16, 32 or 64G iPhone 4S ???
14 May 2007
London
What do you think guys?
I don't store loads of videos and music tracks. I was thinking of going the 32G option. Is it really worth going up to the 64G? Do apps use loads of storage?
Looking at the three deal too for £35 pm. looks a good offer.
K
32 would be more than sufficient, mine is 32gb and think ive got over 20gb free, my ipad is 32gb too, in the past had loads of apps on, and thousands of music and then, only then I came near to filling it. 16gb would even do if you dont do hundreds and hundreds of useless apps.
If you are using it as a gaming device as well as a media player you'll want the 32 at least. Personally, I went for the 64, as it isn't that much more expensive compared to the 32 (what's £100 when you are already spending £600?).
To be honest, I'd go for the 32 anyway. 16 seems to be pushing it for most to be honest.
64GB is definitely overkill just or apps. 16GB is fine for now for all but the heaviest gamers - but who knows how big games will get in the future. Apart from games and sat nav, apps don't tend to take up much space.
Got the 64gb myself using the same logic of just paying £100 more.
Defo dont use anywhere near that and I have loads of crap apps on that I dont even use, still havent even got round to putting loads of media on anyway so would definitely say 32gb or even 16 but that would be pushing it!
16Gb is MORE than enough.
Not for everyone. I have the 16GB iP4 and it's quite limiting. I've had to cut down on my music because many apps take quite a lot of space these days, especially games. Real Racing alone uses over 1GB of space. I wish I bought the 32.
Its important to remember than its not 16 gig, its more like 14. Same as 32 is more like 28.
Once you've loaded up 20 or more albums, apps which some of are almost a gig themselves. photos, few videos before you even start shooting your own you'll find yourself on the edge of capacity with 16gig. Ive had 5 iPhone models and 3 of them were 16 gig. On the iPhone 4 it wasn't enough. my 32gig iPhone 4S is loads better.
Apps, no music or video - 16GB.
I've got over 20GB of music on my iPhone as it was replacing an existing iPod. The Apps total 4GB and that includes Sat Nav with European Maps.
I had a 16GB iPhone 4 before and I do download a lot of apps and have about 5GB of songs so sometimes I would have to delete apps to make space.
Which is why I definitely went for a 32GB this time for my iPhone 4S. Now I never have to worry about space.
I have 16GB on my 3GS and it can get tight with a lot of music on there. I'd rather have 32GB. However, I can't ever imagine a need for 64GB and the price for 64GB is ludicrous.
Used to have a 16Gb iPhone 3G but I struggled to keep to the limit once I started putting videos, photos and music on there. Without all that though 16GB would be fine. Went for 32GB with the iPhone 4 and found it much more suitable.
