Potentially stupid question about grounding yourself?
10 Apr 2008
If you live in a non-ground floor flat, can you still ground yourself in all the usual ways (e.g. touching metal heating pipes, touching your case with the PSU plugged in)?
It is a stupid question really :p Does your plumbing not eventually reach ground just because you don't live on a ground floor flat? No!
Yes you can.
Its not a stupid question at all. We all have to learn somewhere.
Some people on here really need to get their head out of their backside and respect others who want to learn.
Yes you can.
Agreed. We can all learn from each other. That's what it's all about. Asking and learning.
No such thing as a silly question.... only a silly answer (Ban hammer) being one of them :P
hmmm, people have told me before that I need to keep the mains powered on, and turn off the PSU or adaptor to have it grounded.
Does grounding work through the PC case if the PSU is plugged in, but the mains is switched off?
The way I used to do it.
Now I don't bother at all. I've not fried any computers in the past 3 years for certain with static. (I've touched inside and built close to 600-700).
I really think the whole static thing can be a bit over the top. Unless your wearing a wooly jumper and scratching a balloon on your head. Chances are your fine and don't need to bother.
Yeas static isn't really a problem... just like in a previous job when a few dozen line cards in a system started dying about 6 months after install. ;) The guy who installed it got a kicking as he'd been seen handling all the boards without an antistatic strap.
Static damage is not always immediately apparent, and if you're handling expensive components, it's not worth taking the risk. As the poster above says: "chances are...", but would you want to take a chance on a £300 GPU? :p
Yes if the plug is plugged in. It does not require any electricity to be grounded :p
Correct. The metal body of the PSU (and thus the case) will be connected to mains earth, as long as the mains plug is in the back of the PC and it is plugged into a mains socket. The PC needn't be powered on. The mains switch doesn't have to be on either if you have a switched socket as earth wires are always unswitched.
Make sure you touch a 'bare metal' part of the case though. Quite often a PC case will be coated, so not so good for grounding.
The point is to be at the same voltage (equipotential) as the pc components. There's no need to earth yourself or the pc. just make good contact with the pc case. :)
I wouldn't listen to this guy unless you may want your components failing in a few years.
ESD damage is usually long term damage rather than short term.
If the equipotential is different from your computer to you own, the balance is off as soon as you touch anything there will be ESD.
Well. Like I said. Theory is one thing... actual practice is another. I've never had anything fail or been brought back to me with failed parts. Unless of course it takes more than three years for ESD damage to kick in?
Like I said... It's never caused me any concerns. It's all a bit overhyped. Obviously it's wise to take precautions but it can get silly.
For e.g. I always handle components by the edges and don't put my fingers over everything and touch gold connections. Common sense really does prevail.
No such thing as a stupid question, chances are many other folk are wondering the same but don't pluck up the courage to ask. The question made for 19 posts an interesting thread and I learnt a bit along the way, I rest my case.
