You're meant to use two.
Maybe if you learnt to type on a typewriter about 50 years ago![]()
Indeed, this has come up before.
Outcome: Used to be the way, not for quite a long time now.
IIRC, it was legislated under the Renewable Transport Fuel Obligation that all fuels England must have at least 5% bioethanol (yes even V-Power).
And, i have lost all faith in Thorney Motorsport fuel comparisons, ever since seeing their absolutely LOLworthy figures using Tesco's Momentum99.
[TW]Fox;20866242 said:Of course your car can accelerate smoothly. The N42 is a lovely engine. I don't beleive that it accelerates noticeably less smoothly by filling with a different grade of permissable fuel. You'll have a bit less power and use a tad more fuel but there shouldn't be noticeable characteristics like that, or it wouldn't be a permissable grade!
People driving around in bonkers tuned Jap stuff notice a drop in smoothness and running quality with 95 Ron. You and me driving UK market BMW's do not, or should not. We'll just get a bit less power and use a little more fuel.
[TW]Fox;20866242 said:The N42 is a lovely engine.
[TW]Fox;20866196 said:I'll step in and support mrk here. Just because it's a 318i doesn't mean it's a bobby basic simple engine. He has an N42B20, which has Valvetronic and is designed for 98 RON fuel - it is the recommended grade for his engine. The nominal performance and economy figures for his engine relate to the use of 98 RON fuel.
Am I reading this incorrectly or have you just called a non-6-cyl BMW engine lovely?![]()
I knew the legislation on Bio fuel was about to change, but was not aware all existing fuel already contains 5% bioethanol.
On the Thorney Motorsport figures, I don't see any reason to suspect they are wrong. Their 2006 report shows Tesco 99 is producing marginally more power then Optimax 98, that is in turn producing marginally more power over BP 97. From BP 97 to regular 95 there is a large gap however.
^ I think you're assuming that a difference was noticed over a few days Firestar_3x? This is over a few years!
Thorney is claiming large percentage power gains from small NA engines along with range increases, this is just total BS, you will see a power gain on a higher strung NA or FI car but hardly anything on a shopping trolley.
Thorney are sponsored by Tesco Momentum 99 are they not? If not i'm fairly sure they used to be.
I'd certainly be highly sceptical of a test proclaiming Tesco 99 is the best fuel and you should buy it whenever possible that comes from a man who is paid large sums of money by Tesco.
What testing / figures are you referring to ?
Mileage noted when low fuel warning light emitted
Super Mini
Vauxhall Corsa 1.2 Breeze
Registration Year: 2008
• Miles covered on 95 Octane: 948
• Miles per Gallon achieved on 95 Octane: 36.65
• Miles covered on Momentum 99: 1106
• Miles per Gallon achieved on Momentum 99: 42.75
Ford Focus 1.6 Zetec
• Miles covered on 95 Octane Fuel: 928
• Miles per Gallon achieved on 95 Octane: 29.30
• Miles covered on Momentum 99: 1160
• Miles per Gallon achieved on Momentum 99: 36.62
Specialist Sports
Audi TT 2.0 Turbo
• Miles covered on 95 Octane fuel: 1126
• Miles per Gallon achieved on 95 Octane: 35.55
• Miles covered on Momentum 99: 1320
• Miles per Gallon achieved on Momentum 99: 41.67
On a personal level i myself had two shopping trolleys, a 1.1 saxo and a 1.2 Clio, neither felt any different nor got any more mpg on super, my NA MX-5 felt marginally better on Super but didn't have any more power.
I hear this story a lot about ECU's that will actively tune themselves up and I simply don't believe it. Can any actual ECU mappers/experts confirm it? If this were true then what the heck is the point in remaps.
I'm a bit old school but the way I know it an ECU generally has a standard map and a knock map for if it senses knock, and is able to fine tine the AFR based on lambda readings.
