OLD style EK supreme HF
31 May 2006
West London
After breaking a promise to my self about never buying a plexi top block.
I as with many others, got the EK supreme HF, nickle plexi version.
I got this before EK changed the shape to the square top.
And no surprise durring my current build log I fractured the top.
Long story short - after looking everywhere (not many HF in this shape where made)
EK found an old box of stock and I sourced a replacement Acetal top.
Happy days I thought - and QC make swapping out blocks really easy
Also worth noting EK send new button heads and seals :cool:
But all was not well on closer inspection...RMA time
Back to air cooling untill I can fully flush the loop.
On the up side with my D5@5 I have a home brew Mayhems Aurora
Link to video - that's not air it's silver and/or nickle!
The thing is, I was using metal primochill ghost fitting.
They don't even have a spanner socket - just a thumb turn Knurling.
How I over tighten them I'll never know (might be the smaller stock O ring - Hmmmm, will have a think about that)
Generally, what I found that as long as you have it as tight as your thumb can twist without it hurting, then you'll be fine :)
@Biffa - soooo many tiny particals in my coolant at the minute - will take an age to flush :(
Just as well really most were just passing through the block without issue
The more I read around the more I think it's the O ring.
With it being so much smaller, see image below - it's more squashy.
Never had a leak with the barbs and the thin o ring is by design according to primochill.
But if the barb base and block top are not perfectly alined and/or flat, when you screw it down, with just a thin extra squashy buffer between them...
It's very easy to see how thumb tight may be to tight and cause locallised stress fractures.
From left to right - EK HF, Dtek HF, Primochill ghost
Well that's my thoughs on it anyway, still needs an RMA for the nickel issue :(
Glad EK extended the deadline
the nickel issue is really something that can be sorted quickly. good to see EK are responding well to the problem still.
I still haven't got EN blocks and my nickel is still fine, must have been lucky.
i see that issue with plexi all the time. doesnt happen with comp fittings as you tighten them by hand, but barbs usually get overtightened with spanners so it is inevitable.
I am liking acetal at the moment anyway, looks sleeker imho. and my cpu block has a copper top so that aint gonna break :p
Heh, thats what he said.
:eek:
Don't you have older blocks (before they changed the nickel plating process?)
:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
hush cleeecooo
we all know of your fetish for nickel plexi. :p
my supreme HF is an old, non EN one and my 590 block is an older one from before the nickel issue reared its head.
