Hello there,
I am currently looking for a new graphics card and figured I would come to these forums with my questions. I am from austria and my budget for a new graphics card would be around 300€.
First of all, I'd like to say that I prefer Nvidia over AMD, so please do not recommend an AMD that maybe is even better for a cheaper price.
I currently have a GTS 250 512mb and think that its time for me to upgrade.
I am looking at a Model of the GTX 560 Ti Ultracharged Edition with the following specs at 285€:
2048 MB GDDR5, active Cooling
PCI-E 2.0 16x, 2x DVI (Dual Link), mini-HDMI
GPU Clock: 910MHz; Memory Clock: 4008MHz; 256Bit
Stream-Processors: 384; Shader Clock: 1820MHz
Shader Model 5.0, DirectX 11.0, PhysX, SLI-ready
and a GTX 570 with the following specs at 300€:
1280 MB GDDR5, active Cooling
PCI-E 2.0 16x, 2x DVI (Dual Link), HDMI, DP
GPU Clock: 732MHz; Memory Clock: 3800MHz; 320Bit
Stream-Processors: 480; Shader Clock: 1464MHz
Which one would you recommend me?
The rest of my systems specs are:
CPU: Intel Core2Quad Q9450 @2,66Ghz
RAM: 4GB DDR2
Power supply: 750W
I am also looking forward to upgrade my mainboard, CPU and RAM during the next year, but for now the graphics card has to go first.
The reason for this upgrade now is, that I am getting bf3 and the beta left me unimpressed with my current setup. I simply want to boost the graphics a bit. My desired resolution would be 1680x1050 and I am not planning on getting a new monitor with FullHD resolution, incase that matters for any of these graphic cards.
Thanks in advance and have a nice day
-0cube
RAM: 4GB DDR2
Power supply: 750W
-0cube
