Spec me...
Megapixels aren't everything hyburnate :p
Obviously, but you can't really change anything on a phone :( Apart from turning the flash on and off :p#
I forget to ask, how do you do them awfully great images with the lights staying, turning down the shutter speed?
Yeah, you watercool your compact, and ill put it up against my d50, let's see who wins :p
And this thread is pretty much done now anyway :p
atleast i'll be taking pics in style whilst you'll be looking like a tramp :p:D
Doesn't mean we should spam it :/
(i'll stop now until some watercooling questions come up!)
Red? :o You sir have a job though. The best thing is I had the money in change :/ Which now means I need to put stupid amounts of money in my bank :(
Does anyone fancy writing a complete guide on how to clean the rad and blocks?
Blocks, no need
Rads, flush with hot water a few times and them one last time with deionised.
No red fluid, just green and blue :D
Actually, one bottle of red :D
Who says I have a job?:p
Ahhha. That from the HAFX? So I guess I put it in the outlet, screw the things back on. Swish it around. Take out the metal parts, take it out. Surely 1L should be ok. I don't know how much 1L is and I'm doing Additional Maths :facepalm:
So what I'm doing is, unpacking the case putting stuff in there, make sure it boots up ok.
Open the rad up, pour some hot tap water in and swish it round 3 times. Put some special water in swish it around and leave it for about 3 mins. Then check for leaks in the rad with special water.
Then connect up all the tubing, turn it on moving the pump and system around getting the air out, power off and connect up the main board etc and turn the system off, keep a eye out for leaks for a further 12 hours, but I would have thought with the moving about it would have come off it was going too by then.
Then :cool:
Oh I forgot to say I'll fill the res up with special water and leave it in the loop for 20mins, then somehow drain the loop. Help?!?!?!? Turn the pump off and empty the res? :S Then fill up with liquid? Or is doing a loop with special water not needed
