- 19 Oct 2002
- Shakespeare’s County
AC doesnt work below 5C as otherwise the condensation can freeze on the evaporator core and block cabin fresh airflow and ice may deform/break the fins.
[TW]Fox;20827462 said:He is a Ford tech, you are an internet knowitall![]()
No he said he used to be a Ford tech![]()
CLUTCH CYCLING SWITCH
Switch used to control evaporator core temperature either by system pressure or an electrical sensing bulb. Clutch cycling switch controls electrical current to the compressor clutch preventing the evaporator core from freezing during operation
The compressor will cycle for the following reasons:
Ambient temperature low, refrigerant pressure low as a result of low ambient temp.
Ambient temp high, cabin temp low, evaporator exchanges little cooling because cabin is already cool.
Ambient temp warm to high, fan set on low, same reason as #2.
Ambient temperature high, cabin temperature high, system charge low.
No temperature sensor here
I use de-icer in the windscreen washer bottle. Few squirts and my windscreen is clear.![]()
Could we see the keys to verify this please?
or
It's been recovered and key were left in the ignition, how do you explain this?
Ni-on all the cars I have driven (which is LOTS) the air has never worked at below 4c /end please.
Yes you can. that was on the later models with the electric motor control for the heater flap. My car is an early one with the cable control for the heater flap.[TW]Fox;20827161 said:No you can't. Once you move the switch to windscreen you can't switch the AC off. It automatically illuminates the AC light to indicate it is using (or attempting to but with no effect if its really cold outside) the air conditioning.
Surely everyone with a Mk2 Mondeo knows this, we used to get people asking about it on a weekly basis when I was into Mondeos, people seem confused by it (Its the only car I've driven that does this, to be fair).
So what about thewhich has ultimate control over the compressor clutch solenoid? Does that not have a temperature sensor connected to it?
Not if you've got warm air running over it from the heater matrix when the car has warmed up a bit & you've set the heater to wrk with warm air + a/c. Before you say 'the cars warmed up and the a/c will work now', my a/c compressor will still operate from stone cold .
If the compressor is on, the a/c is on.
