which to buy Antec Kúhler H2O 920 or Corsair Hydro H60
30 Sep 2009
im new to water cooling just want to buy a cheap kit to get use to the idea,i own a
AMD Bulldozer FX-8 Eight Core 8120 Black Edition 3.10Ghz
and a asus bord im after to overclock a bit which one one theese cheap kits are the better dont really want spend more then 80 quid,so which is better Antec Kúhler H2O 920 or Corsair Hydro H60 or the cheaper antec with only one fan ive got loads off 120 fans knocking about the place is the cheaper
Antec Kúhler H2O 620 the same kit as H2O 920 but with only one fan if so by just adden a 120 fan would it save me about 30 quid?:) thanks for any help
I'd go with the Antec. Between the 620 and 920 - not sure if matching the fans in terms of performance is important or not though. I've only ever done push/pull with the same fans.
i prob got 2 decent matchin 120 fans,if thats alls the difference is between the 2 kits it seams silly to spend the extra 30 quid on the better kit reading the reveiws most peps change the fans on theese cheap cooling kits any way just want to know if there any difference say in the rad or the block that sits on cpu ya will have to excuse me lol dont know that much about water cooling as in the pics of them they look the same just ones got an extra fan
The 920 has a thicker radiator then the 620, meaning it dissipates heat better due to the increased surface area in the radiator. The 920 would perform quite a bit better then both the H60 and the 620.
XSPC Rasa 450 RS120 Water Cooling Kit i could prob go a bit extra cash and afford this but looks like a big jigsaw lol only useing standerd cooler at moment ive got prob with useing air cooler ive tryed a Akasa AK-CC4008HP01 which i have on another machine and it wont fit in me case but it is a big air cooler thats why i want to try water coolin.
