- 14 Dec 2011
- England - Doncaster
Hi guys firstly I know nothing about compatibility and technical jargon that you guys use.. well very limited... which is embarrassing as i've got a b-tech in I.t and also a 2:1 degree in i.t and business hahaha.
Firstly i have the Corsair sp2500 2.1 gaming speakers... so i want a sound-card that can bring out the full potential of these speakers.
My GPU at the moment is - nividia geforce 9600 GT ( i would like to use this in the new build but i doubt its compatible with a completely different card using SLI?)
I have a spare 1gb ram stick though its DDR2 so i doubt im going to be using it in the new build.
Anyway.... I'm looking to spend around 500 - 700 on this new build. I'm wanting to be able to play Skyrim on the best possible graphics so i guess that will give you an idea of the spec I'm looking for.
My pc will mainly be a gaming machine.
I'm still debating whether or not i want a water cooling system and mods to make it look awesome and personalised, so Ive not considered this in the build's cost.
Could you guys give me some hardware choices n costings(with short explanation as to why it would be suited for me). as well as links to modding,cases etc that i can ahve a look at.
p.s i create beats and so on, and music is a big part of my everyday usage of th ecomputer.. so any idea of a certain operating system or software that can customize my pc into a proper media centre.
Thanks, i appreciate
your time and effort put into answering this post
