**This Week Only 28/12/2011** Great Deals!
22 Aug 2010
This Week Only deals is upon us again, dropping prices of some great products for just one week. Take a look through what we have to offer.
Corsair Gaming Audio Series HS1A Analogue Headset @ £30.66 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Was £31.98 Inc. VAT
Only £30.66 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1 USB Headset @ £60.00 inc VAT
nonl2br
The Gaming Audio Series HS1 USB Gaming Headset is designed for gamers who are serious about audio. Massive 50mm drivers deliver serious gaming punch, without sacrificing the sparkling sound quality you need to enjoy music and movies. Dolby Headphone surround sound gives you a competitive edge, and the noise-cancelling microphone ensures that your teammates and opponents hear you loud and clear. Extra-large earcups and fabric covered memory foam earpads provide a firm fit and excellent noise isolation without binding or pinching, so you’ll keep your cool and keep your head in the game for hours of playtime. The extra-large inline volume and microphone controller is easy to grab when things get fast, and the HS1 is designed and crafted with high-quality materials for years of use.
<br><br>
<object width="640" height="360"><param name="movie" value="
"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<br><br>
- Massive 50mm drivers for high-quality audio reproduction<br>
- Frequency response tuned to deliver serious gaming punch without sacrificing audio quality for music and movies<br>
- Circumaural, closed-back earcups for superior noise isolation<br>
- Replaceable memory foam earpads with fabric covers for a firm fit without binding or pinching<br>
Was £69.98 Inc. VAT
Only £60.00 inc VAT.
ORDER NOW
Krypton Z68 TURBO Intel Core i5/i7 @ 4.60GHz DDR3 Overclocked Bundle @ £370.98 inc VAT
Designed by experts the "Krypton Z68 TURBO Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.60GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 4GB (8GB option available) of Dual Channel DDR3 memory delivers unlimited bandwidth
- Z68 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 & SATA 6GB/s compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i5 2500K or i7 2700K overclocked @ 4.60GHz
- Motherboard: Gigabyte Z68X-UD5 (Socket 1155) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Corsair A50 CPU Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £394.98 Inc. VAT
Only £370.98 inc VAT.
ORDER NOW
Krypton Z68 590i Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle @ £334.36 inc VAT
Designed by experts the "Krypton Z68 590i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 590i" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Gigabyte Z68AP-D3 Intel Z68 (default choice)
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Artic Silver 5 Thermal Compound
Service Package
Was £358.36 Inc. VAT
Only £334.36 inc VAT.
ORDER NOW
Krypton 700a AMD Bulldozer FX-4 Quad Core 4100 3.60GHz @ 4.00GHz Overclocked Bundle @ £240.97 inc VAT
Designed by experts the "Krypton 700a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Krypton 700a Bundle" will accelerate your computer experience into the next level.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Quad Core processing performance
- CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz @ 4.00GHz
- Motherboard: Asus M5A97 PRO AMD 970 (Socket AM3+) DDR3 Motherboard (Upgrade Options available)
- RAM: Kingston HyperX Genesis Grey (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £250.96 Inc. VAT
Only £240.97 inc VAT.
ORDER NOW
Energenie 30 Minute Rundown Timer @ £4.79 inc VAT
This rundown timer will switch off the mains power to your appliance after 30 minutes.
Suitable for:
• hair strighteners
• irons
• curling tongs
• electric blankets
• bedroom lamps
• bedroom TVs etc
Voltage: 220 - 250v ac 50Hz
Maximum load: 13A, 3kW
Manual reset button & indicator lamp
Timeout period: 30 minutes
Was £7.88 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
Philips Longlife R6 (4) Zinc AA (R6L4B/10) @ £0.83 inc VAT
Top low-drain device batteries
For your low-drain products, choose LongLife batteries. Zinc-Chloride technology is perfect for your clocks, radios, calculators and remote controls.
Top Performance
- High-quality Zinc-Chloride technology ensures long life
- The battery remains fresh for use for up to 3 years
Environmentally Responsible
- Philips ZnC batteries contain 0% harmful heavy metals
Was £1.49 Inc. VAT
Only £0.83 inc VAT.
ORDER NOW
Philips eXtreme Life + LR6 AA Alkaline 4 Pack (LR6E4B/10) @ £1.43 inc VAT
Ultra-high energy for digital devices like cameras Excellent for use in digital cameras and high-energy devices. Alkaline batteries are 6 x better than average Zinc Carbon
Alkaline batteries are six times better than average Zinc Carbon batteries.
The battery remains fresh for use for up to 7 years
Every battery suffers from energy loss when not in use. We guarantee that the battery contains at least 80% of its initial energy within the best before date
Philips Alkaline batteries contain 0% Cadmium, Mercury, Lead
These Philips batteries are guaranteed free from harmful heavy metals such as Cadmium, Mercury and Lead.
Was £2.99 Inc. VAT
Only £1.43 inc VAT.
ORDER NOW
Panasonic Alkaline Power Bronze AA 4 pack (PANLR6APB) @ £1.19 inc VAT
AA batteries are the most common size of battery used in the UK today. They power a wide range of devices, from audio players and digital cameras to toys and torches. Alkaline technology provides much better value for money than traditional zinc chloride batteries, especially with more demanding applications such as CD or MP3 players.
• Battery Technology: Alkaline (Single Use)
• Capacity Range: 2300.0mAh - 2850.0mAh
• Current: 5.0000A
• Diameter: 14.5mm
• Height: 50.0mm
• Voltage: 1.50V
• Weight: 24.0g
Was £1.45 Inc. VAT
Only £1.19 inc VAT.
ORDER NOW
Duracell ULTRA Power MN1500 AA 4Pack, 20pb (DURMN1500M3) @ £2.52 inc VAT
Duracell Lithium Battery - Dl123A
The best battery availabler today, designed for use in high performance digital photography, this battery can be put to use in any device to ensure long lasting performance.
BATTERY, ULTRA POWER ALKALINE AA 4PK
Battery IEC Code:LR6
Battery Size Code:AA
Battery Technology:Alkaline
Battery Terminals:Raised Positive and Flat Negative
Battery Voltage:1.5V
External Diameter:14.5mm
External Height:50.5mm
Weight:24g
Output Voltage:1.5V
Was £3.20 Inc. VAT
Only £2.52 inc VAT.
ORDER NOW
Krypton G1 Killer Intel Core i7 960 3.20GHz @ 4.00GHz DDR3 Overclocked Bundle @ £489.99 inc VAT
Designed by experts the "Krypton G1 Killer i7 960 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- Bigfoor Killer E2100 LAN Chip & Creative X-Fi Xtreme Fidelity HD sound
- CPU: Intel Core i7 960 3.20GHz @ 4.00GHz
- Motherboard: Gigabyte G1 Killer Guerilla X58 (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
Service Package
Was £509.99 Inc. VAT
Only £489.99 inc VAT.
ORDER NOW
Workstation PRO Intel Core i7 2600K 3.40GHz @ 4.50GHz Overclocked Bundle @ £540.00 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.50GHz overclock has the processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 16GB of RAM at your disposal you can run even the most demanding of programs
- A solid, optimised 4.50GHz overclock profile provides outstanding processing performance
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
- CPU: Intel Core i7 2600K 3.40GHz @ 4.50GHz Sandybridge CPU
- Motherboard: Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- RAM: Kingston HyperX Genesis Grey16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £568.98 Inc. VAT
Only £540.00 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme HF 360 **2011 Compatible** @ £180.00 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
EK have stepped in and solved this problem. With each EK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike, transform your computer system
All of these kits offer the new EK Standard EN Nickel Plating method which ensures the highest quality nickel plating finish on your water blocks.
Overclockers UK recommends the use of Distilled Water or Watercooling Fluid which is available on this web-store.
To make the kit functional, the user needs 1Litre of Coolant.
The EK-KIT H3O - Supreme HF 360 water cooling kit is an advanced kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme HF 360 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel 775, 1155/1156 and 1366 processors. The CPU block comes with an additional plate to allow use with AMD AM2 and AM3 sockets
Supreme HF block is best and most efficient CPU block (by independent reviews) and offers supreme thermal conductive performance and best high flow.
EK-CoolStream RAD XT (360) radiator will fit in majority of watercooling cases and will succesfully take heat out of your system (please check template of rad prior to installing in case).
EK-DCP 4.0 pump has been also proven for some time now by water cooling community and allows adequate and optimal flow for your kit.
EK-KIT H3O - Supreme HF 360 water cooling kit includes following items:
- EK-Supreme HF - Nickel
- EK-CoolStream RAD XT (340)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 4.0 (Pump)
- EK-Multioption RES X2 - 150 Basic
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (8 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is included).
This kit can also be upgraded with an additional EK-VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Was £184.99 Inc. VAT
Only £180.00 inc VAT.
ORDER NOW
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £91.19 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming.
- Not compatible with Socket LGA1156 Mainboards!!
- Lithography Process: 32 nm
- Cores: 2
- Threads: 4
- Frequency: 3.10 GHz
- Integrated HD 2000 Graphics
- Integrated Graphics Frequency: 850MHz
- Cache: 3 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 65W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
Was £95.99 Inc. VAT
Only £91.19 inc VAT.
ORDER NOW
Intel Core i5-2300 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £143.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Cores: 4
- Threads: 4
- Frequency: 2.80 GHz (Turbo Mode 3.10GHz)
- Integrated HD 2000 (6 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
"Primo 6200a" AMD Bulldozer FX-4 4100 3.60GHz DDR3 Quad Core System @ £397.97 inc VAT
The "Primo 6200a" offers the performance needed for home and business use at a low price. The AMD Bulldozer FX-4 Quad Core 4100 3.60GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience. With HDMI output the "Primo 6200a" is more than capable of being a efficient home entertainment system.
Why You Should Buy This System?
- AMD Bulldozer FX-4 Quad Core 4100 3.60GHz (Socket AM3+) offers multitasking performance.
- Seagate 500GB SATA-II 16MB Cache
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: Coolermaster Elite 335 - Black
- Power Supply: OCZ ZS 550w
- CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz (Socket AM3+)
- Motherboard: AMD 760G Chipset (Socket AM3+) DDR3 Motherboard
- RAM: 4GB or 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Onboard AMD Graphics
- Sound: ALC888B 8-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
Is this System for You?
Designed for the gamer who doesn't have a massive budget, yet expects quality gaming performance. The "Primo 6200a" is the ultimate entry level gaming system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
Was £417.97 Inc. VAT
Only £397.97 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £161.99 inc VAT
- Unlocked Multiplier
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
Was £173.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V6 Watercooled Case - Zalman Z9 **2011 Compatible** @ £181.07 inc VAT
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
Zalman Z9 Plus Tower Case with Fan Controller - Black
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £181.07 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £167.99 inc VAT
- Cores: 4
- Threads: 4
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Only £167.99 inc VAT.
ORDER NOW
"Primo 6000i" Intel Pentium E6700 3.20GHz DDR3 Dual Core System @ £257.98 inc VAT
The "Primo 6000i" features the excellent value Intel Pentium Dual Core E6700 3.20GHz processor, combined with a selection of high performance yet excellent value, handpicked components designed to meet your desire for the home office or work system.
- The Dual Core E6700 is perfect for multi-tasking applications in the home or office environment
- Small and silent making it the ideal home office or work system
- Large capacity 500GB hard giving you plenty of room for storage
- Precision built and cabled by Overclockers UK expert technicians
- Case: OcUK IMP microATX Case
- Power Supply: OcUK Value 500W Power Supply
- CPU: Intel Pentium Dual-Core E6700 "LGA775 Core 2" 3.20GHz
- Motherboard:Intel G41 (Socket 775) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- Graphics Card: Onboard Intel GMA X4500 Graphics
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: 22x DVD+RW SATA Dual Layer Rewriter
Service Package
If you're looking for a reliable and affordable system for work or at home this system is perfect for you.
Was £287.96 Inc. VAT
Only £257.98 inc VAT.
ORDER NOW
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £479.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 K series with unlocked multiplier. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.20GHz (3.80GHz TURBO)
- Multiplier: 32x (Upto 40x available)
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- TDP: 130W
- DOES NOT INCLUDE COOLER
- 3yr Warranty
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Battlefield War Rush Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Limited Edition Quad Core System @ £527.99 inc VAT
Ready the Scud missiles, arm the Tomahawks and prime the Nukes. Fire up the tanks, scramble the jets and roll in the artillery! Control the Battlefield in the palm of your hand with the "Battlefield War Commander", designed and engineered for hardcore gaming. During the heat of the battle the "Battlefield War Commander" will complete the mission no questions asked. Featuring the multiple award winning Gigabyte Z68AP-D3 motherboard for ultimate reliability and overclocking performance. With a choice of DX11 graphics cards to choose from, you can equip yourself with the right weapon for the mission ahead.
- A guaranteed 4.40GHz performance for the price of 3.30GHz
- Choose from a selection of graphics cards to meet your performance needs
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Antec 300 Gaming Case
- Power Supply: OCZ ZS 650w PSU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Xigmatek Red Scorpion CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Command, control and dominate the battlefield with the "Battlefield War Rush" system.
Was £538.99 Inc. VAT
Only £527.99 inc VAT.
ORDER NOW
Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £839.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.30GHz (3.90GHz TURBO)
- Multiplier: 33x (Unlocked Multiplier)
- L3 Cache: 15MB
- TDP: 130W
- 3yr Warranty
Was £851.99 Inc. VAT
Only £839.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooled Case - Corsair 800D **2011 Compatible** @ £388.68 inc VAT
Assembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
Corsair Obsidian 800D (6GB/s) Full Tower Case - Black
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £400.00 Inc. VAT
Only £388.68 inc VAT.
ORDER NOW
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail **£10 CASHBACK** @ £89.99 inc VAT
We call it the new AMD FX 4-Core Processor Black Edition and it's unlocked for your overclocking pleasure. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Quad Core Technology
- 3.60GHz Clock Speed
- 3.80GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 4MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 95W
- Voltage: 0.925v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- £10 AMD Cashback Promotion, see here: http://www.overclockers.co.uk/LP/amd_fx_cashback.php?utm_source=forums&utm_medium=banner
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £29.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Samsung SH-B123L/RSBP 12x BluRay ROM / DVDRW DL & RAM Lightscribe SATA-II Optical Drive - Black (Retail) @ £54.98 inc VAT
True 1080p Full HD technology is more than just entertainment, it's an experience. And it's the pinnacle of picture quality, engulfing and entertaining you with spectacular detail-rich, eye-popping colours and super-sharp, ultra-realistic images that enhance anything and everything on your screen. With our Blu-ray drives, you'll feel like you're seeing your favourite movie for the very first time.
Blu-ray lets you get the most out of your movie watching, so shouldn't you get the most out of Blu-ray? That's where BD Advisor comes in. It lets you unlock the power of interactive high-definition movie viewing with PowerDVD and Blu-ray Discs. BD Advisor helps you test your system and understand Blu-ray basics as well as suggest upgrades. Now you can always enjoy the best Blu-ray has to offer.
Breathe new life into your movie collection with Samsung's up-scale technology. It gives your standard definition DVDs a dramatically different high resolution look. And it gives your movie-viewing experience a cinematic boost. By up-scaling, your favourite DVDs will feature the same brilliant details and rich, robust colours you've come to enjoy from the high definition content on your HDTV.
- SATA Interface
- Includes Cyberlink PowerDVD
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 12x
- BD-R: 8x
- BD-RE: 8x
- BD-RE DL: 6x
- DVD: 16x
- CD: 48x
Was £59.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £59.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-10-9-27 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
OCZ Vertex 3 60GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-60G) @ £88.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br><br>
- Capacity: 60GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 535MB/sec<br>
- Maximum Write: 480MB/sec<br>
- Sustained Write: 455MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- Warranty: 3 Years<br>
<br>
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe>
Was £94.99 Inc. VAT
Only £88.99 inc VAT.
ORDER NOW
LG GH22NS70 24x DVD±RW SATA ReWriter (Black) - OEM @ £14.99 inc VAT
The LG Super-Multi GH22NS40 internal SATA DVD rewriter features a 22x DVD±R write speed and SecureDisc technology that allows you to protect and share data securely. Designed for storage needs that demand consistency, the GH22NS70 can read and write in CD, DVD±R, DVD±RW, and DVD RAM formats.
Write Speed
- DVD-R: 22x
- DVD+R: 22x
- DVD-RW: 6x
- DVD+RW: 8x
- DVD-RAM: 12x
- DVD-R DL: 12x
- DVD+R DL: 12x
- CD-R: 48x
- CD-RW: 32x
Read Speed
- DVD-R: 16x
- DVD-RW: 12x
- DVD-RAM: 12x
- CD-R: 48x
- CD-RW: 40x
- CD-ROM: 48x
Was £18.98 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLE2CP4G3D1869DE1TX0CEU) @ £79.99 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Temperature Probes
- Crucial MOD software compatible
- Elite heat spreader for performance
- Tested together at 1866MHz, Vdimm = 1.60V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1866MHz, 1.60V
- 100% tested at 1866MHz in Intel based motherboards
- Lifetime Warranty
- Bulldozer compatible
Was £99.98 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £64.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 Years
Was £69.98 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (1x8GB) DDR3 PC3-12800C10 1600MHz Single Channel Module (CMZ8GX3M1A1600C10) @ £59.99 inc VAT
The new 8GB Vengeance DDR3 memory operates at 1.5V for compatibility with the new 2nd generation Intel® Core™ processor family and is guaranteed to operate at 1600MHz. Providing 8GB of rigorously-screened DRAM on a single module allows gamers and performance enthusiasts to build systems with 32GB of high-performance memory.
"Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget," said Giovanni Sena, Director of Memory Products at Corsair. "Our kits based on 8GB modules give builders, system integrators, and gaming enthusiasts the power to break the 16GB barrier."
Features
- 8GB Module
- Each module is tested at 1600MHz
- Tested at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £71.98 Inc. VAT
ORDER NOW
OCZ Vertex 3 MAX IOPS 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3MI-25SAT3-120G ) @ £179.99 inc VAT
<br>
- Capacity: 120GB<br>
- Maximum Read: 550MB/sec<br>
- Maximum Write: 500MB/sec<br>
- Sustained Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 75000 IOPS (4KB File)<br>
- 2.5" to 3.5" SSD adaptor included<br>
<br>
Was £199.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OCZ Octane 128GB 2.5" SATA-3 Solid State Hard Drive (OCT1-25SAT3-128G) @ £149.99 inc VAT
nonl2brCombining high-speed data transfer rates with record-breaking access times, OCZ Octane SSDs are designed to provide a superior user experience and improved application performance. Octane leverages the cutting-edge Indilinx Everest platform and is optimized for the complete spectrum of file types and sizes, with proprietary page mapping algorithms mirroring real world conditions across a wide range of applications. The Octane series also includes advanced features unique to Indilinx, including latency reduction technology to enhance system responsiveness and enable instant-on boot-ups. Octane SSDs also deliver the energy efficiency, durability, and reliability that traditional hard drives cannot provide.<br>
<br><br>
- Capacity: 128GB<br>
- Controller: Indilinx Everest<br>
- Maximum Write: 170MB/sec<br>
- Max I/O Per Second (IOPS): 37000 IOPS (4KB File)<br>
<br>
<br>
Was £155.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939/AM2/AM3/775/1155/1156/1366) @ £17.99 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Was £19.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) @ £39.98 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £39.98 inc VAT
- Lifetime Warranty
Was £43.99 Inc. VAT
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP4G3D1608DE1TX0CEU) @ £50.39 inc VAT
- Black PCB
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £53.99 Inc. VAT
Only £50.39 inc VAT.
ORDER NOW
OCZ Synapse Cache 64GB SATA-3 Solid State Hard Drive (SYN-25SAT3-64G) @ £99.98 inc VAT
OCZ Synapse Cache Solid State Drives accelerate workstation and desktop computing applications with an innovative hardware-meets-software design and advanced caching feature-set.
The OCZ Synapse Series integrates the benefits of SSD performance and HDD capacity with Dataplex™ caching software to dynamically manage the use of both SSD and HDD for superior overall storage performance. This combination creates an environment where the most frequently used "hot" data stays on the ultra-fast SSD, while the "cold" data remains on the larger capacity HDD (sold separately). Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user, maximizing productivity for the most demanded programs and applications. Synapse Series integrates seamlessly within any modern PC platform, ensuring optimal compatibility along with performance gains.
High Performance SSD Architecture
- Maximizes performance with SATA 6 Gb/s interface
- Unleashes the full potential of today’s leading platforms
- OS/application bootable with TRIM support
- Easy-to-deploy 2.5” solution for multiple drive bays
Integrated Dataplex™ Caching Software
- Intelligently manages HDD and SSD simultaneously
- “Hot” data managed on Synapse SSD for highest performance, access, and bandwidth
- “Cold” data routed to HDD for highest capacity usage
- No data migration or OS installation required
- Delivers up to 80,000 IOPS
- Bandwidth up to 550 MB/s
- Usable SSD capacity up to 32GB on 64GB Model
- Manages and accelerates full HDD capacity
Was £119.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
OCZ Synapse Cache 128GB SATA-3 Solid State Hard Drive (SYN-25SAT3-128G) @ £178.58 inc VAT
- Usable SSD capacity up to 64GB on 128GB Model
Was £194.99 Inc. VAT
Only £178.58 inc VAT.
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £17.99 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was £23.99 Inc. VAT
ORDER NOW
Arctic Silver 5 Thermal Compound (3.5g) @ £7.98 inc VAT
Introducing Arctic Silver 5 With its unique high-density filling of micronized silver and enhanced thermally conductive ceramic particles, Arctic Silver 5 provides a new level of performance and stability. Now available at Arctic Silver dealers worldwide, Arctic Silver 5 is definitely The New Reference. Arctic Silver 5 is optimized for use between modern high-power CPUs and high performance heatsinks or water-cooling solutions. Arctic Silver 5 uses three unique shapes and sizes of 99.9% pure silver particles to maximize particle-to-particle contact area and thermal transfer.
!!<<img src="green.gif">>!!
Was £8.99 Inc. VAT
Only £7.98 inc VAT.
ORDER NOW
Netgear WNA1100 Wireless-N 150 USB Network Adaptor @ £17.15 inc VAT
The NETGEAR N150 Wireless USB Adapter is a simple and secure way to connect your notebook or desktop computer to Wireless-G or Wireless-N network for surfing the Internet, email, online chat and Facebook. Easy setup with the Smart Wizard® CD gets you up and running fast, while Push ‘N’ Connect gives you a secured connection at the push of a button. Compatibility with Wireless-G networks allows hassle-free connection flexiblity.
- Surf, email, chat - Wireless-N connection for basic Internet applications like surfing the Web, email and Facebook. Backward compatible with Wireless-G
- Notebooks and desktops - Allows wireless Internet freedom for both notebook and desktop computers
- Cradle - Includes convenient cradle for use with desktop PCs
- Easy setup - Smart Wizard® CD with graphical installation guide
- Secured connection - Push 'N' Connect offers a secured wireless Internet connection at the push of a button
- Technical support - Expert technical support team available 24/7
Was £20.99 Inc. VAT
Only £17.15 inc VAT.
ORDER NOW
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Kit (OCZ3P1333LV4GK) @ £14.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Platinum Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3 (1600MHz capable with CAS8/9 timings)
- CL 7-7-7-20
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.50-1.60 Volts**
- 240 Pin DIMM
Was £19.99 Inc. VAT
ORDER NOW
Asus ATI Radeon HD 6950 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Deus Ex PC Game** @ £227.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Speed up heat dissipation with 600% more airflow via exclusive DirectCU with dual fan design
- Expand your visual horizon across six monitors with four native DisplayPort outputs
- Super Alloy Power technology delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- Crank up 50% faster clock speed with exclusive Voltage Tweak
- Core Clock: 810MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 4x DisplayPorts
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 6pin & 1x 8pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 3 Years
- Supplied with FREE Deus Ex
Was £239.99 Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
Features:-
- Core Clock: 840MHz
- Memory Clock: 5120MHz (Effective)
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- Warranty: 2 Years
Was £215.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Intel Gigabit PRO/ 1000 CT PCI Express Desktop Network Adapter (EXPI9301CTBLK) @ £23.78 inc VAT
For PCs with PCI Express (PCIe*) slots, the Intel® Gigabit CT Desktop Adapter offers the newest technology for maximizing system performance and increasing end-user productivity.
Specifically, the Intel Gigabit CT Desktop Adapter uses auto-negotiation to ensure the adapter runs at the highest available network speed (10, 100, or 1000 Mbps), and it maintains full bandwidth capacity with the dedicated bandwidth of a PCI Express input/output (I/O) bus to provide connectivity you can count on.
Based on the low-power Intel® 82574L Gigabit Ethernet Controller, this desktop adapter offers optimal performance in a low-cost, low-power, compact profile. Teaming support and an array of other advanced features enable customers to utilize this adapter as an entry-level server adapter as well.
Features and Benefits
- High performance and reliability; low power
- Delivers increased performance while significantly reducing CPU usage
- Reduces deployment and training costs and enables easy, quick migration to Gigabit Ethernet
- 10/100/1000 Mbps auto-negotiation
- Automatically compatible with Ethernet, Fast Ethernet, and Gigabit Ethernet networks
- Support for most network operating systems
- Allows for low-power consumption, remote wake, and remote booting
- Intel® PROSet Utility for Microsoft* Device Manager
- Advanced cable diagnostics
- Backed by an Intel® limited lifetime warranty
- Efficient packet prioritization
- Minimizes the overhead of interrupts
- Allows load balancing of interrupt handling between different cores/CPUs
Was £24.98 Inc. VAT
Only £23.78 inc VAT.
ORDER NOW
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black @ £99.98 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Was £114.98 Inc. VAT
ORDER NOW
OcUK 85Mbps Homeplug @ £30.61 inc VAT
The OcUK Homeplugs provides convenient powerline access to office/family users by sharing a simple AC power line network. Embedded Homeplug 1.0 Turbo interface enables you to connect one PC ethernet port to another PC's at other end of power line, and not limited by the wall or layer that block RF wireless communication. (*Subject to change without notice.)
- Supports Up To 15 Nodes Per Network
- 56 bit DES Link Encryption With Key Management
- Effect Data Rate : Up To 25Mbps Effective Throughput
- Line Rate: 85Mbps
Was £31.99 Inc. VAT
Only £30.61 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Dirt 3 PC Game** @ £199.99 inc VAT
- Core Clock: 800MHz
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 500W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Dirt 3 Download coupon
Was £209.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
"Titan 8300i Supersaurus" Intel 4.60GHz Quad Core System @ £829.97 inc VAT
The Supersaurus was the largest Herbivore to roam the World in times once gone by, now embrace the power of the legendary dinosaur with the "Titan 8300i Supersaurus". Featuring the Intel Core i5 2500K overclocked to a storming 4.60GHz and can be equipped with the most powerfull graphics cards available, the "Titan 8300i Supersaurus" is literally armed to the teeth. For the extreme among you, you can upgrade to a GTX 580 enabling you to dominate all the opposition. Contained within the sleek Coolermaster CM 690 II Dominator case finished in stunning black.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- DX11 cinematic graphics for the ultimate performance
- SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Coolermaster CM 690 II Dominator Advanced - Black
- CPU: Intel Core i5 2500K 3.30GHz Overclocked to 4.60GHz Sandybridge CPU
- Motherboard: Gigabyte Z68X-UD5 Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: OcUK H2 Flo Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 1TB + OCZ 60GB Sata 6GB/s Solid State Drive
- Graphics Card: Choice of the latest DX11 Graphics Cards
- Sound: Asus Xonar DG PCI Sound Card
- Optical Drive: DVD+/-RW SATA Drive
Service Package
Embrace the power of the "Titan 8300i Supersaurus" with DX11 graphics and Intel Sandybridge technology. Take the advantage with the "Titan 8300i Supersaurus".
Was £853.97 Inc. VAT
Only £829.97 inc VAT.
ORDER NOW
"Ultima 9200i Mosasaur" Intel 4.60GHz Quad Core System @ £1,083.98 inc VAT
The "Ultima 9200i Mosasaur" takes gaming perfomance, next generation computing and reliability to the next level. Build with militart grade components and outfitted with the most advanced graphics cards available, the "Ultima 9200i Mosasaur" is as powerful as the legendary sea monster. With a crazy 4.60GHz overclock you can be sure your system will stand the test of time. Powered by ATI Radeon HD 6950 graphics with the option to crossfire for the real hardcore gamers.
- A guaranteed 4.60GHz performance for the price of 3.40GHz
- DX11 cinematic graphics with Crossfire option available
- Case: Antec 300 Case - Black
- Power Supply: OCZ ZS 750w PSU
- CPU: Intel Core i7 2700K 3.50GHz Sandybridge overclocked to 4.60GHz
- Motherboard: Intel Z68 (Socket 1155) PCI-Express DDR3 Motherboard
- Hard Drive: 1TB HDD
- Graphics Card: ATI Radeon HD 6950 2048MB GDDR5 Graphics Card (Crossfire option available)
- Optical Drive: LG 22x DVD±RW SATA ReWriter
Service Package
Own a true sea monster with the "Ultima 9200i Mosasaur", breath-taking graphics with immense processing speed for the perfect gaming system.
Was £1,119.98 Inc. VAT
Only £1,083.98 inc VAT.
ORDER NOW
TP-Link AV200 200Mbps Mini Powerline Starter Kit (TL-PA211KIT) @ £38.39 inc VAT
nonl2br
<b>What This Product Does</b><br>
TP-LINK's powerline adapter TL-PA211 takes advantage of your home's existing electric wires to transfer data while transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and establish networking infrastructure in a flash. With high-speed data transfer rates of up to 200Mbps, you can enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/nonewwirespa211.jpg"><br><br><br><br>
<b>Super Small Design</b><br>
With the new ultra-compact housing design, TP-LINK TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room.<br><br>
<img src="http://www.tp-link.com/Resources/Up...uct Features/[Features]super small design.jpg"><br><br><br><br>
<b>Up to 200Mbps, 300 Meters</b><br>
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/PA211022.jpg"><br><br><br><br>
<b>Twin Pack Design</b><br>
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters pluged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time.<br><br><br><br>
<b>Reduces Power Consumption Up to 65%</b><br>
The TL-PA211, a new-generation Powerline Adapter, with its logical practical product design and sophisticated Power-Saving Mode, it now consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce the energy consumption by up to 65%.<br><br><br><br>
<b>Pair Button for Easy Network Security</b><br>
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
It's that simple!
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons—and you're done<br><br><br><br>
<img src="http://www.tp-link.com/Resources/Up...ct Features/[Features] PLC 'Pair' Button .jpg"><br><br><br><br>
- HomePlug AV standard compliant, high-speed data transfer rates of up to 200Mbps <br>
- Twin Pack design helps establish a powerline network initially <br>
- Super small design with a new exterior, blends in completely in front of any power outlet <br>
- No new wires, Easy Plug and Play operations, No configuration required <br>
- <b>UK Standard Plug <br></b>
- Patented Power-Saving Mode automatically reduces power consumption by up to 65%<br><br>
Was £39.98 Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
"Ultima 9500i Monolith" Intel 4.20GHz Hex Core System @ £1,787.96 inc VAT
Introducing a new game changer, the "Ultima 9500i Monolith", harnessing the all powerful Intel Core i7 3960X Hex Core CPU. Unlocking the true potential of the CPU with a mental 4.20GHz overclock. The Intel X79 chipset allows for quad channel memory an industry first allowing for unlimited bandwidth and ultra high capacities to be utilised. Choose your favourite DX11 compatible graphics card for the ultimate gaming experience. Consider pairing the "Ultima 9500i Monolith" with an optional SSD upgrade, to provide split second boot times and lightning fast transfer speeds.
- A guaranteed 4.20GHz performance for the price of 3.30GHz
- Quad Channel DDR3 memory for unlimited bandwidth
- Hex core processing for seamless multitasking
- Case: Coolermaster HAF X Case
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 3960X 3.30GHz Sandybridge - E overclocked to 4.20GHz
- Motherboard: Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard
- Cooler: OcUK H2 Flo Extreme CPU Cooler
- RAM: 16GB (4x4GB) DDR3 Quad Channel Kit
- Graphics Card: DX11 GFX Options
- Sound: Onboard 7.1 Audio
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter - Black
Service Package
Weild the power of Intel X79 and next generation Hex core i7 power with the "Ultima 9500i Monolith".
Was £1,823.96 Inc. VAT
Only £1,787.96 inc VAT.
ORDER NOW
Need For Speed The Run - PC @ £26.51 inc VAT
nonl2br
<a href="http://www.origin.com/download"/>
<img src="http://www.overclockers.co.uk/LP/games/originactivation.PNG"></a><br><br>
It’s called The Run.<br>
An illicit, high-stakes race across the country. The only way to get your life back is to be the first from San Francisco to New York. No speed limits. No rules. No allies. <br>
All you have are your driving skills and sheer determination as you battle hundreds of the world’s most notorious drivers on the country’s most dangerous roads. In Need for Speed The Run, you’ll weave through dense urban centers, rocket down icy mountain passes and navigate narrow canyons at breakneck speeds, all the while evading a relentless police force prepared – and willing – to use lethal force to take you down.<br><br>
<center><iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe></center>
Was £26.99 Inc. VAT
Only £26.51 inc VAT.
ORDER NOW
Cooler Master Elite 342 Case - Black @ £22.98 inc VAT
Elite 342 (RC-342) is a mini-tower that accommodates micro-ATX, built with a modern black design body and front panel. This chassis maintains Elite’s pedigree of compact-sized and quality build that would look great in any space. Elite 342 maintains a quiet environment while providing the option of adding 80mm or 90mm rear fans to provide the best ventilation possible for a compact system.
- Front mesh design provides superior ventilation to maintain constant cooling
- Front I/O panel provides easy access for users
- Side panel security lock hole for higher security
- Side ventilation holes for better cooling performance
- Front 120 mm fan provides the best cooling solution
- Removable HDD cage
- Dimensions: 180 x 352 x 440mm
- Motherboard Compatible: Micro ATX
- 2 x 5.25" Drive Bays
- I/O Ports: USB2.0 x2 / Audio x 2
- Front Cooling: 120 x 25mm fan x 1 / 1200 RPM / 17 dBA
- Rear Cooling: 80 / 90 mm fan x 1 (optional)
- Expansion Slots: 4
- 2 Year warranty
Was £24.98 Inc. VAT
Only £22.98 inc VAT.
ORDER NOW
"Ultima 9100i Viper" Intel 4.00GHz Quad Core System @ £949.97 inc VAT
The "Ultima 9100i Viper" assumes all the traits of the legendary serpent and takes them to the next level. Lightning quick, precise and ultimately powerful, the "Ultima 9100i Viper" utilises the very latest hardware to back up these claims, with an Intel Core i7 960 featuring a heart pounding 4.00GHz overclock. With four cores and four threads of pure perfomance, the "Ultima 9100i Viper" smashes apart even the most demanding benchmarks and game titles. Choose your poison, with an array of powerful graphics cards to choose from you can equipe your machine with the right graphics card for the task in hand, be it the subtle GT430 or the mighty GTX 580. Outfitted with 6GB of 1600MHz memory as standard the "Ultima 9100i Viper" blazes through multiple applications with ease. With a massive 1TB hard drive as standard you have more than enough space to store all your films, games and music making the "Ultima 9100i Viper" a competant media player when you aren't owning the competition, add to the fact it now has a Blu-ray reader as standard so you can view the latest HD films in ultra sharp quality.
Why Should You Buy This System?
- A guaranteed 4.00GHz performance for the price of 3.20GHz
- Cinema quality 5.1 surround sound for true gaming immersion
- Choose from a selection of DX11 graphics cards to meet your performance needs
- 8 Hours stressed tested and quality controlled
- Case: Antec 902 Ultimate Gaming Case - Black
- CPU: Intel Core i7 960 3.20GHz Overclocked to 4.00GHz
- Motherboard: Gigabyte G1 Guerilla Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler:Corsair OcUK H2 Flo Extreme CPU Cooler
- RAM: 6GB DDR3 1600MHz Tri-Channel
- Graphics Card: Choice of the latest DX11 graphics cards
- Sound: Asus Xonar DG 5.1 PCI Sound Card w/ Headphone Amp
- Optical Drive: Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
When losing isn't an option and for when just getting the job done isn't enough. The "Ultima 9100i Viper" outperforms all the competition. Upgrade now and start winning today.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £973.97 Inc. VAT
Only £949.97 inc VAT.
ORDER NOW
Corsair Obsidian 650D Gaming Midi Tower - Black @ £138.98 inc VAT
nonl2br
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.<br><br>
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.<br><br>
- Motherboard Support: ATX / mATX<br>
- Expansion Slots: 8<br>
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6<br>
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans<br>
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller<br>
- Dual 200mm fans provide outstanding cooling for even the hottest components<br>
- Easily accessible dust filters make maintenance simple and hassle-free<br>
- Quick-release side panels make it easier than ever to upgrade your hardware<br>
- Integrated fan controller lets you quickly adjust cooling performance and noise levels<br>
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion<br>
- CPU backplate cutout makes it easy to upgrade your CPU cooler<br>
- Brilliant cable routing system provides a way to keep your system neat and tidy<br>
- Adjustable drive cages can be removed and relocated to accommodate large video cards<br>
- Room for long power supplies gives you peace of mind for future upgrades<br>
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)<br>
<br>
<CENTER>
<IMG SRC="http://www.ocia.net/images/goldseal.gif" width="150" height="150"/>
<IMG SRC="http://techgage.com/reviews/award.jpg" width="150" height="150"/>
</CENTER>
Was £145.99 Inc. VAT
Only £138.98 inc VAT.
ORDER NOW
"Verso 5200i" Intel 3.20GHz Dual Core System @ £427.98 inc VAT
The "Verso 5200i" offers a small form factor system perfect for home media and sound creation. Built into a stylish small form factor case and utilising low power consumption components, the "Verso" range of systems cater for every discreet system requirement. The "Verso 5200i" features the Intel Core i3 2100 for improved power saving features and stellar GPU performance. The Intergrated Intel HD 2000 provides excellent graphical power with Nvidia and ATI DX11 options available, combined with 4GB of DDR3 RAM and a large 500GB hard drive, the "Verso 5200i" is a competant system desgined specifically for you home theatre and sound production needs.
- Intel Core i3 3.20GHz (Socket 1155) offers multitasking performance.
- 500GB hard drive gives a solid and reliable storage capacity.
- 4GB of 1600MHz DDR3 RAM allows for snappy and precise processes to be made.
- Case: Antec Fusion Remote HTPC - Black
- Power Supply: OcUK Value 500W PSU
- CPU: Intel Core i3 2100 3.20GHz (Socket 1155)
- Motherboard: Asus P8H61-M (Socket 1155) DDR3 Motherboard
- Graphics Card: Integrated HD 2000 Graphics (Graphics Upgrades available)
- Sound: Asus Xonar DG 7.1 Sound Card w/headphone amp
Service Package
With the stylish Antec Fusion case complete with remote control the "Verso 5200i" certainly looks the part. Perfect for a home theatre or sound production system.
Was £439.98 Inc. VAT
Only £427.98 inc VAT.
ORDER NOW
Xenon AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Bundle - Quad Core @ £159.98 inc VAT
Designed by experts the "Xenon AMD AMD Bulldozer FX-4 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD FX-4 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- Motherboard: Asus M5A78L-M LX AMD 760G (Socket AM3+) DDR3 Motherboard
- RAM: 4GB (2x2GB) DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £171.98 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Black Pearl @ £82.98 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
- Front I/O: 2 x USB3.0 Ports
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £84.98 Inc. VAT
Only £82.98 inc VAT.
ORDER NOW
Battlefield 3: Back To Karkand DLC Code @ £9.72 inc VAT
Get ready to head back to Karkand this December with Battlefield 3: Back to Karkand, the first expansion pack to DICE’s critically acclaimed Battlefield 3. Utilizing the power of Frostbite 2, the Back to Karkand expansion pack remasters four of the greatest Battlefield 2 multiplayer maps with enhanced levels of destruction: Strike at Karkand, Wake Island, Gulf of Oman and Sharqi Peninsula. Back to Karkand continues Battlefield 3’s all-out warfare in what the New York Times has hailed as “the most visually realistic shooter on the market”.
More than a map pack, Back to Karkand marks the return of the classic Conquest Assault mode from Battlefield 2. A slight twist on the beloved Conquest mode, Conquest Assault starts with one team commanding all flags on the map while the opposing team must assault and take the flags over in order to stop their tickets from bleeding down to zero.
Back to Karkand also features three new vehicles (the STOVL fighter jet, desert buggy, and an APC), ten Battlefield 2 weapons you can bring back to the base game, five new dog tags, five new achievements/trophies, and an added layer of persistence where players complete Assignments to earn their rewards.
Since the launch of the game, Battlefield 3’s multiplayer has won over 60 industry awards and captivated fans across the globe with truly innovative team-based multiplayer augmented with powerful and free online social features found via the game’s unique social network, Battlelog.
Features:
Four Reimagined Classic Battlefield 2 Maps
Back to Karkand features four of the most beloved Battlefield 2 maps (Strike at Karkand, Gulf of Oman, Wake Island and Sharqi Peninsula), all fully re-imagined utilizing the power of the Frostbite 2 engine.
Enhanced Destruction
Frostbite 2 creates a whole new level of life-like destruction. The enhanced destruction in this expansion pack lets you turn entire maps into rubble. Chip away at cover, blow holes in walls, and bring down building façades on enemies.
More Weapons And Vehicles
Enhance the signature Battlefield “Rock, Paper, Scissor” gameplay with an arsenal of ten new weapons that you can bring back to the base game and three new vehicles including the STOVL fighter jet, desert buggy, and an APC.
Personalised Dog Tags
Players can express their individuality with five new dog tags including Dolphin Diving and One Man Army. Players can pick the design that showcases their play style best and show it off on the battlefield.
Enhanced Persistence
With the introduction of the all-new Assignments, Back to Karkand features an added layer of persistence on top of what is in the base game. With a vast range of unlockables and upgrades, the combined persistence in Battlefield 3 and Back to Karkand will keep players occupied even longer.
Powerful Social Features In Battlelog
Players will never go into battle alone thanks to the powerful new community features of Battlelog. Players can build their Platoon, communicate with other gamers, and compare their prowess with friends and foes alike. Battlelog is free on all platforms.
Battlefield 3 Multiplayer Features
• Epic scale vehicle and infantry warfare
• Endless variety on vast battlefields
• Refined team play that rewards all play styles
• Destruction with a tactical purpose
• Deep persistent soldier carrier
• Upgradeable vehicles and customizable soldier kits
• Unparalleled weapon customization
• Supported shooting and suppressive fire
• Hardcore mode for a tougher challenge
• Infantry-only game modes for an instant-action fix
• Powerful social features in free Battlelog platform
Was £10.49 Inc. VAT
Only £9.72 inc VAT.
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card **Lowest Price DX11 Graphics Card in UK** @ £23.99 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Core Clock: 650MHz
- Memory: 512MB GDDR3
- Memory Interface: 64-Bit
- Memory Clock: 1066MHz (Effective)
- Processing Cores: 80
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was £25.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Asus GeForce GTX 590 OC 3072MB GDDR5 PCI-Express Graphics Card @ £659.99 inc VAT
The most powerful NVIDIA® graphics card ever created with a dual-GPU model offers unmitigated gaming performance for hardcore enthusiasts
The Asus ENGTX590/3DIS/3GD5, the world’s fastest dual-core NVIDIA® graphics card, aimed directly at PC gaming and entertainment enthusiasts. Featuring 3GB of GDDR5 video memory and a core clocked at 612MHz, the card also comes with ASUS Voltage Tweak overvolting for up to 50%* faster clock speeds, this represents very noticeable enhancements to in-game smoothness and responsiveness. Twin NVIDIA® GF110 cores bring the full potential of Fermi technology to bear on DirectX® 11 and 3D Vision™ Surround gaming in uncompromising detail, quality and can easily handle full HD 3D output simultaneously on three displays. The GTX 590 also offers more than double the power of the GTX 580 thanks to two GPUs running in 2-way SLI™ on one board by default.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 612 MHz
- CUDA Cores: 1024
- Memory Clock: 3420MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 3yr Warranty
IMPORTANT: The supplied Geforce Drivers 267.52 for Geforce GTX 590 will not stop the card from overheating when overclocking. Please use newer versions from the Nvidia website and stay away from 267.52.
Was £699.95 Inc. VAT
Only £659.99 inc VAT.
ORDER NOW
OcUK Value GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card @ £623.99 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- 2yr Warranty
Was £649.99 Inc. VAT
Only £623.99 inc VAT.
ORDER NOW
Creative Inspire T10 2.0 Speaker System (51MF1600AA001) @ £27.98 inc VAT
Creative Inspire T10 speakers give a high-quality performance of all your digital music. Compact and sleek, in glossy black, they combine advanced engineering with good looks to deliver better audio with your PC, notebook or MP3 player. They create a true ‘Hi-Fi' sound stage, using separate tweeters for high-end perfection, precision drivers for accurate mid-tones and BasXPort technology for strong lows without a subwoofer. Separate controls for volume and bass enable you to optimise playback with any kind of music, and you can position Inspire T10s close to PC monitors and TV screens thanks to their magnetic shielding. They include a headphone socket for private listening.
- Elegant 2.0 design with separate 1-inch tweeter and 3-inch mid-range drivers in each satellite for improved highs and mid-tones.
- BasXPort feature in each satellite adds strong bass to complete the sound stage, without requiring a separate subwoofer.
- Separate tone and volume/power controls enable output to be adjusted to suit personal taste.
- Can be connected to MP3 players as well as PCs and notebooks. Headphone port for private listening.
- Magnetic shielding enables speakers to be positioned close to PC monitors, notebooks and other equipment.
Was £32.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £371.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £379.99 Inc. VAT
Only £371.99 inc VAT.
ORDER NOW
Logitech S-120 2.0 Speaker System - OEM (980-000011) @ £7.99 inc VAT
Logitech's S-120 2.0 stereo speaker system with its refresh design features enhanced acoustics delivering a smooth audio performance with low distortion. The S-120 speaker with its redesigned base offers sturdy design, strong audio performance and exceptional value for money. The integrated power and volume control is conveniently located on the satellite at your fingertips with an essential 3.5mm jack close by.
- 2.2W RMS
- 3.5mm Headphone Jack
- Amber LED
Was £9.59 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Asus Rampage IV Extreme/BF3 Intel X79 (Socket 2011) DDR3 Motherboard @ £363.98 inc VAT
Continuing ROG’s legendary overclocking reputation, ASUS is glad to launch the first X79-based ROG motherboard - the RAMPAGE IV EXTREME. It aims to fulfill PC enthusiasts’ needs towards greater performance. The R4E motherboard supports the latest LGA 2011 socket for 2nd Gen Intel® Core i7 and Extreme Edition Processors, and it newly launches some revolutionary overclocking features. With record breaking excellence, it’s time to rock the overclocking world again!
RAMPAGE IV EXTREME is presented with a bunch of hardware upgrades baring the latest utilities designed to unleash the full OC potential and push systems to their limit. The R4E features Extreme Engine Digi+ II offering optimum power efficiency with premium components and intelligent digital design. Built-in finest Japan-made Black Metallic Capacitors offer +20% low temperature endurance and 5X longer lifetime usage.
Most notable is the supplied OC Key which provides an on-screen graphical overlay without the need for extra software on your monitor, allowing you to tweak and monitor your system’s settings in real-time. The Subzero Sense even offers as precise subzero degree measurement as costly thermometers, saving users money while enjoying the same benefits. For PC enthusiasts, there is one thing they don’t wanna miss - the accurate and effortless VGA overvolting way. No need to solder and blindly tweak the tiny resistors, the VGA Hotwire makes VGA overvolting quick and easy via interface such as OC Key, TurboV EVO, and UEFI BIOS. Last but not the least, don’t rush to junk your expensive LGA1366 cooler. With X-Socket, switch out the LGA2011 pad for a 1366 one and you can get more life out of your previous CPU cooler!
With a gorgeous design, great performance and revolutionary features, overclockers will no doubt lust after the RAMPAGE IV EXTREME.
This version is bundled with a full copy of Battlefield 3 and Battlefield 3 Lanyard
ASUS ROG Exclusive Overclocking Features:
ROG OC Key
- OSD TweakIt: Tweak the parameters of your system in real-time with a convenient graphical overlay
- OSD Monitor: Monitor the status of your system in real-time
ROG Extreme OC kit: Super tools for the enthusiast overclocker.
- Subzero Sense: you can read the system’s temperature even in its coldest subzero degrees temperature.
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane switch
- Q_Reset
- EZ Plug
ROG Connect: Plug and Overclock - Tweak it the hardcore way!
- RC Poster
- RC Remote
- RC Diagram
- GPU TweakIt
ROG iDirect: Tune your PC from your iPhone or iPad now!
GPU.DIMM Post: Easily check the status of your graphics cards and memory in the BIOS!
ROG Extreme Engine Digi+ II: equipped with the finest Japan-made 10K Black Metallic capacitors, Precise adjustments create greater efficiency, stability, double lifespan
- 8-phase CPU power
- 3-phase QPI/DRAM power
- 2-phase NB power
- 2-phase Memory power
ProbeIt: Closely monitor your PC’s overclocking
iROG: Connect and Tweak!
Extreme Tweaker: One stop performance tuning shop
USB BIOS Flashback: Easily flash your Bios without the need for even a CPU or Memory.
BIOS Flashback with onboard switch button
Loadline Calibration: Ensure optimized overclock stability.
Intelligent overclocking tools
- ASUS AI Booster Utility
- O.C Profile: Allows you to store multiple Bios images.
Overclocking Protection
- COP EX (Component Overheat Protection - EX): Maximum OC with confidence via burn proof protection to chipsets and GPU!
- Voltiminder LED II: displays the voltage status for CPU, NB, SB, and Memory in a intuitive color-coded fashion.
- ASUS C.P.R.(CPU Parameter Recall)
ASUS Exclusive Features:
CPU Level Up: Upgrade your CPU at no additional cost with ROG's CPU Level Up!
ASUS EPU Engine: Automatically provides the most appropriate power usage to save power and money.
MemOK!: Quickly ensures memory boot compatibility with failsafe settings.
Onboard Switches: Power/Reset/Clr CMOS (at rear)
ASUS Quiet Thermal Solution
- Fan Xpert: Smart thermal control via fan speed detection.
- Q-Fan Plus: automatically detects temperature and adjusts fan speed accordingly to achieve quiet and efficient cooling.
ASUS EZ DIY
- ASUS O.C. Profile: Easily store multiple overclock profiles.
- ASUS CrashFree BIOS 3: Restore corrupted BIOS data from a USB flash disk
- ASUS EZ Flash 2: Easily update your systems bios firmware.
- ASUS MyLogo 2: Update your own windows boot screen.
- ROG BIOS Wallpaper
ASUS Q-Design
- ASUS Q-Connector: Easy access front panel connector
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot: Easy access expansion slots.
- ASUS Q-DIMM: Easy access dimm slots.
Key specification:
Form Factor: Extended E-ATX, 12”x 10.7” (30.5cm x 27.2cm)
CPU: Intel® Socket 2011 for 2nd Generation Intel® Core™ i7 Processor Extreme Edition, Supports Intel® Turbo Boost Technology 2.0
Chipset: Intel® X79 Express Chipset
Memory: 8 x DIMM, max. 64GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz, ECC, Non-ECC, un-buffered Quad channel Memory
Expansion Slots: 4 x PCIe3.0 x16 (red) slots, support x16; x16/x16; x16/x8/x16 and x16/x8/x8/x8, 1 x PCIe3.0 x16 (grey) slot, support x8, 1 x PCIe2.0 x1 slot
Multi-GPU: Supports NVIDIA® 4-Way SLI™ and AMD® CrossFireX™ Technology
Storage 1: Intel® X79 Express Chipset: 2 x SATA 6.0 Gb/s ports (red); 4 x SATA 3.0Gb/s ports (black) Intel® Rapid Storage Technology enterprise supports RAID 0, 1, 5 & 10
Storage 2: ASMedia® SATA controller 2 x External SATA 6.0 Gb/s ports, 2 x SATA 6.0 Gb/s ports (Red)
LAN: Gigabit Intel® Ethernet LAN
Audio: Realtek® ALC898 7.1-Channel High Definition Audio CODEC
USB: ASMedia USB 3.0 controllers: 8 x USB 3.0/2.0 ports (4 at back panel; 4 at midboard)
USB: Intel®X79 Express Chipset: 12 x USB 2.0/1.1 ports (4 ports at midboard; 7 ports at back panel, 1 reserved for ROG Connect)
IEEE 1394: None
BT & WiFi: Bluetooth v2.1+EDR
Bios Features: 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability: WfM2.0, DMI2.0, WOL by PME, WOR by PME, PXE
*This motherboard is ready to support PCIe 3.0 SPEC
Back Panel I/O Ports:
1 x PS/2 keyboard/mouse combo port
1 x Clr CMOS button
1 x ROG Connect On/Off button
1 x LAN (RJ45) port
1 x Bluetooth v2.1+EDR module
4 x USB 3.0/2.0 ports (blue)
8 x USB 2.0/1.1 ports (1 port also for ROG Connect)
7.1-channel Audio+SPDIF I/O
Internal I/O Connectors:
2 x USB 3.0 connectors supports additional 4 USB 3.0 ports
2 x USB 2.0 connectors support additional 4 USB 2.0 ports
4 x SATA 6.0 Gb/s connectors (red)
4 x SATA 3.0 Gb/s connectors (black)
2 x Subzero Sense connectors
1 x OC Key header
1 x OT header (ROG Connect switch)
8 x 4-pin Fan connectors: 2 x CPU / 3 x Chassis / 3 x Optional
8 x ProbeIt Measurement points
3 x Thermal sensor connectors
1 x SPDIF_Out header
1 x 24-pin ATX Power connector
1 x 8-pin ATX 12V Power connectors
1 x 4-pin ATX 12V Power connectors
1 x LN2 Mode header
1 x Slow Mode switch
1 x START (Power On) button
1 x RESET button
2 x EZ Plug connectors (4-pin in white for memory DIMMs; 6-pin in black for PCIe slots)
1 x Go button
1 x BIOS Switch button
1 x Q Reset button
1 x Audio front panel (AAFP)
1 x System panel connector
In The Box:
1 x ROG Connect cable
1 x 3-Way SLI bridge
1 x 4-Way SLI bridge
1 x SLI cable
1 x CrossFire cable
1 x 2-in-1 ASUS Q-Connector Kit
2 x 2-in-1 SATA 3Gb/s signal cables
2 x 2-in-1 SATA 6Gb/s signal cables
1 x I/O shield
1 x 12-in-1 ROG Cable label
1 x ProbeIt cable set
1 x OC Key
1 x OC Key cable
1 x X-Socket pad
1 x Battlefield3 Lanyard
1 x Battlefield3 Key code
Support DVD:
- Drivers and Applications
Kaspersky Anti-Virus
ASUS TurboV EVO Utility
ASUS PC Probe II
ASUS Update
ASUS AI Suite II
ASUS AI Charger+
Daemon Tool Pro Standard
ASUS WebStorage
Was £399.98 Inc. VAT
Only £363.98 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 *** Hydro Copper 2 3072MB GDDR5 PCI-Express Graphics Card @ £659.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 772MHz (Fermi GF110)
- EVGA Waterblock
- Memory: 3072MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 10 Years (Requires registration within 30 days with EVGA)
Was £679.99 Inc. VAT
ORDER NOW
Thermaltake VK60001W2Z Element S Case - Black @ £44.99 inc VAT
Silent, cool and stylish are the hallmarks of a classic case. The Element S hits the mark on every level; featuring large quiet fans to maintain maximum airflow, anti-vibration and noise material is applied to the side panels, stealth black interior shows off the quality both inside and outside and when combined with excellent build quality makes the Element S the best Thermaltake case ever.
- Anti-vibration & noise reduction materal on side panel
- Stealth Black Interior
- Direction-free HDD cage
- Excellent thermal performance with optimal air flow
- Folding edge design to strengthen structure and prevent cutting
- Front (intake): 120 x 120 x 25 mm TurboFan, 1300 rpm, 17 dBA : 120 x 120 x 25 mm (optional)
- Rear (exhaust): 140 x 140 x 25 mm TurboFan, 1000 rpm, 16 dBA
- Top(exhaust): 230 x 230 x 20 mm red LED fan, 800 rpm, 15 dBA
- VGA (exhaust): Two 60 x 60 mm fan (optional)
- Drive bays: 3 x 5.25" and 7 x 3.5"
- Dimensions: 540 (H) mm x 230(W) x 505(L) mm
Was £59.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard @ £227.99 inc VAT
At the very top end of motherboard performance, the P9X79 series from ASUS brings you complete power, enhanced with unmatched flexibility and boundless tuning possibilities. These new boards launch with the world’s first digital power controls for both the CPU and memory, thanks to exclusive ASUS New DIGI+ Power Control Technology. They further put power right in your hand via UEFI BIOS, the most detailed and accessible BIOS ever, allowing you to tune your system to its full performance potential. While user-friendly from the ground-up, the P9X79 Series ships with the latest features, including exclusive ASUS SSD caching for one-click performance boosting through the benefits of solid state drive technology. You also get USB BIOS Flashback for the easiest ever BIOS modification – all it takes is a USB stick and one button press! Sign up for total power and performance insight with the new ASUS P9X79 Series.
The world’s first Dual Intelligent Processors from ASUS pioneered twin on board chips – TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Third generation Dual Intelligent Processors with New DIGI+ Power Control include two digital voltage regulator modules (VRMs). An all-new digital controller now allows ultra-precise DRAM tuning. EPU provides system energy saving and real time power management. TPU delivers a second micro-processor to free CPU resources as well as easy O.C. and an instant performance boost through an on-board switch or the easy O.C. tool, TurboV EVO.
ASUS Unique Selling Points:
ASUS Dual Intelligent Processors 3 with New DIGI+ Power Control:
CPU Power: Industry leading Digital 8+2 Phase Power Design and CPU Power Utility
DRAM Power: Industry leading Digital 2+2 Phase Power Design and DRAM Power Utility
ASUS EPU and EPU switch: Automatically provides the most appropriate power usage to save power and money.
ASUS TPU with Auto Tuning and TurboV with Switch: Providing simple steps to easy overclocking.
ASUS BT GO!: Bluetooth on-board for easy Folder Sync, BT Transfer, Shot & Send, BT to Net, Music Player, Personal Manager, BT Turbo Remote
ASUS EFI BIOS(EZ Mode):The most flexible and easy to use Bios.
ASUS SSD Caching: 3x Faster storage performance with one click
USB 3.0 Boost: Make USB 3.0 speeds faster than ever (UASP Mode)
Front Panel USB 3.0 Support: Support for cases with front USB 3.0
AI Suite II: One stop access to all Asus features.
Ai Charger: Faster USB charging speed.
Fanless Design: Silent Heat-sink solution
Fan Xpert+: Smart thermal control via fan speed detection.
ASUS Q-Code: Allows easy fault diagnosis
ASUS Q-Shield: Extra Secure I/O Shield
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED):
USB BIOS Flashback: Flash your Bios in 1 easy step, no CPU or RAM required.
Percision Tweaker 2: Advanced overclocking tools.
Multi-language BIOS: easily change Bios to your language.
Asus Overclocking Features:
Precision Tweaker 2:
- vCore: Adjustable CPU voltage at 0.005V increment
- vTTCPU: Adjustable I/O voltage at 0.00625V increment
- vCCSA: 255-step system agent voltage control
- vDRAM Bus: 160-step Memory voltage control
- vPCH: 96-step Chipset voltage control
- vCPU_PLL: 48-step CPU & PCH PLL voltage control
SFS (Stepless Frequency Selection)
- BCLK/PEG frequency tuning from 80MHz up to 300MHz at 0.1MHz increment
Overclocking Protection:
Key specification:
Form Factor: ATX, 12”x 9.6” (30.5cm x 24.4cm)
Memory: 8 x DIMM, Max. 64GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz, ECC, Non-ECC, un-buffered Quad channel Memory
Expansion Slots: 3 x PCIe 3.0 x16 slots (dual@x16/x16; triple@x16/x8/x8), 1 x PCIe 3.0 x16 slot (PCIe x16_3@x8 speed), 2 x PCIe 2.0 x1 slots
Multi-GPU: Supports NVIDIA® 3-Way SLI™ and AMD® Quad-GPU CrossFireX™ Technology
Storage 1: Intel® X79 Express Chipset: 2 x SATA 6Gb/s ports with RAID 0,1,5 and 10 support, 4 x SATA 3Gb/s ports with RAID 0,1,5 and 10 support
Storage 2: Marvell® 9128 SATA controller: 2 x SATA 6Gb/s ports
Storage 3: ASMedia® 1061 SATA controller: 2 x Power eSATA 6Gb/s ports
LAN: Intel® 82579V Gigabit LAN controller
Audio: Realtek® ALC 898 8-channel High Definition Audio CODEC Supports 192kHz/ 24bit BD Lossless Sound
USB: 3 x ASMedia USB 3.0 controllers: 2 x USB 3.0/2.0 ports at mid-board for front panel support: 4 x USB 3.0/2.0 ports at back panel with 1 additional VIA SuperSpeed USB
USB: Intel®X79 Express Chipset: 12 x USB 2.0/1.1 ports (6 ports at mid-board, 6 ports at back panel)
IEEE 1394: None
BT & WiFi: Bluetooth V2.1+EDR with ASUS BT GO! Utility, NO WIFI
Bios Features: 64 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.6, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability: WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
1 x Bluetooth module
1 x Optical S/PDIF Output port
1 x LAN (RJ-45) port
2 x Power eSATA 6G ports
6 x USB 2.0/1.1 ports
1 x USB BIOS Flashback button
8-channel Audio I/O
1 x USB 3.0/2.0 connector support additional 2 USB ports (19-pin)
3 x USB 2.0/1/1 connectors support additional 6 USB ports
4 x SATA 6Gb/s connectors
4 x SATA 3Gb/s connectors
1 x CPU Fan connector (4-pin)
1 x CPU Opt Fan connectors (4-pin)
4 x Chassis Fan connectors (4-pin)
1 x Front panel audio connector(AAFP)
1 x S/PDIF Out header
1 x Clear CMOS button
1 x 24-pin EATX Power connector
1 x 8-pin EATX 12V Power connector
1 x System Panel (Q-Connector)
1 x MemOK! Button
1 x EPU switch
1 x TPU switch
1 x PWR button
1 x Reset button
In The Box:
4 x Serial ATA 6Gb/s cables
2 x Serial ATA 3Gb/s cables
1 x ASUS 3-Way SLI bridge connector
1 x ASUS SLI bridge connector
2 in 1 Q-connector
I/O Shield
User's manual
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
ORDER NOW
Logitech X-140 2.0 Speaker System (970264-0120) @ £15.98 inc VAT
Logitech’s X-140 stereo speakers have the quality and innovation you expect from Logitech. The innovative two-driver acoustic design provides enhanced bass in a slim profile. Dynamic, real-time bass equalization maximises bass reponse while minimising distortion. Connect your portable MP3 or CD player to the convenient 3.5mm auxiliary input. Customize your audio balance with easy-to-reach tone and volume controls. Connect your favorite headphones to the integrated headphone jack and enjoy your music privately.
- Innovative two-driver design delivers more bass while maintaining a slim profile
- Dynamic, real-time bass equalization maximises bass response while minimising distortion
- Connect your portable MP3 or CD player to the convenient 3.5 mm auxiliary input
- Customise your audio balance with easy-to-reach tone and volume controls
- Connect headphones to enjoy your music privately
- Distinctive design and impressive sound from the makers of the award-winning “Z” speakers
Was £17.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Gigabyte X58 G1 Guerilla Intel X58 (Socket 1366) DDR3 Motherboard - Gaming Series @ £163.99 inc VAT
Was £199.99 Inc. VAT
Only £163.99 inc VAT.
ORDER NOW
MicroLab SOLO6C 100W Bookshelf Stereo Speakers - Dark Wood Finish @ £69.98 inc VAT
High fidelity Active bookshelf stereo speakers with beautiful wood finish. Designed with Microlab special care and audio expertise, this series is ideal for most living room setup. Listen to crystal clear and dynamic music with this stereo pair and witness the quality in its audio drivers. High resolution and near perfect performances, simply stunning audio production quality. Powerful sharp cone dispersion design on woofer for perfect audio experience. Comes with infrared remote control capability for wireless remote control. Special heritage range for Microlab's 2.0 system that employs high quality design techniques and speaker technology - perfect sound quality and near linear response Incorporates IGBT OCL circuit for pure tones and dynamic acoustic production. Wireless remote control for attenuation.
High quality sound and full range spectrum, ideal for all music lovers and audiophiles.
- Beautiful wooden cabinets with excellence sound quality, powerful 2-way speaker system
- Crystal clear dynamic highs, balanced mid range and deep bass
- Reference monitor quality, driven by high quality drivers
- Each cabinet with 1" tweeter for high notes and woofer for mid to low depths and bass. Includes wireless remote control
- Ideal for high fidelity music, movies and digital media playbacks
- Amplifier: Output power: 100 Watt RMS
- Power distribution: 50 Watt x 2
- Harmonic distortion: < 0.3% 1W 1kHz
- Frequency response: 55Hz - 20kHz
- Signal/Noise ratio: > 85dB
- Separation: > 55dB
- Input sensitivity: 440mV
- Nominal impedance: 4 ohm
- Speakers: Tweeter driver type: 1"
- Tweeter rated power: 10 Watt 6 ohm
- Bass driver type: 6.5"
- Bass rated power: 30 Watt
- Frequency range: 55Hz - 20kHz
- Output: Terminals
- Input: 2RCA
- Aux input: 2RCA
- Power: Power supply: AC 220 - 240V, 50Hz
- Package Contents: SOLO6C speakers x 2
- Interconnect cable
- 2RCA - 3.5mm stereo 1.8m cable
- Full function remote control
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Antec VP450P 450W Continuous Power Supply @ £36.98 inc VAT
The VP450P is crafted for quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkly lights or glittery paint jobs - a 120 mm fan for effective and quiet cooling, dual +12V rails for amazingly stable power, heavy-duty protection circuitry and active Power Factor Correction (PFC) that saves money on corporate power bills. And it comes with all the assurance of Antec's AQ2 Antec Quality 2 year limited warranty. All the features, none of the waste: for builders that are strictly business, the VP450P is strictly power.
Features:
- 450 watts of Continuous Power
- ATX12V version 2.3 compliant
- Dual +12V rails ensure greater system stability
- EuP 2010 compliant assuring efficiency and low standby power consumption
- Active Power Factor Correction with PF: 0.99 for higher efficiency and less power grid pollution
- 120 mm fan delivers quiet, reliable cooling
- Black exterior complements any system
- Heavy-duty protection circuitry prevents damage from a variety of dangers:
- Over Current Protection (OCP)
- Over Voltage Protection (OVP)
- Short Circuit Protection (SCP)
- Over Power Protection (OPP)
- Safety: CB,TÜV,C-TICK,CCC,CE , Gost-R
- MTBF: 100,000 hours
- AQ2 Antec Quality 2 year limited warranty on parts and labor
Was £39.98 Inc. VAT
Only £36.98 inc VAT.
ORDER NOW
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply @ £69.98 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS® Bronze certification, TP-650 is the ideal solution for elite system builders and quality-minded enthusiasts alike.
- NVIDIA™ SLI™ - ready certified
- 80PLUS® Bronze Certified saves energy and lowers your electric bill
- DC to DC voltage regulator modules for greater system stability
- 120mm PWM fan runs up to 50% quieter than standard fans
- Advanced Hybrid Cable Management improves airflow and reduces clutter
- Double layer PCB optimizes cooling efficiency and allows for heavy duty components
- Universal Input and Active Power Factor Correction
- Supports dual GPUs and dual/quad core CPUs
- 4 +12V output circuits provide stable power
- ATX12V v2.3 and EPS12V v2.91
- 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
- 2 x 6 pin and 2 x 8 (6+2) pin PCI-E graphics card connectors for TP-650, TP-750 and - Industrial grade protection
- Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
Was £72.98 Inc. VAT
ORDER NOW
Creative Inspire A520 5.1 Speaker System (51MF4110AA008) @ £38.99 inc VAT
Give your games, music and movies a much-needed boost with the Creative A520 5.1 speaker system. Given their contemporary style and ease of use, they are the perfect choice for immersive multi-channel surround sound, bringing to you all the benefits of Creative’s leadership in audio technology. The five satellites make use of the two-inch drivers for crisp dialogue and impressive effects, while the large subwoofer with a flared port tube and separate bass control provides you with the freedom to adjust your bass level and deliver the extra impact and oomph for all of your entertainment needs. The system also includes a wired remote for easy-to-reach and convenient control.
- Speaker Power: 5Watts RMS per channel (5 channels)
- Subwoofer: 12Watts RMS
- Frequency Response: 40Hz ~ 20kHz
- Signal-to-Noise Ratio (SNR): 75dB
- Product Weight: 3.5 kg
- Dimensions (HxWxD): Speaker (144x80x104)mm, Subwoofer (235x192x192) mm
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Cooler Master Silent Pro Gold 1200W Power Supply @ £152.99 inc VAT
The Silent Pro Gold series features an entirely new design with several innovative and patented technologies. Cooler Master has created HTT™ (Heat Transfer Technology), a unique “L-shaped” heat-sink designed to vastly improve the airflow inside the power supply, resulting in lower operating temperatures. Another unique feature to the Silent Pro Gold series is the Hybrid Transformer™ which mounts the transformer directly to the heatsink. This makes for a more compact transformer and improves the power efficiency at the same time.
Yet another feature that helps improve the power efficiency is Hyper Path™ which is a “hyper link” between the transformer and the various power conversion components. The “hyper link” results in almost a loss-less transfer of energy which has never been done before. Combine all three of these features and you got one of the most quiet and power efficient power supplies in its category. The entire range offers a power efficiency that exceeds 90 percent at 220V, starting from a load of about 50 percent (model dependant), with some models never dropping below 90 percent. During normal use (up to about 50 percent load), neither model exceeds 21 dBA of fan noise thanks to the low RPM fan design combined with the new heat-sink design.
- 90% efficiency typically
- 80 Plus Gold Certified
- Quad SLI or CrossFireX
- A unique "L-shaped" heatsink to remove heat from the PSU
- Hybrid Transformer: Unique design that combines heat-sink with transformer
- Flat modularised cables provide easy cable management leads to better airflow
- Compliance with the latest ATX V2.3 standard
- Operation with intelligent fan speed control
- High reliability (MTBF > 100,000 hours)
- Double Layer EMI filter retains noise and to avoid affect to users
- Integrating active PFC with PWN combo controller while increase efficiency
- Multiple protection design (OVP/UVP/OPP/OTP/SCP/OCP)
- Japanese made capacitors
- Single +12V rail up to 98A
- Five year warranty
Was £154.99 Inc. VAT
Only £152.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £151.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br>
<br>
- Capacity: 120GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 550MB/sec<br>
- Maximum Write: 500MB/sec<br>
- Sustained Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- 2.5" to 3.5" SSD adaptor included<br>
- Warranty: 3 Years<br>
<br>
Was £172.99 Inc. VAT
Only £151.99 inc VAT.
ORDER NOW
Cooler Master GX 450W '80 Plus' Power Supply @ £27.98 inc VAT
Cooler Master is electrifying gamers PCs with the new GX-series, specifically targeted at systems in the upper-mid to high-end range, yet reasonably priced, providing users with unsurpassed cost per performance. The Cooler Master GX Series of power supplies feature a single highly robust 12 V rail, proficiently delivering power to the most demanding components including the processor, drives, cooling fans and even the most intense dual graphic cards, such as the SLI or CrossFireX. Now including a double-layer EMI Filter, an intelligent 120 mm controllable fan and an active PFC/PWM combo controller for increased efficiency, the GX Series will keep the power in your hands.
- Compliance with the latest Intel standard ATX 12V V 2.31
- Single 12V rail for most demanding SLI configurations
- High efficiency design that meets 80plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- High reliability
- Huge bulk capacitor for hold time up >17ms at full loading
- Integrated Active PFC with PWM
- Efficient transformer
Was £29.99 Inc. VAT
ORDER NOW
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard @ £81.38 inc VAT
Was £84.98 Inc. VAT
Only £81.38 inc VAT.
ORDER NOW
Lepa B-Series 850W '80 Plus Bronze' Modular Power Supply - with FREE LEPA Hard Drive Enclosure @ £94.98 inc VAT
Designed by Sirtec these mid to high end PSU's are ideal for any pro-gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® Bronze certified with peak 88% efficiency.
- 13.5cm fan with intelligent RPM control guarantees cool performance and silent operation.
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V.
- 8P PCI-E connector supplied supporting extreme graphic cards.
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits.
- CPU 12V connector rail with > 18A output to support next generation >6 cores processor structure.
- Extending CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis.
- SATA power connector with 3.3V rail to support new generation SSD.
- Modular design for easy cable management and flexible system upgrade support.
- 3 year warranty
- FREE LEPA hard drive enclosure with any LEPA PSU!
Was £99.98 Inc. VAT
Only £94.98 inc VAT.
ORDER NOW
OCZ ZS Series 650W '80 Plus Bronze' Power Supply @ £56.99 inc VAT
The OCZ ZS Series PSU is the superlative solution for driving today's value oriented gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Enthusiast-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the OCZ ZS Series PSU was engi-neered to be the quietest PSU available in its class, elimi-nating distracting noises from your PC. Highly efficient, featuring up to 86.72% efficiency at typical load and up to 83% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
This PSU is backed with OCZ’s 3-year “power swap” warranty, the OCZ ZS Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- OCZ PowerWhisper™ Technology
- Internal 135mm ball-bearing fan
- Can power SLI™ and CrossFire™ GPU configurations
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- 86% Efficiency (Typical Load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program.
Was £64.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Asus P67 Sabertooth Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION ** @ £138.98 inc VAT
Was £144.98 Inc. VAT
ORDER NOW
OCZ ZX Series 850W '80 Plus Gold' Modular Power Supply @ £117.06 inc VAT
The ZX Series is the unsurpassed solution for driving today's Enthusiast and gaming systems. It has the ability to easily power both NVIDIA® SLI™ and ATI CrossFire™ modes, supporting even the most power hungry GPUs with multiple GPU configurations. Industrial-grade yet designed with enthusiasts, gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and the most compact form factor of its class.
Kept ultra-cool with a load-controlled ultra quiet 140mm fan, the ZX Series was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 92% efficiency at typical load and up to 89% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. The OCZ ZX Series provides universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
Backed with OCZ’s 5-year “power swap” warranty, the OCZ ZX Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 850W Continuous power
- Ultra quiet 140mm ball-bearing fan
- +12VDC @ 70A Single Rail Design
- SLI™ and CrossFire™ support
- Fully modular cable management system
- 150 x 175 x 86mm (W x L x H)
- 80-Plus Gold Certified
- 92% Efficiency (Typical Load)
- Active PFC
- 5 year warranty backed by OCZ's exclusive
- PowerSwap Warranty replacement program.
- 20+4 pin ATX
- Dual 4+4 pin CPU
- 4 x PCIe 6+2 pin
- 12 x SATA
- 9 x Molex
- 1 x Floppy
Was £124.99 Inc. VAT
Only £117.06 inc VAT.
ORDER NOW
Asus P8H61-M Intel H61 Chipset (Socket 1155) DDR3 Motherboard **B3 REVISION** @ £53.99 inc VAT
The P8H61-M delivers users fantastic graphics performance in an Intel® LGA1155 package with memory and PCI Express controllers integrated to support 2-channel DDR3 memory and 16x PCI Express 2.0 lanes. DDR3 supports data transfer rates of 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia and Internet applications. The Intel® H61(B3) Express Chipset is the latest single-chipset design to support the new 1155 socket Intel® Core™ i7 / i5 / i3 2nd generation processors. It provides improved performance by utilising serial point-to-point links, allowing increased bandwidth and stability.
The P8H61-M features a multitude of exclusive ASUS features. ASUS EPU (Energy Processing Unit) provides total system power management by intelligently moderating power usage in real time saving power and money. ASUS AI Suite II, this all-in-one software offers diverse and ease to use functions, with no need to switch back and forth between different utilities. AI Suite II allows users to supervise overclocking, energy management, fan speed control, voltage and sensor readings.
Anti-Surge protection detects over voltage conditions to prevent voltage surges from spreading in real time. Fan Xpert intelligently allows users to adjust the CPU chassis fan speeds according to differing temperature and climate conditions, offering flexible control of fan speeds to achieve a quiet and cool environment.
ASUS TurboV provides the adrenaline rush of real time OC without exiting or rebooting the OS. The ASUS OC profiles in TurboV provide the best OC settings in different scenarios. The P8H61-M uses all high-quality conductive polymer capacitors on-board for durability, improved lifespan and enhanced thermal capacity. GPU Boost overclocks the integrated GPU in real time for the best graphics performance with a user friendly UI that facilitates flexible frequency and voltage adjustments.
The BIOS C.P.R, (CPU Parameter Recall), feature automatically restores the CPU default settings when the stystem hangs due to an overclocking failure. C.P.R. eliminates the need to open the system chassis and clear the RTC data. Users can simply shut down and reboot the system. The on-board 8-channel HD audio (High Definition Audio) CODEC enables high-quality 192KHz/24-bit audio output. Jack Detect feature, automatically identifies peripherals and notifies users of any inappropriate connection.
- GPU Boost: Upgrade your graphics performance by up to 48%
- 100% Solid Capacitors: Provides the motherboard with improved durability, improved lifespan and enhanced thermal capacity.
- Protect 3.0: Protects the Planet, your Hardware and You.
- MemOK!: Quickly ensures memory boot compatibility with failsafe settings.
- Anti-Surge Protection: This special design prevents expensive devices and the motherboard from damage caused by power surges.
- EPU: Automatically provides the most appropriate power usage to save power and money.
- Anti-EMI: Reduces Electro Magnetic Interference by up to 50%
- TurboV: Providing simple steps to easy overclocking.
- ASUS EFI BIOS(EZ Mode):The most flexible and easy to use Bios.
- AI Suite II: One stop access to all Asus features.
- CrashFree BIOS 3: Restore corrupted BIOS data from a USB flash disk
- My logo 2: Easily customize your start up screen.
- EZ Flash 2: Easily update your systems bios firmware.
Key specification
- Form Factor: mATX 9.6 in x 8.0 in (24.4 cm x 20.3 cm)
- Socket: LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
- Chipset: Intel® H61 Express
- Graphics interface: 1 x PCI Express 2.0 x16 slot
- Memory: 2x DIMM, max. 16GB, DDR3 1333/1066 MHz, non-ECC, un-buffered memory
- Audio: ALC887 8-channel High Definition Audio CODEC
- LAN: Realtek® 8111E Gigabit LAN
- Storage: 4 x SATA 3.0 Gb/s ports
- USB: 10 x USB 2.0/1.1 ports (6 ports at mid-board, 4 ports at the back panel)
- 1 x PS/2 COMBO port (Keyboard & Mouse)
- 1 x S/PDIF Out port(Optical)
- 1 x HDMI port
- 1 x DVI port
- 1 x D-Sub port
- 1 x LAN (RJ45) port
- 6 x USB 2.0/1.1 ports
- 3 x Audio jacks
- 2 x USB connectors support additional 4 USB ports
- 4 x SATA 3.0Gb/s connectors
- 1 x CPU Fan connector
- 1 x Chassis Fan connector
- 1 x LPT connector
- 1 x Front panel audio connector
- 1 x COM port
- 1 x S/PDIF Out header
- 1 x 24-pin ATX Power connector
- 1 x 4-pin ATX 12V Power connector
- 1 x System Panel connector
In The Box
- 2 x Serial ATA 3.0Gb/s cables
- 1 x I/O shield
- 1 x Support DVD
- User's manual
- Drivers
- ASUS Utilities
- ASUS Update
- Anti-virus software (OEM version)
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Western Digital Caviar Green 3TB SATA 6Gb/s 64MB Cache - OEM (WD30EZRX) @ £179.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 3TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £229.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £109.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Was £119.99 Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Logitech G700 Wireless Gaming Mouse (910-001759) @ £66.98 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Was £69.98 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Epson Stylus Office BX305F All In One Inkjet Printer - Colour @ £48.00 inc VAT
Epson Stylus Office BX305F Multifunction Inkjet Printer raises the bar with efficiency, intelligent controls, a sleek design and energy efficiency in one cool black package.
The Epson Stylus Office BX305F Multifunction Inkjet Printer can print, scan, copy and fax. Speed-dial fax buttons, an auto document feeder (ADF), fast operation speeds and a compact design are other attractive features of this printer. The Epson DURABrite Ultra inks give you great vibrant colour and laser-like document prints, while the Presto! PageManager software makes it easier to edit, share and work with scanned documents.
With this all-in-one Epson Stylus Office BX305F Multifunction Inkjet Printer, you'll get everything you need to make office work easier or home printing more fun!
Was £49.98 Inc. VAT
Only £48.00 inc VAT.
ORDER NOW
Hitachi Deskstar 5K3000 3TB SATA 6Gb/s 64MB Cache 5900RPM - OEM @ £164.99 inc VAT
The Deskstar™ 5K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 5900 RPM performance in a standard 3.5-inch form factor. The 5K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 5900RPM
- Bootable with Sandybridge P67/H67/Z68 Motherboards
- Warranty: 2 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Was £209.99 Inc. VAT
Only £164.99 inc VAT.
ORDER NOW
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) @ £99.98 inc VAT
The F3 operates at 7200RPM with offerings of up to 1TB data storage capacity by using two 500GB per platter disks. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 1TB
- Cache: 32MB
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £99.98 inc VAT.
ORDER NOW
Cooler Master Xornet 2000DPI Gaming Mouse @ £17.99 inc VAT
The Xornet gaming mouse is lightweight, ergonomically designed and forged with a reassuringly solid design. It is built for professional FPS gamers that prefer a claw grip. Engineered to execute precise in-game tactics, Xornet comes loaded with a high-performance 2000 DPI sensor that includes on-the-fly adjustment, an ultra-step wheel encoder – providing extremely accurate scrolling, and Japanese-made Omron micro-switches that are meant to endure up to five million clicks. Presented in a eye-catching crimson stealth black high-gloss finish, Xornet lends its truly breathtaking appeal as the focal point of a gamer’s setup.
- Precision Anti-Drift Control Sensor
- Xornet utilizes the latest high performance optical engine ensuring extreme stability and reliability.
- Omron Micro Switches (5 million clicks)
- DPI On the Fly
- Rubberized Anti-Slip Design
- Material: Rubber Grip / ABS Plastic
- Dimensions: (L) 107 X (W) 75 X (H) 35 mm / (L) 4.2 X (W) 4 X (H) 1.3 inch
- Net Weight: 142 g / 0.313 lb
- Sensor: 2000 DPI Storm Tactical Optical Sensor
- Maximum Tracking Speed: 160 IPS
- Maximum Acceleration: 23 g
- Polling Time: 1.0 ms
- Speed Measurement: 6700 FPS
- Onboard Memory: 8 Kb
- Form Factor: Right Hand Ergonomic
- Button Assignment: 5 mouse buttons+ 2 fix function buttons
Was £19.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £119.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="728" height="90"><param name="movie" value="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf" /><param name="quality" value="high" vmode=transparent /><embed src="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Only £119.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) @ £71.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £184.99 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="
"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Only £184.99 inc VAT.
ORDER NOW
Logitech K300 Compact Keyboard (920-001488) @ £15.98 inc VAT
Control your media and smarten up your space with the Logitech® Compact Keyboard K300. Its stylish, backlit media controls provide an elegant and easy way to access to your music, videos and e-mail, with keys that blend cleanly into the streamlined styling. The K300 features a space-saving design with full-size keys that frees up space on your desk – and makes the keyboard easy to store or take with you. A full-size, integrated number pad makes data entry fast and effortless. The ultra-flat profile helps you type comfortably with keys move quietly and feel great, shifting your wrists toward a more neutral position. Plus, setup is easy: the K300 works right out of the box, with no software to install.
- Backlit media controls
- Full-size number pad
- Space-saving design
- Ultra-flat profile
- Easy setup
Was £17.99 Inc. VAT
ORDER NOW
Microsoft SideWinder X6 Gaming Keyboard - Retail (AGB-00006) @ £37.98 inc VAT
Flexible design, choose right side or left side configuration. Switch between standard key pad and macro pad in gaming mode. Keyboard keys are red, and key pad and Macro keys are amber in Game mode. Lighting dial adjusts the brightness of the keyboard and key pad. Up to 30 programmable keys that can allow up to 90 programmable options with an assigned gaming profile. Use Cruise Control to continue an action without having to hold down the key or keys assigned to the action. You can use Cruise Control with up to four keys at a time. When a game or application profile is assigned using the software, the keyboard detects the game or application you are running and applies your custom profile to the application.
- Switchable Key Pad
- Two Colour Adjustable Backlight dial
- Macro Keys
- Mode Switching
- Cruise Control system control keys
- In-Game Macro Recording
- Auto Profile Switching
- WASD gaming keys lighting
- Media Keys
- 3 Year Warranty
Was £39.98 Inc. VAT
Only £37.98 inc VAT.
ORDER NOW
Gainward GeForce GTX 570 Golden Sample 1280MB GDDR5 PCI-Express Graphics Card @ £251.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI, 1x Displayport
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £263.99 Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card @ £281.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/PowerEdition.jpg" alt="Power Edition" /><br>
<br>
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle. <br>
<br>
<Font size="4"><b>Key Features</b><br></font>
<b>Propeller Blade on Twin Frozr III</b><br>
- Twin Frozr III Thermal Design with 18C cooler & 7.7 dB quieter.<br>
- Propeller Blade technology for 20% more airflow.<br>
- Dual 8cm fans with dual 8mm SuperPipes for best heat dissipation.<br>
<br>
<b>Power Edition Architecture</b><br>
- Triple overvoltage function support by MSI Afterburner to raise overclock capability.<br>
- 6+1 Phase PWM Design provides better overclock stability.<br>
<br>
<b>MSI Exclusive P/S Switch Function</b><br>
- Dual fan speed profiles–Performance/Silent.<br>
- Performance Mode provides best cooling demand; Silent Mode balances noise and GPU Temperature.<br>
<br>
<b>Military Class II Components</b><br>
- SFC (Super Ferrite Choke) has higher current for better overclocking ability.<br>
- Hi-C CAP for GPU provides more precise voltage.<br>
- All Solid CAPs have longer lifespan.<br>
<br>
<Font size="4"><b>Specification</b><br></font>
- Core Clock: 770MHz <br>
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)<br>
- Memory: 1280MB GDDR5<br>
- Memory Clock: 4000MHz (Effective)<br>
- Memory Interface: 320-Bit<br>
- Processing Cores: 480<br>
- Shader Clock: 1540MHz<br>
- Bus Type: PCI-Express 2.0<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready (Upto 3-Way SLI Supported)<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 4.0 Support<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
- 3D Vision Enabled<br>
- NVIDIA Surround Enabled<br>
- Warranty: 3 years<br>
Was £299.99 Inc. VAT
Only £281.99 inc VAT.
ORDER NOW
TT eSports Challenger Gamers Keyboard @ £26.99 inc VAT
This keyboard offers a unique cooling solution for your hands when the heat of the battle takes its toll on you. Allowing you to game under many different conditons you will be razor sharp at all times.
- Interface: USB
- Operational systems: WindowsR 7/Vista/XP
- Number of Macro keys: 6
- Number of Multimedia keys: 7
- 2.0 USB port: 1
- Switch lifecycle: 10 Millions
- Cable length: 2m
- Body dimension (LxWxH): 480x 205.5x 25mm
- Fan Speed: 6,000 RPM(±15%)
- Max. airflow:2.7CFM
- Noise level:21.7dB
- Rate voltage: DC 5.0V
- Life expectancy: 50,000 HRS
- Body dimension (LxWxH): 30x30x10mm
Was £36.98 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3 PC Game** @ £185.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
- Supplied with BattleField 3 Full PC Game download voucher!
Was £191.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
OcUK GeForce GT 520 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £32.39 inc VAT
Make your video experience better. Whether you stream 1080p online videos from sites like YouTube® or Hulu® or prefer immersive Blu-Ray 3D™ movies, the power of the GeForce® GT 520 GPU makes your video playback fast and smooth.
In addition to rendering your high-res photos instantly, the GeForce® GT 520 also speeds up the editing of your videos. And when you share your photos and videos online, you'll enjoy a richer web experience with GPU accelerated browsers like Google Chrome™ and Internet Explorer® 9.
Go beyond photos and videos and take your gaming to the next level. With the GeForce® GT 520, your favourite DirectX11 games come to life with lifelike characters and incredibly detailed terrain and game environments.
Features:-
- Core clock: 810Mhz
- Memory: 1024MB GDDR3
- Memory Clock: 1800MHz (Effective)
- Shader Clock: 1620MHz
- 1x HDMI
- 1x Analogue
- 1x Dual-Link DVI
- DirectX Version: 11
- OpenGL Version: 4
- SLI Support
- Warranty: 2 Years
Was £35.99 Inc. VAT
Only £32.39 inc VAT.
ORDER NOW
EVGA GeForce GTX 460 Superclocked 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 763MHz
- Memory Clock: 3800MHz (Effective)
- Processing Cores: 336
- Shader Clock: 1526MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Only £113.99 inc VAT.
ORDER NOW
Gigabyte GeForce GT 430 OC "Dual Fan" 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £50.39 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 730MHz
- Memory Interface: 128-Bit
- Processing Cores: 96
- Shader Clock: 1460MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Warranty: 2 Years
Was £53.99 Inc. VAT
Only £50.39 inc VAT.
ORDER NOW
OcUK GeForce GT 430 1024MB GDDR3 PCI-Express Graphics Card @ £40.79 inc VAT
Specification:-
- Core Clock: 700MHz
- Memory Clock: 1600MHz (Effective)
- Shader Clock: 1400MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £49.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) @ £359.99 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Was £369.98 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Razer Goliathus Omega Fragged Control Gaming Mouse Pad @ £11.99 inc VAT
Lab-engineered by Razer's scientists and field-validated by the biggest names in professional gaming today, the Razer Goliathus Control Edition greatly enhances the precision and tactile response of gaming-grade mice without introducing excessive, fatigue-inducing drag and premature surface degradation. The tournament-tuned textured weave enables mice—regardless of sensor type—to register the minutest of movements, thus yielding unprecedented targeting and tracking accuracy while maintaining a perfectly controllable yet consistent glide.
- Heavily Textured Weave For Maximum Mouse Control
- Pixel-Precise Targeting And Tracking
- Optimized For All Mouse Sensitivity Settings And Sensor Types
- Dimensions: 270mm x 215mm x 4mm
- Rubber Base For A Secure Grip On Smooth Surfaces
- 2 Year Warranty
Was £13.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Asus VE228H 22" Widescreen LED Multimedia Monitor - Black @ £119.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Was £131.99 Inc. VAT
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £134.39 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Was £139.99 Inc. VAT
Only £134.39 inc VAT.
ORDER NOW
IIyama Prolite E2274HDS 22" Widescreen LED Business Monitor - Black @ £131.99 inc VAT
The LED-backlit ProLite E2274HDS 22” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
LED-BACKLIT
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
SPEAKERS
HDMI
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
Specification
Screen Size - 22"
Response Time - 2ms
Height Adustable - No
Rotatable Screen - No
Built in Speakers - Yes
VGA Input - Yes
DVI-D Input - Yes
HDMI Input - Yes
LED Panel - Yes
Was £143.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
OcUK E2250SWDA 22" Widescreen LED Monitor - Black @ £86.39 inc VAT
The OcUK 22" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 20,000,000:1 contrast ratio and digital connectivity there is no other LED that can match the combination of value and performance.
Features
- Screen Size: 21.6" Widescreen
- Contrast Ratio: 20,000,000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Inputs: 1x Analogue & 1x DVI-D
- Multimedia Speakers
Was £89.99 Inc. VAT
Only £86.39 inc VAT.
ORDER NOW
OcUK Air Duster Compressed Air (400ml) @ £6.48 inc VAT
AIR DUSTER MT2607 is a compressed air in a container with a capacity of 400 ml. Includes an intensive blower to remove dust and dirt from the most inaccessible places. Perfect for all the surfaces, especially those where you cannot use wet or chemical cleaning. Ideal for computers, office equipment, printers, accessories, photographic, precision mechanics, electronics, etc.
Was £6.98 Inc. VAT
Only £6.48 inc VAT.
ORDER NOW
Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black @ £143.99 inc VAT
ProLite X2377HDS - A 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all around panel type. This IPS panel offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2377HDS is full HD, has a 5 000,000:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user clear and vivid images. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The Prolite X2377HDS has two integrated stereo speakers and is VESA mount compatible. It will provide both excellent performance for photographic, design and web-design and is also an excellent choice for Universities, Corporate and Financial Markets, as well as the rapidly expanding demand for Multi Monitor applications.
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- 3yr Warranty
Was £167.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Was £149.99 Inc. VAT
ORDER NOW
OcUK 2436VWA 24" Widescreen LCD Monitor - Black @ £119.99 inc VAT
The OcUK 24" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 60,000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
Features
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 60,000:1
- Colors: 16.7 M
- HDCP compatible: Yes
- USB: 1up / 1down
- VESA 100x100mm
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £185.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- VESA Compliant
Was £194.99 Inc. VAT
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £575.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Response Time : 2ms (Gray to Gray)
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was £599.99 Inc. VAT
Only £575.99 inc VAT.
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey @ £623.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 80000:1
- Brightness: 350cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was £649.99 Inc. VAT
Only £623.99 inc VAT.
ORDER NOW
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £935.99 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was £959.99 Inc. VAT
Only £935.99 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £245.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
Was £269.99 Inc. VAT
Only £245.99 inc VAT.
ORDER NOW
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Glass Monitor - Black @ £479.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
These monitors use a glass coating on the front which results in much sharper images quality, more vibrant colours and an overall better viewing experience. The downfalls of glass fronted panel is the monitor weighs a lot more and the manufacturing process can lead to dust particles been trapped between the panel and the glass which can sometimes be spotted when up very close to the screen and with certain solid coloured backgrounds.
Features:-
- Glass front panel for improved image quality
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 1000:1 / 1,000,000:1 (Dynamic)
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x Dual Link DVI-D
- 2.5mm Audio out
- Kensignton Security Port
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
- Only available to customers in the United Kingdom
- 3yr RTB Warranty (UK customer only)
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
OcUK Value 8GB USB Drive Black @ £6.49 inc VAT
OcUK Value PinStripe 8GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
- Push and pull sliding feature
- Enhanced for Windows ReadyBoost
- Includes EasyLock Password Protection Software Trial
- Compatible with Windows 2000, XP, Vista & Windows 7
- Compatible with Mac OS 9 or higher & Linux 2.4.0 or higher
With ports in almost every computer and popping up in cars, DVD and Multimedia players, TV's, Photo Frames and many more, USB drives are now being considered an essential accessory.
Was £8.99 Inc. VAT
Only £6.49 inc VAT.
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Monitor - Black @ £599.99 inc VAT
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
Features:-
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
Only £599.99 inc VAT.
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Glass Monitor - Black @ £599.99 inc VAT
Features:-
- 1 x DisplayPort
- 2 x HDMI
- 1 x RGB VGA
- 1 x L/R RCA Audio
- SPDIF Optical Out
Was £699.95 Inc. VAT
ORDER NOW
OcUK Value 16GB USB Drive Black @ £12.98 inc VAT
OcUK Value PinStripe 16GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £16.99 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Patriot 8GB Supersonic Xpress USB 3.0 Flash Drive PSF8GXPUSB @ £13.99 inc VAT
The Supersonic Xpress USB 3.0 flash drive brings the speed and performance of USB 3.0 at an affordable price. Featuring a stylish cap-less design that hides the USB 3.0 connector when not in use, the Supersonic Xpress works like a pen to reveal the USB connector. Transfer data in a flash with speeds up to 60MB/s read and 25MB/s write when connected to a USB 3.0 port. No USB 3.0 port? The Supersonic Xpress is backwards compatible to USB 2.0/1.1 and comes with a 2-year limited warranty.
Was £15.98 Inc. VAT
Only £13.99 inc VAT.
ORDER NOW
MSI GT780DX-603UK 17.3" WLED TFT Intel I5-2430M, 8GB DDR3, 750GB HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,127.99 inc VAT
nonl2brWhat do gamers desire most? MSI knows best! In GT780DX, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT780DX provides you the best gaming experience!
<br><br>
GT780DX has a 17-inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT780DX is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
<br><br>
In order to present the best sound effects, the GT780DX speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
<br><br>
The exterior design of the GT780DX combines the classic, succinct appearance of a limousine with the aerodynamic contour of a spacecraft creating a low-key composure but powerful image. The black casing of the GT780DX is specially covered with brushed aluminum, coupled with the silver msi logo, it makes the GT780DX a symbol of the coexistence of textural quality and ultimate performance.<br>
<br>
To avoid accidentally touching the touch pad while gaming, the GT780DX is equipped with a control switch for the touch pad on the side of the keyboard<br>
<br>
<br>
Features:-<br>
- Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)<br>
- The Latest 2nd Generation Intel® Core™ i5 Processor<br>
- High-end NVIDIA® GeForce GTX 570M discrete graphics card (with GDDR5 1.5GB VRAM) provides great detail images quality<br>
- Best gaming keyboard designed by SteelSeries<br>
- Exclusive TDE technology to speed up the performance<br>
- Sound by Dynaudio for extreme audio performance<br>
- Exclusive DDR3 SO-DIMM x 4 slot design easily upgrades memory capacity<br>
- THX TruStudio Pro provides excellent surround sound<br>
- Latest & fastest data transfer technology USB 3.0<br>
<br>
Specification:-<br>
- CPU Intel® Core™ i5-2430M Processor (3M Cache, 2.40 GHz) (3.0GHz Turbo Mode) <br>
- OS Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)<br>
- Chipset Intel HM67 <br>
- 8GB Memory DDR3 1333 MHz ,Slot : 4 <br>
- LCD Size 17.3" Full HD (1920x1080) LED backlight <br>
- Graphics nVidia GeForce GTX 570M <br>
- Graphics VRAM 1.5GB GDDR5 <br>
- HDD: 750GB (7200rpm) HDD<br>
- Optical Drive: DVD Super Multi <br>
- Audio 2.1 channels speakers, Sound by Dynaudio, THX TruStudio Pro, 7.1ch output <br>
- Webcam HD type (30fps@720p) <br>
- Card Reader SD(XC/HC)/MMC/MS(PRO)/xD <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth Bluetooth v3.0 + HS <br>
- D-Sub (VGA) 1 <br>
- HDMI 1 (v1.4) <br>
- USB 2.0 port 3 <br>
- USB 3.0 port 2 <br>
- eSATA 1 <br>
- eSATA/USB Combo N/A <br>
- Mic-in/Headphone-out 1/1 <br>
- Line-in 1(line in)/1(line out) <br>
- Express Card N/A <br>
- Modem port N/A <br>
- Keyboard 102-key keyboard by SteelSeries <br>
- Sensor N/A <br>
- AC Adapter 180W <br>
- Battery 9 cells <br>
- Power Management Turbo Battery+ <br>
- Dimension 428 x 288 x 55mm(WxDxH) <br>
- Weight (KG) 3.9 <br>
- UK Model does *NOT* have backlit keyboard<br>
- UK Model comes with FREE Dirt 3 PC Game<br>
- Steelseries UK Keyboard layout (No Backlight)<br>
- Supplied with Dirt 3, New gaming mouse, 17" Gaming bag<br>
- 2yr Warranty<br>
<br>
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe>
Was £1,199.99 Inc. VAT
Only £1,127.99 inc VAT.
ORDER NOW
Patriot 16GB Supersonic Xpress USB 3.0 Flash Drive PSF16GXPUSB @ £19.99 inc VAT
Was £22.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Patriot 32GB Supersonic Xpress USB 3.0 Flash Drive PSF32GXPUSB @ £34.99 inc VAT
Was £43.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Kingston 4GB SDHC Class 4 Flash Card (SD4/4GB) @ £3.98 inc VAT
Kingston Technology's Secure Digital High-Capacity (SDHC) memory cards are fully compliant with the new Secure Digital Association 2.00 specification. They are a new performance class of SD memory cards designed to meet the storage demands of high-quality digital still and video cameras and other high-resolution image recording devices.
- Capacity: 4GB
- Data Transfer Speed Class: 4
- Lifetime Warranty
Was £4.99 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Kingston 16GB SHDC Class 10 Flash Card (SD10G2/16GB) @ £14.99 inc VAT
Kingston Technology’s SDHC Class 10 cards are designed for amateur and professional photographers who need faster speeds to keep pace with their evolving equipment. It allows users to easily capture sequential shots that used to be a challenge due to the speed limitations of memory cards. With a guaranteed minimum sustained transfer rate of 10 MB/s, the SDHC Ultimate Class 10 is ideal for anyone who uses their digital equipment for serious photography or HD video.
- Capacity: 16GB
- Data Transfer Speed Class: 10
- Lifetime Warranty
Was £18.98 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin @ £12.98 inc VAT
The GentleTyphoon achieves high airflow volume and low noise with the newly designed impeller, enabling silent cooling of the latest devices which run very hot.
The GentleTyphoon has a different type of tone. The fan propeller is designed to reduce the disturbing frequency fan noise to human ears. The newly designed motor and motor support mechanism of the GentleTyphoon uses a double vibration reduction structure. The new support mechanism uses coil dampers to greatly reduce vibration.
- Manufacturered in Japan
- Only 21.0 dB(A) at 1850 RPM
- Weight 200 g
- Dimensions 119 x 119 x 25 mm
- Air volume at full speed (12V), CFM ±10% 58.0
- Noise level at full speed (12V), dB(A) 28.0
- Fan speed at full speed (12V), RPM ±10% 1850
- Bearing Type Double Ball Bearing
- MTBF 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories 4-pin Molex Adapter, 4x Screws
Was £14.99 Inc. VAT
ORDER NOW
Asus Xonar D2 7.1 PCI Sound Card @ £86.99 inc VAT
ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- Unprecedented SNR Up to 118db reaching the limit of PC sound clarity
- High-definition audio processing at 192KHz/24Bit for all Input and outputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theatre System
Was £89.99 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Asus Xonar D2X 7.1 PCI-E Sound Card @ £84.98 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Was £88.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £18.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
**Supplied with Driver disk, Manual, Low profile PCI bracket and Xonar DG card - All thats missing is the box!**
Was £20.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium 7.1 Sound Card - OEM (30SB088200000) @ £59.99 inc VAT
Creative's Sound Blaster X-Fi Titanium is the essential audio upgrade for maximum PC gaming and entertainment. Whether you use Windows XP or Vista, its PCI Express design guarantees total compatibility, plus hardware-accelerated EAX 5.0 and OpenAL support for maximum gaming performance. With X-Fi CMSS-3D for accurate and immersive 3D positional audio even over headphones, this card will give you the edge over the competition! THX certified, it also features onboard Optical I/O and real-time Dolby Digital encoding for single cable connectivity to your surround sound decoder. The supplied PowerDVD software works with X-Fi technology to let you play Dolby and DTS movies in incredible surround sound over headphones or speakers.
- Sound Blaster X-Fi PCI Express chipset is designed for the latest PCs.
- Hardware-accelerated EAX 5.0 and OpenAL gaming for ultra-realistic cinematic in-game audio. Creative ALchemy software restores EAX surround sound to Windows XP games under Windows Vista.
- Delivers accurate and immersive X-Fi CMSS-3D surround sound over headphones for on-line or late-night gaming sessions.
- On-board optical I/O with Dolby Digital real-time encoding, for single cable connection to your surround sound decoder.
- UAA (Universal Audio Architecture) design ensures maximum compatibility under Windows Vista.
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
I find these ever so depressing. Now that I've "completed" my pc over the years, the only thing I could possibly put in it left is an SSD and they are always on offer but always too expensive to justify still.
I think I need to build a new pc so I can take up your ram/cpu deals etc instead haha.
Nice ones! Need to be categorised though. :p
I've always said that.
I am tempted to try eyefinity with 3 OcUK (AOC) E2250SWDA 22" Widescreen LED Monitors... It would mean a new GPU :(
should I??
Should I????
Better off with a nice 27" or 30".
Actuall I already run a Samsung T260 monitor using 1920x1200. It is an amazing monitor but the lure of 3 screens is getting too much and lets face it, it's one thing paying over £400 (I bought th T260 when it was released) for one screen but I just can't afford to pay £300+ per screen. It's over a £1000 vs less than £300.
Ok quality blah blah, resolution blah blah... but basically 3 22inch LED screens at 1920x1080 each for less than £300 is bloody good for the money vs 27inch and 30inch.
When I said a nice 27", I meant a hazro or something with a greater resolution. Much better having a high res single screen in my opinion. A 1920x1200 27" is a waste of money in my opinion.
Anyone know if the Gigabyte Z68AP-D3 that is on TWO is Rev 2.0 with PCI Express Gen 3 support?
Thanks,
I have been looking at that very same board a lot lately as well mate with an I5 upgrade in mind its dropped a few quid almost bought this yesterday. I believe its revision 1.0 though but i may be wrong
SSD included?
The description for the "Titan 8300i Supersaurus" includes "Hard Drive: 1TB + OCZ 60GB Sata 6GB/s Solid State Drive" yet in the SSD Upgrade bit it shows as "No Upgrade £0.00", and to get an OCZ Agility 3 60Gb SSD costs £66.66 more.
So is there one included or not as per the description, or do you have to pay more for it?
