive 1TB Seagate drive brings in the storage for all your films, games and photos. Lay waste to all, with the "Ultima Tyrannosaur".
- A guaranteed 4.80GHz performance for the price of 3.50GHz
- Choose from a selection of graphics cards to meet your performance needs
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Corsair 600TM Case
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 2700K 3.50GHz Sandybridge overclocked to 4.80GHz
- Motherboard: Asus Maximus IV Extreme -Z Intel Z68 (Socket 1155) PCI-Express DDR3 Motherboard
- Cooler: OcUK H2 Flo Extreme Cooler
- RAM: 8GB (2x4GB) DDR3 Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: Nvidia GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card
- Sound: Onboard 7.1 Audio
- Optical Drive: Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black
Service Package
Harness the power of the "Ultima Tyrannosaur" with the all new Intel Sandybridge CPUs and Intel Z68 Chipset. Hunt down your prey with the "Ultima Tyrannosaur" and be the ultimate predator.
Was £1,599.98 Inc. VAT
Only £1,549.98 inc VAT.
ORDER NOW
Asus GeForce GTX 580 Matrix Platinum 1536MB GDDR5 PCI-Express Graphics Card @ £407.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110) (Upto 950MHz core possible)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1632MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Was £419.99 Inc. VAT
Only £407.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 SuperClocked w/Backplate 1536MB GDDR5 PCI-Express Graphics Card @ £383.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 797MHz (Fermi GF110)
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1594MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 10 Years (Requires registration within 30 days with EVGA)
Only £383.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £259.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3 PC Game** @ £185.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
- Supplied with BattleField 3 Full PC Game download voucher!
Was £191.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Power Edition "448 Edition" OC Twin FrozR III 1280MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
Was £239.99 Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 460 Superclocked 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 763MHz
- Processing Cores: 336
- Shader Clock: 1526MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Only £113.99 inc VAT.
ORDER NOW
LG E1951S 18.5" Widescreen LED Monitor - Glossy Black @ £69.59 inc VAT
Clear contrast of light and colour Enables display of Subtle differences. Even now CAN BE observed Blacks, is Considered the most Difficult to visualize the before. Intelligent LED technology saves energy and LG monitors Provides clear and vivid images
Specification:-
- Screen Dimensions: 18.5in
- Screen Type: LED TN 16.7 Million Colours
- Aspect Ratio: 16:9
- HD Support: Yes
- Resolution (Native): 1366 x 768 Pixels
- Brightness: 250cd/m2
- View Angle: 170° (Horizontal - Max) x 160° (Vertical - Max)
- Contrast Ratio: 5,000,000:1 (Dynamic)
- Response time: 5ms
- Anti-Glare / Anti-Static: Anti-glare, 3H
- VGA In: 1 x 15-pin D-sub
- Plug and Play: Yes
- Voltage/Frequency: 100 to 240VAC
- Power Consumption: 17W (Max) / 0.5W (Standby)
- Case Colour: Black
- Dimensions: 44.94cm (W) x 3.35cm (D) x 27.90cm (H) - Weight 1.60kg
- 3yr Warranty
Was £73.99 Inc. VAT
Only £69.59 inc VAT.
ORDER NOW
Dell IN2020N 20" Widescreen LCD Monitor - Black @ £83.99 inc VAT
Enhance your multimedia experience with the IN2020 high-definition monitor with LED. This 20" widescreen display offers brilliantly vivid features at an even more brilliant price.
Highlights of the Dell 20" Wide IN2020N 5ms LED HD
* Enhance your multimedia view
* Environmental footprint
* Convenient comfort
* Great-value performance
Expand your productivity and multimedia performance with this 20" widescreen display, including LED backlight. With its 16:9 aspect ratio, 8,000,000:1 high dynamic contrast ratio and 1600 x 900 high-definition display, the IN2020 is excellent for viewing movies, photos and videos. Plus, you'll never skip a beat by adding the optional multimedia Dell soundbar for an enhanced audio experience.
The IN2020 monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, Energy Star 5.0, to help you lower energy consumption without sacrificing performance.
Convenient comfort
The IN2020 monitor is uniquely designed for comfort, convenience and visual appeal. With tilt adjustability, the IN2020 offers a versatile and comfortable view. The high-gloss slim black bezel complements both your home environment and your Dell desktop or laptop. Simply connect to any standard computer using the VGA connector.
The IN2020 monitor delivers a high dynamic contrast ratio of 8,000,000:1, vivid 1600 x 900 high-definition resolution, a fast response time and VGA connectivity, all at an affordable price.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 1000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 160°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- Dimensions: 453.7mm x 344.0mm x 204.8mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was £89.99 Inc. VAT
ORDER NOW
Iiyama ProLite E2008HDS 20" Widescreen LCD Monitor - Black @ £93.59 inc VAT
The Iiyama E2008HDS-1 20" LCD offers great value for money, and is the ideal screen for Gaming or as a Home Office display. Iiyama’s Opti-Colour Modes ensure high colour performance, supported by an ultra fast 2ms response time and a high 1600x900 resolution. With DVI and VGA connections and Iiyama’s new Power Saving Eco Modes, you are in safe hands with this superb display.
- Contrast Ratio: 30000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 485.0mm x 367.0mm x 193.0mm
- VESA Compliant
- Weight: 4.0kg
- Stereo Speakers
Was £99.98 Inc. VAT
Only £93.59 inc VAT.
ORDER NOW
Dell UltraSharp U2212HM 22" Widescreen LED Monitor - Midnight Grey @ £179.99 inc VAT
See vivid imagery from almost any angle. The 21.5" Dell UltraSharp U2212HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Diagonal Viewable Size: 54.61 cm (21.5 inches (21.5- inch wide viewable image size))
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Preset Display Area ( H x V): 476.57mm x 268.76mm, 18.76" x 10.58"
Contrast Ratio: 1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 250 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut (typical): 82% (CIE 1976)1
Color Depth: 16.7 million colors
Pixel Pitch: 0.2475mm
Backlight Technology:LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D): 365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm,14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight:2.7 kg, 6.0 lbs
Weight (with packaging):6.8kg, 15.0 lbs
Specifications - Service / Support Details
3-Year Advanced Exchange4 Service and Premium Panel Guarantee
Was £194.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Dell ST2220M 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
Take your multimedia viewing experience to another level with the ST2220M full HD monitor with LED. This 54.61cm (21.5") widescreen display is an optimum choice for cinematic quality and makes watching movies, playing games and photo editing an amazing experience.
The new Dell™ ST2220M 54.61cm (21.5") widescreen full HD monitor with LED delivers true cinematic picture quality with a 16:9 aspect ratio and excellent color contrast (estimated dynamic contrast ratio of 8,000,000:1). Give your movies, videos and games the big-screen attention they deserve with clear 1920 x 1080 full HD resolution and true-to-life picture quality. Plus, add the optional Dell multimedia soundbar for even more enhanced audio performance.
With its slim depth and high-gloss front bezel that complements your desktop, the ST2220M is a stylish monitor designed to fit most home environments. Elegant, functional and built for maximum comfort, its tilt-adjustability feature has a panel tilt of 4° forward and 21° backward. You’ll also be amazed by the intuitive touch controls and the beautiful lit bottom front bezel when the monitor is on.
The ST2220M monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, ENERGY STAR 5.0, to help you lower energy consumption without sacrificing performance.
Enjoy the convenience of digital and analog connectivity options. Seamlessly connect the ST2220M to your desktops, laptops and gaming consoles with DVI (HDCP) and VGA analog ports. Cables sold separately.
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 8,000,000:1
- Viewing Angles (H/V): 170°/160°
- Inputs: 1x Analogue, 1x DVI-D
- Weight: 7.65kg
- Warranty: 3 Years Next Day Swap Out Warranty Direct from Dell.
Was £113.99 Inc. VAT
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £131.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
Was £139.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
IIyama Prolite E2274HDS 22" Widescreen LED Business Monitor - Black @ £125.99 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
LED-BACKLIT
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
SPEAKERS
HDMI
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
Specification
Screen Size - 22"
Response Time - 2ms
Height Adustable - No
Rotatable Screen - No
Built in Speakers - Yes
VGA Input - Yes
DVI-D Input - Yes
HDMI Input - Yes
LED Panel - Yes
Was £143.99 Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
Asus PA238Q 23" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £215.99 inc VAT
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA238Q adopts 178degrees of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution. The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want.
Features:-
- Panel Size: Wide Screen 23.0"(58.4cm) 16:9
- Color Saturation : 100%(sRGB)
- Panel Type : IPS
- True Resolution : 1920x1080
- Full HD 1080P : Yes
- Pixel Pitch : 0.2652mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- Display Colors : 16.7M
- LCD ZBD Warranty : Yes
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack (for HDMI & DisplayPort Only)
- USB Port(s) : 1 x upstream, 4 x downstream
- Chassis Colors : Black
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Warranty 3yr On-site
Was £235.99 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black @ £155.99 inc VAT
ProLite X2377HDS - A 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all around panel type. This IPS panel offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2377HDS is full HD, has a 5 000,000:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user clear and vivid images. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The Prolite X2377HDS has two integrated stereo speakers and is VESA mount compatible. It will provide both excellent performance for photographic, design and web-design and is also an excellent choice for Universities, Corporate and Financial Markets, as well as the rapidly expanding demand for Multi Monitor applications.
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- 3yr Warranty
Only £155.99 inc VAT.
ORDER NOW
NVIDIA GeForce 3D Vision 2 New Wireless Glasses & IR Emitter Kit @ £119.99 inc VAT
Discover the difference NVIDIA® 3D Vision™ 2 can make in your PC gaming experience. The new gamer-inspired 3D glasses have 20% larger lenses to give you the most viewing area with the least light leakage. They also work great with the innovative NVIDIA 3D LightBoost™ technology, which makes your screen up to 2x brighter for better 3D gaming and video viewing. Plus, 3D Vision 2 glasses are built from state of the art, softer materials designed to deliver more comfort and better fit.
BETTER PC GAMING
Play over 600 PC games in 3D including the latest titles like Batman: Arkham City, Crysis 2, and L.A. Noire. Enjoy softer composite materials and better fit with gaming headsets. Get best-in-class 2D gaming with ultra-smooth 120 fps gaming on 120Hz monitors
BRIGHTER 3D
Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology. Experience the new external light blocker that minimises the effects of overhead lighting
MORE IMMERSIVE
Try the new 27'' 3D monitors from ASUS and Acer for Full HD 1080p 3D and ghost-free image quality. Experience games more fully with 20% larger 3D lenses for an ultra wide viewing area. Get the most diverse ecosystem of content-including 3D photo sharing and browsing-on 3DVisionLive.com
Was £124.99 Inc. VAT
ORDER NOW
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £155.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 35 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Was £169.99 Inc. VAT
ORDER NOW
Asus PA246Q 24.1" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £407.99 inc VAT
The Most User-friendly P-IPS ProArt Series Professional Monitor, P-IPS panel with 98% Adobe RGB coverage and 178° wide viewing angle. QuickFit Function instantly boost design efficiency by providing real-size document, photo, and grid on screen. Built-in USB hubs and 7-in-1 card reader for instant connection.
PA246Q is equipped with P-IPS panel that provides 98% of Adobe RGB coverage and 1.07 billion colors; 130% more color compare with conventional LCD monitors. Each PA246Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA246Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it. PA246Q's built-in internal 12-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution.
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. The ergonomically-designed PA246Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors. Picture-in-picture multitasking function allows users to view images from different signals. PA246Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with 7-in-1 card reader and two USB 2.0 ports so that users could easily connect PA246Q to any other devices.
Features:-
- Display Panel Size: Wide Screen 24.1"(61.13cm) 16:10
- Color Saturation : 98%(Adobe RGB), 100%(sRGB), 102%(NTSC)
- Panel Type : P-IPS
- True Resolution : 1920x1200
- Pixel Pitch : 0.270mm
- Brightness(Max) : 400 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000:1
- Display Colors : 1073.7M (10bit)
- Color Rich Technology
- SPLENDID Video Preset Modes : 6 Modes (Adobe RGB Mode/sRGB Mode/Scenery Mode/Theater - Mode/Standard Mode/User Mode)
- Color Temperature Selection : 3 Modes
- Color Accuracy : ?E? 5
- Gamma adjustment : Yes (Support Gamma 2.2/1.8 )
- Color Adjustment : 6-axis adjustment(R,G,B,C,M,Y)
- Picture-in-Picture
- HDCP support
- Auto. Adjustment
- Contrast Adjustment
- Input Selection
- QuickFit
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- USB Port(s) : 1 x upstream,2 x downstream
- Card Reader : SD, MS, MS Pro, MS Duo, xD, MMC,SM
- Power Consumption Power ON : < 75W
- Power Saving Mode : < 1W
- Power Off Mode : 0W (hard switch)
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Dimensions Phys. Dimension with Stand(WxHxD) : 558.4 x 380.8 x 235 mm
- Box Dimension (WxHxD) : 683 x 457 x 298 mm
- Weight Net Weight (Esti.) : 7.3 kg
- Gross Weight (Esti.) : 10 kg
- VGA cable
- DisplayPort cable
- Power cord
- USB cable
- Quick start guide
- Support CD
- Warranty Card
- Regulation Approval TCO'03, UL/cUL, CB, CE, ErP, FCC, CCC, TUV-GS, TUV-ERGO, ISO9241-307, BSMI, Gost-R, C-Tick, VCCI, PSB, PSE, J-MOSS, RoHS, Windows 7 WHQL
Was £424.99 Inc. VAT
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
ORDER NOW
IIyama Prolite E2475HDS 24" Widescreen LED Business Monitor - Black @ £149.99 inc VAT
Iiiyama's LED LCD, the E2475HDS is a full HD monitor. Energy Star rated and using less than 1W in power management mode it is good for the environment yet still features the high specification you come to expect from iiyama. The incredible 2msec Response Time and 5 000 000:1 Advanced Contrast Ratio panel ensures vibrant images and blur free Video. The three input configuration of HDMI, DVI and Analogue guarantees compatibility with the flexibility to switch between multiple sources.
- Diagonal: 23.6"
- Panel: TN, LED-Backlit
- Display area: h x w293.2 x 521.3 mm; 11.5" x 20.5"
- Response time: 2 ms
- Contrast: 1000 : 1 typical 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Viewing zone horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCPyes
- 3yr Warranty
Only £149.99 inc VAT.
ORDER NOW
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 3TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £229.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Hitachi Deskstar 5K3000 3TB SATA 6Gb/s 64MB Cache 5900RPM - OEM @ £199.99 inc VAT
The Deskstar™ 5K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 5900 RPM performance in a standard 3.5-inch form factor. The 5K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 5900RPM
- Bootable with Sandybridge P67/H67/Z68 Motherboards
- Warranty: 2 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Was £209.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Toshiba MK5076GSX 500GB 5400RPM SATA-II 8MB Cache - OEM @ £64.99 inc VAT
The MK5076GSX 5,400 RPM, 2.5-inch hard disk drives offers one-half terabyte in capacity with quiet acoustics and enhanced durability, providing a solid storage solution for mobile and stationary PCs, game consoles, printers, external storage devices as well as set top boxes, personal video recorders and surveillance systems.
- 2.5"
- 500GB of Storage Capacity
- 5,400 RPM Spin Speed
- Serial ATA 3.0 Gbps and Extended SATA Features
- Light-weight, Standard 9.5 mm-High Design
- Super-quiet Seek Technology
- Eco-Conscious and Low Power Design
Was £89.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Samsung SpinPoint M7 500GB 5400RPM SATA-II 8MB Cache - OEM (HM500JI) @ £84.98 inc VAT
The Spinpoint M7 utilizes Samsung’s proprietary SilentSeek and NoiseGuard technologies to minimize noise-levels during drive operation. The new M7 drive offers a shock resistance level of 400G (2ms) in operation mode and 900G (1ms) when the power is off. An optimized system-on-chip controller reduces the power consumption in both seek and idle modes to the lowest level among comparable drives.
- Capacity: 500GB
- Cache: 8MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 12.0ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £71.99 inc VAT
nonl2brAs the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
<br><br>
- Capacity: 60GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 525MB/sec<br>
- Maximum Write: 475MB/sec<br>
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- Warranty: 3 Years<br>
<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/rF5PdfFGomw" frameborder="0" allowfullscreen></iframe>
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £67.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 Years
Was £80.99 Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
OCZ Vertex 3 60GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-60G) @ £89.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br><br>
- Maximum Read: 535MB/sec<br>
- Maximum Write: 480MB/sec<br>
- Sustained Write: 455MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/CKMODN3kIpE" frameborder="0" allowfullscreen></iframe>
Was £99.98 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
OCZ Synapse Cache 64GB SATA-3 Solid State Hard Drive (SYN-25SAT3-64G) @ £103.99 inc VAT
OCZ Synapse Cache Solid State Drives accelerate workstation and desktop computing applications with an innovative hardware-meets-software design and advanced caching feature-set.
The OCZ Synapse Series integrates the benefits of SSD performance and HDD capacity with Dataplex™ caching software to dynamically manage the use of both SSD and HDD for superior overall storage performance. This combination creates an environment where the most frequently used "hot" data stays on the ultra-fast SSD, while the "cold" data remains on the larger capacity HDD (sold separately). Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user, maximizing productivity for the most demanded programs and applications. Synapse Series integrates seamlessly within any modern PC platform, ensuring optimal compatibility along with performance gains.
High Performance SSD Architecture
- Maximizes performance with SATA 6 Gb/s interface
- Unleashes the full potential of today’s leading platforms
- OS/application bootable with TRIM support
- Easy-to-deploy 2.5” solution for multiple drive bays
Integrated Dataplex™ Caching Software
- Intelligently manages HDD and SSD simultaneously
- “Hot” data managed on Synapse SSD for highest performance, access, and bandwidth
- “Cold” data routed to HDD for highest capacity usage
- No data migration or OS installation required
- Delivers up to 80,000 IOPS
- Bandwidth up to 550 MB/s
- Usable SSD capacity up to 32GB on 64GB Model
- Manages and accelerates full HDD capacity
Was £119.99 Inc. VAT
Only £103.99 inc VAT.
ORDER NOW
OCZ Agility 3 240GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-240G) @ £259.99 inc VAT
<br><br>
- Capacity: 240GB<br>
- Maximum Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 45,000 IOPS (4KB File)<br>
<br>
<br>
Was £289.99 Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
OCZ Octane 128GB 2.5" SATA-3 Solid State Hard Drive (OCT1-25SAT3-128G) @ £152.99 inc VAT
nonl2brCombining high-speed data transfer rates with record-breaking access times, OCZ Octane SSDs are designed to provide a superior user experience and improved application performance. Octane leverages the cutting-edge Indilinx Everest platform and is optimized for the complete spectrum of file types and sizes, with proprietary page mapping algorithms mirroring real world conditions across a wide range of applications. The Octane series also includes advanced features unique to Indilinx, including latency reduction technology to enhance system responsiveness and enable instant-on boot-ups. Octane SSDs also deliver the energy efficiency, durability, and reliability that traditional hard drives cannot provide.<br>
<br><br>
- Capacity: 128GB<br>
- Controller: Indilinx Everest<br>
- Maximum Write: 170MB/sec<br>
- Max I/O Per Second (IOPS): 37000 IOPS (4KB File)<br>
- 2.5" to 3.5" SSD adaptor included<br>
<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/Ct2mt3wTXms" frameborder="0" allowfullscreen></iframe>
Was £155.99 Inc. VAT
Only £152.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £158.99 inc VAT
<br>
- Capacity: 120GB<br>
- Maximum Read: 550MB/sec<br>
- Sustained Write: 500MB/sec<br>
<br>
Was £172.99 Inc. VAT
Only £158.99 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £349.99 inc VAT
- Maximum Write: 520MB/sec<br>
- Sustained Write: 520MB/sec<br>
<br>
Was £379.99 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
OCZ Synapse Cache 128GB SATA-3 Solid State Hard Drive (SYN-25SAT3-128G) @ £169.99 inc VAT
- Usable SSD capacity up to 64GB on 128GB Model
Only £169.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 120GB PCI-E SSD - (RVD3-FHPX4-120G) @ £299.99 inc VAT
The OCZ RevoDrive 3 PCI-Express Solid State Drive Series was designed with power users and multimedia designers in mind and gives enthusiasts the cutting-edge storage they crave. Eliminating the SATA bottleneck, the PCIe-based Revo3 delivers ground-breaking 1GB/s of bandwidth and 130,000 4KB random write IOPS making this an ideal SSD for high performance applications, multimedia, and workstations. Along with unprecedented performance, the Revo3 features OCZ’s proprietary Virtualized Controller Architecture (VCA) 2.0 which provides features including TRIM support and SMART data monitoring, something previously unheard of with PCIe solutions. In addition, the Revo3’s SuperScale storage accelerator enables scalable SSD performance and significantly reduces the host CPU burden inherent to competing PCIe storage offerings. The RevoDrive 3 series is a premium feature rich storage solution that delivers superior performance and reliability through innovative design.
- Capacity: 120GB
- Controller: Dual SandForce SF-2281 (RAID)
- Maximum Read: 975MB/sec
- Maximum Write: 875MB/sec
- Max I/O Per Second (IOPS): 130,000 IOPS (4KB File)
- Interface: PCI-Express x4
- Warranty: 3 Years
Was £323.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 240GB PCI-E SSD - (RVD3-FHPX4-240G) @ £439.99 inc VAT
- Capacity: 240GB
- Maximum Read: 1000MB/sec
- Maximum Write: 900MB/sec
- Warranty: 3 Years
Was £479.99 Inc. VAT
Only £439.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 480GB PCI-E SSD - (RVD3-FHPX4-480G) ** PRE-ORDER** @ £1,139.99 inc VAT
- Capacity: 480GB
- Maximum Write: 925MB/sec
- Warranty: 3 Years
NOTE
** All RevoDrive3/RevoDrive3 X2 will be ordered on receipt of purchase. **
** Allow 5-10 working days for delivery **
Released Mid July
Was £1,199.99 Inc. VAT
Only £1,139.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 X2 240GB PCI-E SSD - (RVD3X2-FHPX4-240G) @ £539.99 inc VAT
The OCZ RevoDrive 3 X2 PCI-Express Solid State Drive Series was designed with power users and multimedia designers in mind and gives enthusiasts the cutting-edge storage they crave. Eliminating the SATA bottleneck, the PCIe-based Revo3 X2 delivers ground-breaking 1.5GB/s of bandwidth and 230,000 4KB random write IOPS making this an ideal SSD for high performance applications, multimedia, and workstations. Along with unprecedented performance, the Revo3 X2 features OCZ’ proprietary Virtualized Controller Architecture (VCA) 2.0 which provides features including TRIM support and SMART data monitoring, something previously unheard of with PCIe solutions. In addition, the Revo3 X2’s SuperScale storage accelerator enables scalable SSD performance and significantly reduces the host CPU burden inherent to competing PCIe storage offerings. The RevoDrive 3 X2 series is a premium feature rich storage solution that delivers superior performance and reliability through innovative design.
- Capacity: 240GB
- Controller: Quad SandForce SF-2281 (RAID)
- Maximum Read: 1500MB/sec
- Maximum Write: 1250MB/sec
- Max I/O Per Second (IOPS): 230,000 IOPS (4KB File)
- Warranty: 3 Years
Was £569.99 Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 X2 480GB PCI-E SSD - (RVD3X2-FHPX4-480G) @ £1,289.99 inc VAT
- Capacity: 480GB
- Warranty: 3 Years
Was £1,349.99 Inc. VAT
Only £1,289.99 inc VAT.
ORDER NOW
OCZ RevoDrive HYBRID 1TB PCI-E SSD Hard Drive - (RVDHY-FH-1T) @ £374.99 inc VAT
nonl2brUnique Hybrid Storage Solution for Performance and Value<br>
<br>
OCZ RevoDrive Hybrid is the next step in the evolution of storage technology for power users, multimedia designers and game enthusiasts. The PCI-ebased RevoDrive Hybrid not only eliminates the SATA bottleneck to unleash groundbreaking bandwidth and landmark IOPS performance, but it also includes a high-capacity harddisk drive and intelligent software that integrates SSD and HDD into a single high-performance and high-capacity storage solution. <br>
<br>
The OCZ RevoDrive Hybrid comes bundled with intelligent caching software that dynamically manages the use of the SSD with the 1TB HDD for superior overall storage performance. The most frequently/recentlyused “hot” data stays on the ultra-fast SSD while “cold” data remains on the slower but larger capacity disk. Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user. Welcome to the next generation storage from OCZ Technology.<br>
<br>
Highest Performing Hybrid Drive on the Market!<br>
- Completecaching solution on a single card<br>
- SSD performance withoutsacrificing a low cost per gigabyte<br>
- Delivering an exceptional all-in-one solution for power users, multimedia designers, and computing enthusiasts<br>
<br>
OCZ SuperScale Storage Accelerator<br>
- Facilitates scalable performance for intensive workloads<br>
- Unique complex command queuing structure (CCQS) with queue balancing algorithms (QBA)<br>
- Higher performance and reduced burden on the host CPU<br>
<br>
OCZ Virtualized Controller Architecture<br>
- VCA 2.0 presents as a complete storage subsystem for superior data management<br>
- Only virtualization layer in the industry with TRIM and SCSI unmapsupport<br>
- Enables SMART monitoring for system administrators<br>
<br>
Intelligent Caching Software<br>
- Simultaneously manages HDD and SSD, learning individual user behavior to adapt storage policies<br>
- “Hot” data managed on Synapse SSD for highest performance, access, and bandwidth<br>
- “Cold” data routed to HDD for highest capacity usage<br>
<br>
<br>
- Capacity: 1TB total storage with 2 x Sandforce 2281 based drives (100GB) acting as cache<br>
- Nand: 25nm MLC<br>
- Storage: 1TB 5400rpm HDD<br>
- Weight: 289g<br>
- Interface: PCI-Express Gen. 2 x4<br>
- MAX Read: up to 910MB/s<br>
- MAX Write: up to 810MB/s<br>
- MAX 4KB Random Write: 120,000 IOPS (475MB/s)<br>
- Sequential Read: up to 290MB/s<br>
- Sequential Write: up to 130MB/s<br>
- 4KB Random Write: 32,000 IOPS (120MB/s)<br>
- Product: RevoDrive Hybrid<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/jEhid7qFWBk" frameborder="0" allowfullscreen></iframe>
Was £399.98 Inc. VAT
Only £374.99 inc VAT.
ORDER NOW
Acoustic Energy Aego M 2.1 Speaker System - White @ £118.99 inc VAT
The Aego M-System builds on the strengths of the award winning Aego 2, offering a pair of heavy-alloy satellite speakers and a compact subwoofer for a full range sound that embodies AE’s sound quality principles. The sleekly styled satellites have smoother treble and a funky rounded design while potent amplifiers are built into the subwoofer to drive all three loudspeakers. The package gives room-filling sound from devices like the iPod™, PSP™ or MP3 mobile phones. With just one cable the M-System turns any personal music device into the heart of a home entertainment system. In the living room, in the bedroom, away at college or simply for a spontaneous party, the M-System delivers a big sound form the smallest devices. Better still, the M-System’s gorgeous looks, high quality sound and plug and play simplicity won’t cost a fortune as it remains just as affordable as the best selling AE Aego 2.
- Easy to setup and use
- Hi-fidelity, high volume sound
- Instant home entertainment
- Big hi-fi sound from the smallest devices
- Outstanding value for money
- Inputs: 3 x RCA Phono - Line level, 1 x Stereo Mini jack - Line level
- Outputs: 3 x Speaker terminals
- Controls: 1 x Volume / Power pot, 1 x Bass switch (3 Position), 1 x Centre input switch (2 Position)
- Power ratings: 120V Model - 120V @ 60Hz; 80VA, 240V Model - 240V @ 50Hz; 80VA, 90 Watts RMS total system power rating
- Frequency response: Sub is 50Hz-250Hz and the satellites are 250Hz-16KHz
- Dimensions: Sub Woofer - 265 x 190 x 350mm, Satellites - 68mm x 103mm x 90mm
- Weight: 9 Kg
Was £123.98 Inc. VAT
Only £118.99 inc VAT.
ORDER NOW
Asus Xonar D2 7.1 PCI Sound Card @ £86.99 inc VAT
ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- Unprecedented SNR Up to 118db reaching the limit of PC sound clarity
- High-definition audio processing at 192KHz/24Bit for all Input and outputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theatre System
Was £89.99 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Asus Xonar D2X 7.1 PCI-E Sound Card @ £83.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Was £88.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £18.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
**Supplied with Driver disk, Manual, Low profile PCI bracket and Xonar DG card - All thats missing is the box!**
Was £20.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium 7.1 Sound Card - OEM (30SB088200000) @ £56.99 inc VAT
Creative's Sound Blaster X-Fi Titanium is the essential audio upgrade for maximum PC gaming and entertainment. Whether you use Windows XP or Vista, its PCI Express design guarantees total compatibility, plus hardware-accelerated EAX 5.0 and OpenAL support for maximum gaming performance. With X-Fi CMSS-3D for accurate and immersive 3D positional audio even over headphones, this card will give you the edge over the competition! THX certified, it also features onboard Optical I/O and real-time Dolby Digital encoding for single cable connectivity to your surround sound decoder. The supplied PowerDVD software works with X-Fi technology to let you play Dolby and DTS movies in incredible surround sound over headphones or speakers.
- Sound Blaster X-Fi PCI Express chipset is designed for the latest PCs.
- Hardware-accelerated EAX 5.0 and OpenAL gaming for ultra-realistic cinematic in-game audio. Creative ALchemy software restores EAX surround sound to Windows XP games under Windows Vista.
- Delivers accurate and immersive X-Fi CMSS-3D surround sound over headphones for on-line or late-night gaming sessions.
- On-board optical I/O with Dolby Digital real-time encoding, for single cable connection to your surround sound decoder.
- UAA (Universal Audio Architecture) design ensures maximum compatibility under Windows Vista.
Was £67.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Creative Inspire T10 2.0 Speaker System (51MF1600AA001) @ £26.99 inc VAT
Creative Inspire T10 speakers give a high-quality performance of all your digital music. Compact and sleek, in glossy black, they combine advanced engineering with good looks to deliver better audio with your PC, notebook or MP3 player. They create a true ‘Hi-Fi' sound stage, using separate tweeters for high-end perfection, precision drivers for accurate mid-tones and BasXPort technology for strong lows without a subwoofer. Separate controls for volume and bass enable you to optimise playback with any kind of music, and you can position Inspire T10s close to PC monitors and TV screens thanks to their magnetic shielding. They include a headphone socket for private listening.
- Elegant 2.0 design with separate 1-inch tweeter and 3-inch mid-range drivers in each satellite for improved highs and mid-tones.
- BasXPort feature in each satellite adds strong bass to complete the sound stage, without requiring a separate subwoofer.
- Separate tone and volume/power controls enable output to be adjusted to suit personal taste.
- Can be connected to MP3 players as well as PCs and notebooks. Headphone port for private listening.
- Magnetic shielding enables speakers to be positioned close to PC monitors, notebooks and other equipment.
Was £32.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Creative Inspire A520 5.1 Speaker System (51MF4110AA008) @ £39.98 inc VAT
Give your games, music and movies a much-needed boost with the Creative A520 5.1 speaker system. Given their contemporary style and ease of use, they are the perfect choice for immersive multi-channel surround sound, bringing to you all the benefits of Creative’s leadership in audio technology. The five satellites make use of the two-inch drivers for crisp dialogue and impressive effects, while the large subwoofer with a flared port tube and separate bass control provides you with the freedom to adjust your bass level and deliver the extra impact and oomph for all of your entertainment needs. The system also includes a wired remote for easy-to-reach and convenient control.
- Speaker Power: 5Watts RMS per channel (5 channels)
- Subwoofer: 12Watts RMS
- Frequency Response: 40Hz ~ 20kHz
- Signal-to-Noise Ratio (SNR): 75dB
- Product Weight: 3.5 kg
- Dimensions (HxWxD): Speaker (144x80x104)mm, Subwoofer (235x192x192) mm
Was £49.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Hitachi Deskstar 7K3000 2TB SATA 6Gb/s 64MB Cache 7200RPM - OEM (0F12115) (HDS723020BLA642) @ £169.99 inc VAT
The 7K3000 is the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB Cache Buffer delivers a big boost to performance over the previous generation product.
The Deskstar 7K3000 is designed to allow users to leverage the benefits of the latest components and operating systems to deliver high-performance, high-capacity, power-efficient systems.
- 2TB
- 64MB Cache
- 7200 RPM performance
- 6Gb/s SATA interface for improved performance over previous generation product
- Eco-friendly, Halogen-free design
- Designed to leverage new platforms and modern operating systems
Was £199.99 Inc. VAT
ORDER NOW
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) @ £104.99 inc VAT
The F3 operates at 7200RPM with offerings of up to 1TB data storage capacity by using two 500GB per platter disks. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 1TB
- Cache: 32MB
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £104.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £94.99 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 1TB
- Cache: 32MB
- Warranty: 2 Years
Was £109.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Western Digital VelociRaptor 600GB 10000RPM SATA 6Gb/s 32MB Cache - OEM (WD6000HLHX) @ £204.98 inc VAT
WD VelociRaptor hard drives offer twice the capacity of the previous generation while delivering higher performance and cool quiet operation for gaming, workstations, and low-end servers. With a superbly engineered combination of 10,000 RPM spin speed, SATA 6Gb/s interface and a 32MB cache, these drives are truly an evolution in performance. The IcePack mounting frame encloses the 2.5" WD VelociRaptor in a backplane-ready 3.5" enterprise-class mounting frame with a built-in heatsink that keeps this powerful little drive extra cool when installed in high-performance desktop chassis.
- Capacity: 600GB
- Cache: 32MB
- Spin Speed: 10000RPM
- Seek Time: 3.6ms
- Warranty: 5 Years
Was £249.98 Inc. VAT
Only £204.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 500GB SATA 6Gb/s 32MB Cache - OEM (WD5002AALX) @ £99.98 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 32MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it.
- Capacity: 500GB
- Cache: 32MB
- Warranty: 5 Year
Was £111.98 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) @ £69.98 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) @ £84.98 inc VAT
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
ORDER NOW
Samsung SpinPoint F4 320GB SATA-II 16MB Cache - OEM (HD322GJ) @ £76.99 inc VAT
The Spinpoint F4 features 7200rpm speed rotation, advanced areal density technology and a SATA 3.0 Gbps interface. Equipped with Samsung's exclusive dynamic balancing technology, the drive's overall stability and reliability is optimized as a high performing solution. Samsung's proprietary SilentSeek and NoiseGuard technologies are incorporated in the drive to offer ultra quiet operation. With a one-head platform design and fewer mechanical parts, the reliability and acoustic features of the Spinpoint F4 have been improved. The drive delivers 10% increased read/write performance and 7% lower power consumption than the Spinpoint F1. The superior performance and high-reliability Spinpoint F4 is engineered for high-end computing in PCs, Macs, high-end workstations and server applications.
- Capacity: 320GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £83.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
Samsung SpinPoint F3 250GB SATA-II 16MB Cache - OEM (HD253GJ) @ £69.98 inc VAT
The F3 operates at 7200RPM with offerings 250MB data storage capacity. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 250GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £77.99 Inc. VAT
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £163.99 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Only £163.99 inc VAT.
ORDER NOW
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £122.99 inc VAT
<br><br>
<br>
<br>
Was £129.98 Inc. VAT
Only £122.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £249.98 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £269.99 Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £124.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Was £149.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £99.98 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £161.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £251.99 inc VAT
- SR0DG MALAY Stepping
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
Was £265.99 Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £839.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.30GHz (3.90GHz TURBO)
- Multiplier: 33x (Unlocked Multiplier)
- L2 Cache: 6x 256KB
- L3 Cache: 15MB
- TDP: 130W
- DOES NOT INCLUDE COOLER
- 3yr Warranty
Was £851.99 Inc. VAT
Only £839.99 inc VAT.
ORDER NOW
AMD Athlon II X3 Tri Core 455 3.30GHz (Socket AM3) - Retail @ £65.99 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Tri Core Technology
- 3.30GHz Clock Speed
- AM3 Socket
- 3x 512KB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £71.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail @ £89.99 inc VAT
We call it the new AMD FX 4-Core Processor Black Edition and it's unlocked for your overclocking pleasure. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Quad Core Technology
- 3.60GHz Clock Speed
- 3.80GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 4MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 95W
- Voltage: 0.925v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- 3 Year Warranty
Was £94.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £29.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/12GX) @ £53.99 inc VAT
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Capacity: 6GB (4GBx3)
Type: 240-pin DIMM
Warranty: Lifetime
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £59.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-10-9-27 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) @ £40.79 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £44.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (KHX1600C9D3K4/16GX) @ £65.99 inc VAT
Kingston proudly introduces HyperX DDR3 memory, the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2.
This dual/quad-channel HyperX memory kit is Intel XMP-Certified, and runs at a latency timing of 9-9-9-27 at 1.50-1.60V operating voltage for Intel dual/quad-channel Sandy Bridge P67, X79 or Z68 platforms.
Model Name: KHX1600C9D3K4/16GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67, INTEL X79
Capacity: 16GB (4GBx4)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Warranty: Lifetime
Was £74.99 Inc. VAT
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £23.99 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was £25.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 900MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 3 Years
Was £299.99 Inc. VAT
Only £287.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £224.99 Inc. VAT
ORDER NOW
Titan Decimator MKII Intel Core i7 980 3.33GHz @ 4.00GHz DDR3 Hex Core System @ £1,023.97 inc VAT
Harnessing the power of the Intel Core i7 980 Six core CPU. With six processing cores and triple channel DDR3 memory the "Titan Decimator MKII" provides an excellent basis for a workstation, gaming and home cinema system, with power to spare. With a choice of the latest DX11 graphics, the "Titan Decimator MKII" is proven performer.
Why You Should Buy This System
- True DX11 gaming performance available from a choice of compatible graphics cards
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- SATA 6GB/s and USB 3.0 for next gen computing
System Specification
- Case: BitFenix Shinobi Case - Black
- Power Supply: OCZ ZS 550w PSU
- CPU: Intel Core i7 980 3.33GHz @ 4.00GHz
- Motherboard: Gigabyte G1 Guerilla Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: OcUK H2 Flo Extreme
- RAM: 6GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Choice of the latest DX11 Graphics cards
- Sound: Realtek Creative 7.1 Gaming Audio (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
For when nothing but pure power is required, the "Titan Decimator MKII" has it by the bucket load.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £1,073.96 Inc. VAT
Only £1,023.97 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Dirt 3 PC Game** @ £199.99 inc VAT
- Core Clock: 800MHz
- Memory Clock: 5000MHz (Effective)
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with Dirt 3 Download coupon
ORDER NOW
"Titan Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Quad Core System @ £523.98 inc VAT
Strong, resolute, powerful, the "Titan Triceratop" the natural enemy of the T-Rex. Providing immense graphical power and CPU processing speed. The "Titan Triceratop" has a ludicrous 4.40GHz overclock, which enables you to power through the latest games and applications. Own your game with the "Titan Triceratop"!
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Coolermaster Elite 334 Case - Black
- Power Supply: OCZ ZS 650w PSU
- CPU: Intel Core i5 2500K 3.30GHz Sandybridge overclocked to 4.40GHz
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Xigmatek Red Scorpion CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Sound: Realtek 7.1 Channel Sound (On-Board)
Service Package
Powerful and reliable. The two qualities you need to get you through your game, the "Titan Triceratops" lauches you into the next generation of computing.
Was £559.98 Inc. VAT
Only £523.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £119.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 3 Years
Was £127.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6870 OC 1024MB GDDR5 PCI-Express Graphics Card @ £143.99 inc VAT
Immerse yourself with AMD Eyefinity technology and expand your games across multiple displays. Experience ultra-realistic visuals and explosive HD gaming performance in true ?EyeDefinition with AMD’s second generation graphics featuring full Microsoft DirectX® 11 support. Enable incredible video quality and enhanced application performance with AMD EyeSpeed visual acceleration technology.Get unrivalled graphics. Get Radeon™ in your system.
- Core Clock: 920MHz
- Memory Clock: 4200MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Only £143.99 inc VAT.
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card **Lowest Price DX11 Graphics Card in UK** @ £23.99 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Core Clock: 650MHz
- Memory: 512MB GDDR3
- Memory Interface: 64-Bit
- Memory Clock: 1066MHz (Effective)
- Processing Cores: 80
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was £25.99 Inc. VAT
ORDER NOW
MSI GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card @ £719.99 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 2yr Warranty
IMPORTANT: The supplied Geforce Drivers 267.52 for Geforce GTX 590 will not stop the card from overheating when overclocking. Please use newer versions from the Nvidia website and stay away from 267.52.
Was £799.99 Inc. VAT
Only £719.99 inc VAT.
ORDER NOW
"Ultima Tyrannosaur" Intel Core i7 2700K 3.50GHz @ 4.80GHz DDR3 Quad Core System @ £1,549.98 inc VAT
The "Ultima Tyrannosaur" is the our Sandybridge flagship system. Named after the fearsome Dinosaur, strike fear into the hearts of your enemies with the ferocious power the "Ultima Tyrannosaur" has to offer. Equipped with the powerful GTX 580 graphics card delivering cinematic DX11 graphics and smashing through even the most demanding of games. The heart of the system is powered by the brand new Intel Core i7 2700K CPU overclocked to a massive 4.80GHz. With 4 cores and hyperthreading you will experience a seamlessly smooth computing experience. A choice of SSDs allows you to increase the speed of your system by ten fold. A massive 1TB Seagate drive brings in the storage for all your films, games and photos. Lay waste to all, with the "Ultima Tyrannosaur".
- A guaranteed 4.80GHz performance for the price of 3.50GHz
- Choose from a selection of graphics cards to meet your performance needs
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Corsair 600TM Case
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 2700K 3.50GHz Sandybridge overclocked to 4.80GHz
- Motherboard: Asus Maximus IV Extreme -Z Intel Z68 (Socket 1155) PCI-Express DDR3 Motherboard
- Cooler: OcUK H2 Flo Extreme Cooler
- RAM: 8GB (2x4GB) DDR3 Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: Nvidia GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card
- Sound: Onboard 7.1 Audio
- Optical Drive: Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black
Service Package
Harness the power of the "Ultima Tyrannosaur" with the all new Intel Sandybridge CPUs and Intel Z68 Chipset. Hunt down your prey with the "Ultima Tyrannosaur" and be the ultimate predator.
Was £1,599.98 Inc. VAT
Only £1,549.98 inc VAT.
ORDER NOW
Asus GeForce GTX 580 Matrix Platinum 1536MB GDDR5 PCI-Express Graphics Card @ £407.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110) (Upto 950MHz core possible)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1632MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Was £419.99 Inc. VAT
Only £407.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 SuperClocked w/Backplate 1536MB GDDR5 PCI-Express Graphics Card @ £383.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 797MHz (Fermi GF110)
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1594MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 10 Years (Requires registration within 30 days with EVGA)
Only £383.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £259.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3 PC Game** @ £185.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
- Supplied with BattleField 3 Full PC Game download voucher!
Was £191.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Power Edition "448 Edition" OC Twin FrozR III 1280MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
Was £239.99 Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 460 Superclocked 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 763MHz
- Processing Cores: 336
- Shader Clock: 1526MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Only £113.99 inc VAT.
ORDER NOW
LG E1951S 18.5" Widescreen LED Monitor - Glossy Black @ £69.59 inc VAT
Clear contrast of light and colour Enables display of Subtle differences. Even now CAN BE observed Blacks, is Considered the most Difficult to visualize the before. Intelligent LED technology saves energy and LG monitors Provides clear and vivid images
Specification:-
- Screen Dimensions: 18.5in
- Screen Type: LED TN 16.7 Million Colours
- Aspect Ratio: 16:9
- HD Support: Yes
- Resolution (Native): 1366 x 768 Pixels
- Brightness: 250cd/m2
- View Angle: 170° (Horizontal - Max) x 160° (Vertical - Max)
- Contrast Ratio: 5,000,000:1 (Dynamic)
- Response time: 5ms
- Anti-Glare / Anti-Static: Anti-glare, 3H
- VGA In: 1 x 15-pin D-sub
- Plug and Play: Yes
- Voltage/Frequency: 100 to 240VAC
- Power Consumption: 17W (Max) / 0.5W (Standby)
- Case Colour: Black
- Dimensions: 44.94cm (W) x 3.35cm (D) x 27.90cm (H) - Weight 1.60kg
- 3yr Warranty
Was £73.99 Inc. VAT
Only £69.59 inc VAT.
ORDER NOW
Dell IN2020N 20" Widescreen LCD Monitor - Black @ £83.99 inc VAT
Enhance your multimedia experience with the IN2020 high-definition monitor with LED. This 20" widescreen display offers brilliantly vivid features at an even more brilliant price.
Highlights of the Dell 20" Wide IN2020N 5ms LED HD
* Enhance your multimedia view
* Environmental footprint
* Convenient comfort
* Great-value performance
Expand your productivity and multimedia performance with this 20" widescreen display, including LED backlight. With its 16:9 aspect ratio, 8,000,000:1 high dynamic contrast ratio and 1600 x 900 high-definition display, the IN2020 is excellent for viewing movies, photos and videos. Plus, you'll never skip a beat by adding the optional multimedia Dell soundbar for an enhanced audio experience.
The IN2020 monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, Energy Star 5.0, to help you lower energy consumption without sacrificing performance.
Convenient comfort
The IN2020 monitor is uniquely designed for comfort, convenience and visual appeal. With tilt adjustability, the IN2020 offers a versatile and comfortable view. The high-gloss slim black bezel complements both your home environment and your Dell desktop or laptop. Simply connect to any standard computer using the VGA connector.
The IN2020 monitor delivers a high dynamic contrast ratio of 8,000,000:1, vivid 1600 x 900 high-definition resolution, a fast response time and VGA connectivity, all at an affordable price.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 1000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 160°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- Dimensions: 453.7mm x 344.0mm x 204.8mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was £89.99 Inc. VAT
ORDER NOW
Iiyama ProLite E2008HDS 20" Widescreen LCD Monitor - Black @ £93.59 inc VAT
The Iiyama E2008HDS-1 20" LCD offers great value for money, and is the ideal screen for Gaming or as a Home Office display. Iiyama’s Opti-Colour Modes ensure high colour performance, supported by an ultra fast 2ms response time and a high 1600x900 resolution. With DVI and VGA connections and Iiyama’s new Power Saving Eco Modes, you are in safe hands with this superb display.
- Contrast Ratio: 30000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 485.0mm x 367.0mm x 193.0mm
- VESA Compliant
- Weight: 4.0kg
- Stereo Speakers
Was £99.98 Inc. VAT
Only £93.59 inc VAT.
ORDER NOW
Dell UltraSharp U2212HM 22" Widescreen LED Monitor - Midnight Grey @ £179.99 inc VAT
See vivid imagery from almost any angle. The 21.5" Dell UltraSharp U2212HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Diagonal Viewable Size: 54.61 cm (21.5 inches (21.5- inch wide viewable image size))
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Preset Display Area ( H x V): 476.57mm x 268.76mm, 18.76" x 10.58"
Contrast Ratio: 1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 250 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut (typical): 82% (CIE 1976)1
Color Depth: 16.7 million colors
Pixel Pitch: 0.2475mm
Backlight Technology:LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D): 365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm,14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight:2.7 kg, 6.0 lbs
Weight (with packaging):6.8kg, 15.0 lbs
Specifications - Service / Support Details
3-Year Advanced Exchange4 Service and Premium Panel Guarantee
Was £194.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Dell ST2220M 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
Take your multimedia viewing experience to another level with the ST2220M full HD monitor with LED. This 54.61cm (21.5") widescreen display is an optimum choice for cinematic quality and makes watching movies, playing games and photo editing an amazing experience.
The new Dell™ ST2220M 54.61cm (21.5") widescreen full HD monitor with LED delivers true cinematic picture quality with a 16:9 aspect ratio and excellent color contrast (estimated dynamic contrast ratio of 8,000,000:1). Give your movies, videos and games the big-screen attention they deserve with clear 1920 x 1080 full HD resolution and true-to-life picture quality. Plus, add the optional Dell multimedia soundbar for even more enhanced audio performance.
With its slim depth and high-gloss front bezel that complements your desktop, the ST2220M is a stylish monitor designed to fit most home environments. Elegant, functional and built for maximum comfort, its tilt-adjustability feature has a panel tilt of 4° forward and 21° backward. You’ll also be amazed by the intuitive touch controls and the beautiful lit bottom front bezel when the monitor is on.
The ST2220M monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, ENERGY STAR 5.0, to help you lower energy consumption without sacrificing performance.
Enjoy the convenience of digital and analog connectivity options. Seamlessly connect the ST2220M to your desktops, laptops and gaming consoles with DVI (HDCP) and VGA analog ports. Cables sold separately.
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 8,000,000:1
- Viewing Angles (H/V): 170°/160°
- Inputs: 1x Analogue, 1x DVI-D
- Weight: 7.65kg
- Warranty: 3 Years Next Day Swap Out Warranty Direct from Dell.
Was £113.99 Inc. VAT
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £131.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
Was £139.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
IIyama Prolite E2274HDS 22" Widescreen LED Business Monitor - Black @ £125.99 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
LED-BACKLIT
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
SPEAKERS
HDMI
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
Specification
Screen Size - 22"
Response Time - 2ms
Height Adustable - No
Rotatable Screen - No
Built in Speakers - Yes
VGA Input - Yes
DVI-D Input - Yes
HDMI Input - Yes
LED Panel - Yes
Was £143.99 Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
Asus PA238Q 23" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £215.99 inc VAT
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA238Q adopts 178degrees of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution. The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want.
Features:-
- Panel Size: Wide Screen 23.0"(58.4cm) 16:9
- Color Saturation : 100%(sRGB)
- Panel Type : IPS
- True Resolution : 1920x1080
- Full HD 1080P : Yes
- Pixel Pitch : 0.2652mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- Display Colors : 16.7M
- LCD ZBD Warranty : Yes
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack (for HDMI & DisplayPort Only)
- USB Port(s) : 1 x upstream, 4 x downstream
- Chassis Colors : Black
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Warranty 3yr On-site
Was £235.99 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black @ £155.99 inc VAT
ProLite X2377HDS - A 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all around panel type. This IPS panel offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2377HDS is full HD, has a 5 000,000:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user clear and vivid images. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The Prolite X2377HDS has two integrated stereo speakers and is VESA mount compatible. It will provide both excellent performance for photographic, design and web-design and is also an excellent choice for Universities, Corporate and Financial Markets, as well as the rapidly expanding demand for Multi Monitor applications.
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- 3yr Warranty
Only £155.99 inc VAT.
ORDER NOW
NVIDIA GeForce 3D Vision 2 New Wireless Glasses & IR Emitter Kit @ £119.99 inc VAT
Discover the difference NVIDIA® 3D Vision™ 2 can make in your PC gaming experience. The new gamer-inspired 3D glasses have 20% larger lenses to give you the most viewing area with the least light leakage. They also work great with the innovative NVIDIA 3D LightBoost™ technology, which makes your screen up to 2x brighter for better 3D gaming and video viewing. Plus, 3D Vision 2 glasses are built from state of the art, softer materials designed to deliver more comfort and better fit.
BETTER PC GAMING
Play over 600 PC games in 3D including the latest titles like Batman: Arkham City, Crysis 2, and L.A. Noire. Enjoy softer composite materials and better fit with gaming headsets. Get best-in-class 2D gaming with ultra-smooth 120 fps gaming on 120Hz monitors
BRIGHTER 3D
Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology. Experience the new external light blocker that minimises the effects of overhead lighting
MORE IMMERSIVE
Try the new 27'' 3D monitors from ASUS and Acer for Full HD 1080p 3D and ghost-free image quality. Experience games more fully with 20% larger 3D lenses for an ultra wide viewing area. Get the most diverse ecosystem of content-including 3D photo sharing and browsing-on 3DVisionLive.com
Was £124.99 Inc. VAT
ORDER NOW
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £155.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 35 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Was £169.99 Inc. VAT
ORDER NOW
Asus PA246Q 24.1" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £407.99 inc VAT
The Most User-friendly P-IPS ProArt Series Professional Monitor, P-IPS panel with 98% Adobe RGB coverage and 178° wide viewing angle. QuickFit Function instantly boost design efficiency by providing real-size document, photo, and grid on screen. Built-in USB hubs and 7-in-1 card reader for instant connection.
PA246Q is equipped with P-IPS panel that provides 98% of Adobe RGB coverage and 1.07 billion colors; 130% more color compare with conventional LCD monitors. Each PA246Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA246Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it. PA246Q's built-in internal 12-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution.
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. The ergonomically-designed PA246Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors. Picture-in-picture multitasking function allows users to view images from different signals. PA246Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with 7-in-1 card reader and two USB 2.0 ports so that users could easily connect PA246Q to any other devices.
Features:-
- Display Panel Size: Wide Screen 24.1"(61.13cm) 16:10
- Color Saturation : 98%(Adobe RGB), 100%(sRGB), 102%(NTSC)
- Panel Type : P-IPS
- True Resolution : 1920x1200
- Pixel Pitch : 0.270mm
- Brightness(Max) : 400 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000:1
- Display Colors : 1073.7M (10bit)
- Color Rich Technology
- SPLENDID Video Preset Modes : 6 Modes (Adobe RGB Mode/sRGB Mode/Scenery Mode/Theater - Mode/Standard Mode/User Mode)
- Color Temperature Selection : 3 Modes
- Color Accuracy : ?E? 5
- Gamma adjustment : Yes (Support Gamma 2.2/1.8 )
- Color Adjustment : 6-axis adjustment(R,G,B,C,M,Y)
- Picture-in-Picture
- HDCP support
- Auto. Adjustment
- Contrast Adjustment
- Input Selection
- QuickFit
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- USB Port(s) : 1 x upstream,2 x downstream
- Card Reader : SD, MS, MS Pro, MS Duo, xD, MMC,SM
- Power Consumption Power ON : < 75W
- Power Saving Mode : < 1W
- Power Off Mode : 0W (hard switch)
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Dimensions Phys. Dimension with Stand(WxHxD) : 558.4 x 380.8 x 235 mm
- Box Dimension (WxHxD) : 683 x 457 x 298 mm
- Weight Net Weight (Esti.) : 7.3 kg
- Gross Weight (Esti.) : 10 kg
- VGA cable
- DisplayPort cable
- Power cord
- USB cable
- Quick start guide
- Support CD
- Warranty Card
- Regulation Approval TCO'03, UL/cUL, CB, CE, ErP, FCC, CCC, TUV-GS, TUV-ERGO, ISO9241-307, BSMI, Gost-R, C-Tick, VCCI, PSB, PSE, J-MOSS, RoHS, Windows 7 WHQL
Was £424.99 Inc. VAT
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
ORDER NOW
IIyama Prolite E2475HDS 24" Widescreen LED Business Monitor - Black @ £149.99 inc VAT
Iiiyama's LED LCD, the E2475HDS is a full HD monitor. Energy Star rated and using less than 1W in power management mode it is good for the environment yet still features the high specification you come to expect from iiyama. The incredible 2msec Response Time and 5 000 000:1 Advanced Contrast Ratio panel ensures vibrant images and blur free Video. The three input configuration of HDMI, DVI and Analogue guarantees compatibility with the flexibility to switch between multiple sources.
- Diagonal: 23.6"
- Panel: TN, LED-Backlit
- Display area: h x w293.2 x 521.3 mm; 11.5" x 20.5"
- Response time: 2 ms
- Contrast: 1000 : 1 typical 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Viewing zone horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCPyes
- 3yr Warranty
Only £149.99 inc VAT.
ORDER NOW
