The ones in the bottom left are probably the best to give access toCircled the ones I could see here, obviously there might be closer ones that aren't uncovered though..
.The ones in the bottom left are probably the best to give access toCircled the ones I could see here, obviously there might be closer ones that aren't uncovered though..
We've got some within the boundaries too, someone built their house on one![]()
Nah, I think they built their own floating island and used the donation mushroom grass stuff![]()
If you extend the map just on only two sides to get the closest of those you'll be nearly doubling the size of the map.
I think someone with a lot of time on their hands should load the seed in SP and check if there's one closer in the undiscovered lands.Oh. Boo.
Are Mooshrooms part of the animal spawn tickets?![]()
Armour is a lot stronger than it used to be, and mobs hit a lot harder (and take more dmg) than they used to. I guess it goes hand in hand.
Well when you're down a mine with not a lot of food, it can be useful!Pah, Armour....with regenerating health and an abundance of food I just don't see the need in using it.
Also after you've stockpiled a chests worth of iron blocks you kinda think.. I might as well use this stuff![]()
How far out were the mushroom biomes? I am tempted to extend things slightly as a one off.
