- 1 Jun 2010
- Bedford
I think if the 7970 was priced at £350, it will sell like hot cakes (not gonne happen though
Yea...took them a year before they could overtake the GTX580.AMD aren't playing catch up, the 7970 is the fastest GPU currently available, and it beats the GTX 580 in everything.
Indeed. Very good decision indeed.My decision to crossfire my 6950 was a good one.
It's priced higher because its faster than the GTX 580. Why WOULDN'T they price it higher? Do you think AMD is a charity? Do you think that the 28nm process is maxed out with 7970?Yea...took them a year before they could overtake the GTX580.
As mentioned by other people above- moving onto 28nm process and still only on average 8-10% faster, and at a higher price. So basically bang for bucks wise it is harder better than the GTX580, considering people have to pay the extra money for those extra speed.
Also, do bare in mind GTX580 was selling at as low as £320~£340 at one point...and how much is 7970 going to cost again? Something like around £400~£500? Very poor value if you ask me, for the 8-10% extra speed.
People that bought the GTX580 early and been using it all these time are the clear winners.
You are clearing missing my point! I'm not saying AMD should price the 7970 as low as the GTX580...I was merely pointing out they are not really better bang for bucks than the GTX580. Take a chill-pillIt's priced higher because its faster than the GTX 580. Why WOULDN'T they price it higher? Do you think AMD is a charity? Do you think that the 28nm process is maxed out with 7970?
3GB GTX 580 (and beats it in everything) are also winners.![]()
It does not beat it in everything even a 1.5GB GTX 580 beats it in some benchmarks, check the reviews mate and check the reviews with 1920 x 1200 or 1920 x 1080, you will see the 7970 is not the fastest in everything.
What we are saying is anyone with a GTX 580 can forget this release and wait for the next top end cards from either AMD or Nvidia. Otherwise you are throwing money into an empty pit for a max 8%-10% boost at the more common HD resolutions.
This release is really good for people with single 58xx series AMD cards and lower, people with crossfire 68xx/69xx or SLI 560 Ti's and higher dual card setups they need to forget this release too if they are happy with their dual card setups.
Using AMD's Overdrive utility, we pushed the card up to 1,125MHz core speed and 1,575MHz memory speed, which saw our Crysis 2 test leap up to a huge 57.3fps - even faster than the HD 6990's 53fps. The card sounded like it was going to take off when running at these speeds, though.
Price £420
