Flashing object in the Sky - Stoke.
12 Dec 2005
I've just looked outside and their is an object very high in the sky that was flashing like a beacon every second or so. It is perfectly still and it's been their for about 10 mins. Can anyone else in stoke notice this?
Wowzers!! you saw a beacon!? I don't believe you!
Sir, I am a leader in Alien detection and elimination. One must not believe this object is innocent, we have had credible sources in the past tell us that they have been abducted. You must batten down the hatch, arm yourself and if they approach you, open fire on them.
Probably the planet Venus twinkling near the west. It appears after sunset (can be seen sometimes in daylight too). It is the third brightest object in the sky...not usually very high up mind as its usually close to the Sun.
For some idiots in this thread... When did I once say I thought it was Aliens? I'm just curious as to what the OBJECT could be.
Flashing light, hovering.
Helicopter, I don't see why you needed to ask.
As for high up. You can't possibly tell that. You have no idea what it is and can't see what it is and have no perspective.
