The system has two fans on either side but what impact would removing the fan on the inside have (the right fan in the picture) or is it needed?
I'm i'm set on fitting a side fan on my Antec 902 case but it won't fit both!
If that's not an option I also had a look at the H100 but is it possible to install the fans for it at bottom front of the case rather than up top?
