antec kuhler h2o 920 Problem
15 Jan 2007
Hi all i know the antec kuhler h2o 920 is cheating at water cooling but im just wondering if anyone here has this cooler , the problem im having is with the ChillControl software , its saying "Cannot Connect to Chill Control device.
Check USB connection on device and restart the chill control application" every time i run ChillControl , ive tryed changing the USB header and the Antec Light on the pump is on (Green) but just cant get the software working any help would be great.
Regards
Tab
I am sure a few other threads have been posted in generaly hardware with this exact problem, I don't remember if any had a solution though, lemme have a quick search
antec kuhler h2o 920 chill control
hello,i had problems with the chill control software. i have now got it working on my foxconn motherboard. 1st i removed the kuhler's usb cable from the motherboard. 2nd i installed the software from the c.d. (not from antec web site) 3rd i connected the usb cable to the top 5 pins of the motherboard's internal usb connector ( this is important) with the black wire facing left and not facing right as stated in the install guide, hope this helps you.
