From the sound of it you like to throw money at problems. That's great, but none of your setups (providing you had them new) would have been weak enough even when Crossfire wasn't working well to leave you with any major headaches.
I read reviews on CF 5770 and it seemed too good to be true. Wait, these £250 GPUs can actually beat a 5870 that costs £50 more? and by quite a margin too? SIGN ME UP !!!!oneone.
And then the reality of it dawned on me. When it didn't work (hint - often) I did not have enough muscle to do what I wanted my games to do. Which was annoying at the best of times, and swear worthy the rest.
I stuck it out for the best part of 11 months. You? it seems to me that your setups cost many many hundreds of pounds. Your 5970s alone are man enough to take care of any game in the world when running alone, so chances are you are simply eradicating the issue by throwing money at it.
His scenario (and mine when I used it) is the same.
Unless you go by the name of Merlin then I don't know how you can put up with Quadfire. Been there last year for a laugh (£80 for a pair of 3870x2) and it was absolutely bloody horrible.
The 570 has enough VRAM!!!
msiafterburner says bf3 uses 1.8gb vram in bf3 at 1920x1080 and im running a evga 570 2560mb. Standard 570 is very limited![]()
Been using 2560x1600 since 2006, relying on a single gpu is out of the question.
I get 1.6GB
You can get it under 1gb if you turn all the crap off![]()
Akasa Venom Strike, should be big enough i hope
Yeah that makes sense.
I'd have nothing to do with SLI if it wasn't for the fact I want to run surround.
6970 Lightning, great card but is it £70 better than a 6950?
@ALXAndy, I enjoy phys-x but can't use it right now due to having my 3 slot coolers, so when I'm bored of BF3, I'l be going single 6950>70 +9800gt GenL hack
Yo. Yes and no.
No, SLI drivers are much better, and EVGA do a patch thing of their own so it usually works.
Thing is mate, you ain't going to circumvent the caveat, and that is that the 570 doesn't have enough vram. Adding another doesn't add any more ram. It just makes the cores rip games to shreds. However, if you ain't got the vram you need you're in trouble..
I run quad SLI GTX 295s. Acceptable vram limits? these things go bezerk. Give them Battlefield 3? they crap out. Absolutely useless.
So that leaves you (if you want to be safe) with the 2.5gb 570, 6970 2gb (may as well get the Porsche like Lightning as it's cheap and comes with games) or a 3gb 580 which is overkill.
And out of the 3 the 6970L is the cheapest..
Ed. I refuse to turn AA off. You end up with a game console and the flickering of the jagged edges gives me a headache. I recently bought a 360. I played Fallout : New Vegas for 35 mins before feeling rather ill.
The PC is, but im at work.I spy Eve online Final8y![]()
