Yes he did. Here is an image of his facial injuries, which may in fact have been taken some time after the incident:
http://i.imgur.com/q40Ut.jpg[img][/QUOTE]
:rolleyes: If he was thrown and [I]landed [/I] on his face, as you claim, then he would have significantly worse injuries than a scrape. There is no bruising in the photo either, which indicates to me he sustained it by falling or friction against the floor.
[quote="Al Vallario, post: 20820271"]The point is that, with the level of force used, and the manner in which it was applied, he could easily have had his neck broken. That is patently unreasonable.[/QUOTE]
You really are over-exaggerating the incident now. You could break your neck falling off a pavement.
[quote="Al Vallario, post: 20820271"]Train conductors are granted the legal authority to use reasonable force to remove passengers from trains, and you will [i]never[/i] find a conductor removing someone from a train in the manner and with such force as 'big man' did in this instance, precisely because it was totally unreasonable.[/QUOTE]
In the claims culture of late, you'd probably find most companies would opt to "phone it in" or be faced with some BS claim of assault either way. This incident involves one member of public, forcing another member of the public off a train because he was fare-dodging, so that's moot.
