FREE 50GB Online Storage (before 31st Dec)
28 Nov 2003
Manchester, UK
Just in case anyone has missed this, see here:
http://forum.xda-developers.com/showthread.php?t=1414990
Post 6 tells you exactly what you need to do, if you are a Note owner. It also works for other android devices. You just need to be rooted.
Instructions:
http://forum.xda-developers.com/showpost.php?p=20761050&postcount=6
Tried and tested:
I used ES File Explorer, in the settings you need to enable write by ticking mount file system. It then lets you edit.
BTW, the max upload size of a file is 100mb so it is useful for mp3s, photos, documents etc but not really for videos.
If this is similar to the HP Touchpad Box.net offer its worth going to the main website and checking youve actually got 50Gb as some didnt in the end (think default was 10Gb), even with a similar confirmation box as the OP...
ps3ud0 :cool:
Just checked on their main website and it says the same as it did on the box app I downloaded yesterday - used 0 of 50GB :)
I doubt I'll ever use it really, but it's damn nice to know it's there if I DO need it for anything :D
By the way, I used the app in Locke's link - worked first time - thanks for the heads-up guys!!
What is the file upload limit?
Normally free Box Personal accounts have a 25MB upload limit, but we’re bumping it up to 100MB for this promotion in order to help you get the most out of your 50GB of storage. With a 100MB upload limit, you’ll be able to easily save pictures, presentations, audio files and documents to the cloud.
Still handy but only 100mb files is a bit poo
I have split my cwm backups into 100mb chunks and stuck that on there just in case I'm stuck and need to retire my phone remotely and my sd card has gone pop.
