5400rpm fan controller
2.69A starting current and 1.1A running current suggests that it'll melt your motherboard if you do try and hook it up to the fan header.
You'll need a fan controller that can cope with that starting current really but you'd probably find one rated at over 15W per channel could probably cope.
Some of the Lamptron controllers are great for high powered fans. 20-30w per channel depending on model.
Still can't believe you are getting one of these :p
Just to put the noise in to context, I work with some drilling equipment that is only a shade louder (according to db(A) rating) than these fans. Hell even the 180mm fans on welding inverters are only something in the region of 45db(A).
You may want to measure the overall noise of your system once its in, afaik hearing protection must be worn over 85db(A) :D
Ive done similair with my 470's, albeit with a normal 120mm fan. Now using an antec spotcool behind them. 70c max in game with custom gpu fan profile.
