new FX bundle not working :/
I have tried a CMOS Reset, for the 8 pin connector I use a 4 pin to 8 pin converter. could that be the issue? I've tried using a 750W power supply and it made no difference I'm starting to think that the PSU isn't the issue :(
Also I can not get onto the BIOS as there is no display, I've tried using every display port both on my graphics card and the onboard chipset. Given that I think I may just need to send it back if I cannot even get to the BIOS :(
I would check the 8 pin to 4 pin is in correctly, also check your power and reset switch connectors are in the right way around.
Personally I would think it is all fine, just something silly.
I have a gigabyte board with a 4 pin instead of 8, works fine, just make sure the 4 pin is at the correct end.
I can't flash the bios or do anything because I get no display and i've tried every display port, so theres no way for me to get to the BIOS and do anything there and I have no idea how to flash a bios
I think your best bet is to contact Ocuk via the customer forum and point them to this thread as well.
Ok, so I tried it out again and no success. when it plug it all in it almost seems like the back half of the motherboard where all the usb ports/display ports and so on isn't being powered? no usb device or display will will work. Has this got anything to do with me using a 4 pin to 8 pin converter?
The 4pin/8pin only provides power to the CPU.
Try leaving the converter out and just plug the 4 pin connector in directly.
I am currently experiencing the same problem with this bundle the CPU fan and one of the case fans spin when I turn the computer on but that's all nothings appears on the screen have you found a solution would help allot thanks.
Its a bundle and it says its pre configured so I thought OC would have updated the bios so it's simply plug in and play but if this is the case I'm stuck it's my first build and got no other amd cpu to update it.
Gotta be an old bios and the slow fan will be cool n quiet in work. Mine does it till it notices i actually turned it off then they all fire up to max speed.
remove the reset button wire.. it might be caught in an infinity reset loop
you should actually remove everything and connect the bare minimum
does the motherboard have on board VGA?
