Advice - Building a small yet powerfull PC
would 250w psu be enough to power this setup?
I have been looking at a case that doesn't come with a psu.
Do I need a mini itx psu or does any psu fit the mini itx cases?
I will put a thread up of my step by step build, if that's the thing to do here?
Just want to clear this up before I start ordering.
Also I might go for this CPU instead
Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
I will be buying all my parts from the overclockers shop.
Ok.
I have tweaked my setup a little.
Asus P8H67-M EVO Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) ** B3 REVISION ** Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Nexus Value-430 430W True Power Compact PSU
Reckon this combination will work well?
Wanted a quite psu so went for the nexus
Ok.
What happened to the Llano? Plan on using a dedicated graphics card to get round the FPS issue Intel have?
