first time overclocking my q6600
Yer.. fire up prime or intel burntest to stability stress it.. temps seem a little on the low side for that cooler particularly with a Q6600 at 3.6Ghz, also what are you using to measure temps?
just been play a few games and watching coretemp,at 3.6 vcore was 1.4v so i lowed it to 1.3750 but crashed straight away so put the cpu at 3.4 temps are around 45 idle now,not shaw that putting 1.4v was too much for it.
You're not conclusively stable yet. Not a 100% guarantee but usually 24hrs prime and say 50 runs (i do 200) of intel burn test/LINX is a fairly good indicator of stability. 1.4v is fine, if cooling is adequate, though i suspect you might shut your PC off quickly when you see LINX or prime starting to drive those temps up with that cooler :p
Ideally, you need to load it with the likes of prime/intel burn test. 1.4 vcore is fine on a q6600. Tbh, on the old q6600 i had, the freezer pro only allowed me to get to 3.4ghz, (74c under prime load, 1.3750 vcore). Swapped it out for a Thermalright ultra extreme. This allowed me to reach 3.6ghz, then 3.8ghz prime stable. The freezer is a good little budget cooler, but it will struggle with a q6600 under heavy load.
just tryed intel burn test at 3.4 crashed straight away temps were above 81c,put it back to 3ghz with stock volts and settings its very happy wont go over 3ghz with out upping the volts but intel burn test did complete with out crashing i think i need a better cooler.
3.0ghz on stock is practically a given. To go higher your going to need a more beefier cooling solution. If budget is a concern, you really cant go wrong with the Thermalright ultra extreme. They can be had pretty cheaply secondhand. A great cooler to pair with a q6600.
What were you using to get it to a max of 71C before? The likes of Intel Burn Test,etc do tend to stress the cpu more than "normal use". However most would agree that it's the safest bet on ensuring an oc is both stable and within an accepted temperature.
Just to chuck in further complication to the mix, my Q6600 technically won't do 3ghz at stock volts (vid 1.25v) more than likely due to the vdroop on my motherboard (GA-P35C-DS3R) being approximately 0.1v. It's fine however on 1.3v (1.2v after vdroop).
I couldn't safely get past 3.4Ghz when I had my freezer 7, maxxed out at around 72°c. Now with an Antec Kuhler 620 I barely see over 60°c at 3.6Ghz :)
I found the freezer to be great on a dual core e6600 at 3.7ghz, (my first overclocked cpu). Bad on the q6600, bought a TRUE which done both my 3.8ghz q6600 and q9550. Kept the TRUE on the cpu in sig for a while, before foolishly buying a prolimatech supermega.
Ive just refitted the cooler seems one of the clips was loose,now it idles in the lower 30c,i am still going to get a new cooler as i want to overclock it to tun my 580gtx quicker in bf3
If you dont mind me asking setter, why was it foolish?
is there not much difference in temps? or was there something else?
just curious :)
1c in favour of the TRUE, (though it was lapped) and it would have allowed me to use 12gb of ocz reaper ram. Im now on 12gb of low profile kingston ram, (3x4gb) timings of 9-9-9-27. My reapers were a very high end 1600mhz 7-7-7-24 kit. With the TRUE i would have had room for 12gb of reapers in a 6x2 config. Though thats harder to maintain a cpu overclock as opposed to 3x4gb. And the supermega cost £70.00 without fans. Thinking of watercooling the cpu now though.
thanks for that.
i thought there wouldn't be much difference as the true is still an excellent cooler.
yeah watercooling looks like the next step
