- 28 Oct 2003
- Worthington-on-sea
Focus. Drivers window has a 'one touch to lower feature' but not the same to close it. Pointless & lazy design.
Aprilia RSV1000R
Rear brake master cylinder that is located just above the clutch bell-housing. A great place for keeping the fluid cool. I've yet to ride one of these with a working rear brake.
RSV's have a rear brake?.![]()
A couple from me:
Rover 75
The entire car, meh that's prob taking it a bit too far, the worst part is probably that if you don't clean the leaves out regularly then the foot-wells will flood with stinking water, that kind of sucks.
Water pumps on timing belts. Stats behind timing belts. Slave cylinders inside boxes.
No, they have a pedal, a disc, a caliper and some hoses. However the design on the RSV could never be described as a brake.
The coin tray on the right hand side in the Integra
Oh my god, the clips that hold it in place are the worst thing known to man
Ford Focus Mk2
Head Unit AUX connection
INSIDE the glovebox! For the love of God why??!
Power Steering Pump Hose Connections
Crappy design of power steering pump and hoses which leads to hoses coming loose, showering engine bay in PAS fluid leaving owner requiring new pump, hoses, fluid and Cam and Auxiliary belts. Not once but twice now.![]()
I've heard of the hose issue, is it really widespread?
My guess would be to stop you playing with it whilst driving because it's "dangerous". Also potentially deters thieves as they can't see the iPod you left lying in your centre tray.Head Unit AUX connection
Personally I would much prefer that to the sticking-out-the-front of my cheap headunit as the cable sometimes gets in the way of the gearstick. >.>
