Hi all, i have the white 600T (not that the colour makes any difference) and i want to watercool my system. upgrading from a coolIT vantage ALC which has a nice display but is very loud and not that cold. I want to start with a 240mm rad just for my cpu and will upgrade to a pair of 240mm rads in top and front for including gpu, when i can afford.
(to avoid confusion, when i say 240mm i mean 2x120mm)
I have no real experience of modding a case, and the only powertool i own is a dremel, great for cutting put not drilling. I want to mount my first 240mm rad in the front and get rid of the noisy fan that is currently sitting there and wondered if anybody had successfully done this using something like a conversion bracket or something? I know other side rads are available but all the best fans are 120mm so i would prefer to stay with those standard sizes.
Be great to hear some opinions on this, as i may just sell my 600T and buy a better case for watercooling if it is going to be too difficult.
Thanks
Thanks
