Wanting to try water-cooling for my rig. Currently running a Corsair 650D and wanna try cool my CPU ONLY (see sig). NB The graphics is non-reference so not gonna bother with that!
Any suggestions are more than welcome cos i'm completely new to this!!
Budget is around £300 please!
YOUR BASKET
1 x OcUK Tech Lab - 10w DDC Pump & Alphacool Acetal Top Value Combo £62.99
1 x EK Supreme HF CPU Waterblock - Nickel Acetal £55.99
1 x Phobya G-Changer 240 Ver. 1.2 Black £49.99
1 x Lamptron FC5 V2 5.25" Bay Fan Controller - Black £34.99
1 x EK Multioption Reservoir X2 150 Basic £28.98
1 x Masterkleer Hose Pack PVC 16/10mm (3/8ID) UV-Reactive Dark Red 3.3m £10.88
1 x OcUK Tube Cutter Aluminum 3-14mm £8.50
1 x OcUK 30cm Cold Cathode 2-in-1 Kit - UV £5.99
2 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.68 (£9.36)
8 x EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel - [Ideal for EK Kits] £2.75 (£22.00)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
Total : £302.95 (includes shipping : £10.00).
Edit: currently have some vipers kicking about so will use them as fans.
YOUR BASKET
