I hoped this woul dbe an easy upgrade !!!!
My PC originally came with Vista, then I upgraded to 7.....So I assume me I'll need to do the Vista install and then run the upgrade to 7?
was the version of vista that came originally with your pc an oem or retail version?
just bung it in, upgrade a few drivers and carry on as if nothing has happened
You will need to reinstall but don't worry if it was an OEM version. Just follow these instructions:
http://www.winsupersite.com/article/windows-7/clean-install-windows-7-with-upgrade-media
No idea if that is legal or not but it would be an immoral law which forced you to install vista only to upgrade to 7.![]()
If it's OEM, would the product key not be on a sticker on the side of the case; or do they not do that anymore?I'd assume so. Also was the version of vista that came originally with your pc an oem or retail version? if it's oem then technically it's tied to the original motherboard, meaning you'd have to contact microsoft and spin them a line to get a new activation key. not quite sure how the upgade malarkey works so you'd be better waiting for someone with a bit more knowhow to confirm. or post and ask in the 'software' > 'windows' forum
here
http://forums.overclockers.co.uk/forumdisplay.php?f=9
