My passenger window will not go up with one press, drivers side will though!
I have the opposite problem in the Ibiza. The cupholder is directly in front of the air vent, so if I have a cold drink with the heating on, it becomes pretty warm pretty quickly. Not to mention that the cupholder itself is cheap, plastic-y and currently broken.[TW]Fox;20817433 said:The mind numbingly stupid position of the air temp sensor for the climate control in the E39 and, staggeringly, the F10 5 Series.
I don't know of any cars that do
I don't know of any cars that do, It's a safety feature, I think
Talking about headlights, on the 206, I pretty much have to remove the front grill to change a buld, the front grill holds the lights in place it is possible to get your hand behind the light to change a bulb, but its just easier to remove the grill and remove the light, plus you don't slice your hands up
Mk3 Mondeo springs to mind
206 bulbs are incredibly easy![]()
The rear ones are but not the headlights aren't, the whole car is just a cheese grater for hands lol
E46 central locking is just ridiculous, sometimes the doors open, others not, common problem apparently.
Worst one I've seen by a mile has to be in my dads MX5.
The centre section has a compartment with a sliding lid about 1cm short than a credit card, so you can fit a card in there but it won't lay flat. If you put a card in there and shut the lid, the hook on the lock grabs onto the card and it's stuck. You then have to choose between dismantling the interior and destroying your cards pulling them out with pliers![]()
The whole subframe has to come down to do the gearbox.
Citroen C4 you have to remove the windscreen wipers and the brake fluid reservoir to replace the air filter
Stupid Manufacturer Designs - the lack of space given to allow the changing of headlamp bulbs on a MK6 Fiesta![]()
It is directly behind the cupholder. Put a hot drink in the cupholder and all the temp sensor reads is hot air from the drink. It then pumps cold air into the cabin. I popped through the McDonalds drivethru last night, stuck the coke in the cupholder and within about 40 seconds the climate control was blasting out roasting hot air.
Sigh.
You'd think they'd have learned. The E60 didnt do it as the cupholders were in the dash rather than the centre console, but they are back in the centre console in the F10.. right in the same place once again.
MX-5 rear light clusters - you have to remove the entire thing to get to the bulbs, there is no hatch. Why?!
