I went from 1.5gb to 3gb, I got an upto 30fps extra out of it!.
The only reason I got it as I am Planning to get another 2 monitors.
The game I noticed the biggest increase on compared to a 580 1.5gb model (yes, I've owned both and can prove it via OcUK receipts lol) was crysis 2 with the dx11 patch at 1920x1080. It verges on unplayable after the first level when you get deeper into the city and some of the later parts where indeed unplayable. The 3gb model though has around 55fps for literally 95% of the time and only dips when theres tonnes going on at once. My 1.5gb couldn't hack it at all.
I had reported 1.8gb vram usage for reference on the 3gb model![]()
It has been confirmed that BF3 uses less then 1.5Gb even on ultra settings at 1920 x 1080. Link below.
http://translate.google.co.uk/trans...artikel/14650-prestandaanalys-battlefield-3/1
I can confirm it too on 1920 x 1200 on all ultra settings it does not use the full 1.5Gb memory on a GTX 580.
hmm i tested myself 1.5gb vs 3gb on crysis 2, i don't see any differences between these two 580 gtx, and about 1.8gb, the 3gb eats more vram than it needs it called memory leak![]()
Hmz, I am not convinced how accurate these VRAM usage meters are.
Me neither. That's why I have a brilliant VRAM meter in my house.
It's called - my eyes.
GTX 470 1.2gb didn't have enough.
From MY testing 3GB is a waste of time on a 580 in 99% of the time.
The 580 architecture can not make use of it !
Our friend is dreaming with his figuresa 580 3Gb will not run High res Crysis 2 @1920x1200 maxed out......It would not even hold vsync 25fps (if You could set it)
Save Your money for the new stuff![]()
