Hi
Just thought I'd post a problem here and see if anyone else has encountered anything similar / has any thoughts....
For the past 2 or 3 days I've notced the lights in my house occassionally flickering (going dim then back to normal) quickly. This is very temperamental, they will stabilise and then will flicker again every so often.
This flickering occurs both on my upstairs lights and downstairs lights which are on separate circuits from my fuse box. When they flicker I've checked the voltage available on my plug sockets (both upstairs and downstairs which are again separate circuits from my fuse box) and have notced the voltage dropping up to around 3 volts each time whenever the flickers occur.
I have also noticed that when the flickers occur, a street light directly outside of my house is flickering in sequence with my lights. I have also noticed the flickering during the daytime though when the street light is not turned on.
I've spoke to neighbours, they have not seen any problems and other street lights on the street do not seem to be affected.
So what do you think?
1) Is the street light supply the cause of the problem?
2) Is the problem caused by something at the utility supplier's end?
3) Could it be something in my house that is causing the problem? If so, surely this shouldn't affect the street light right?
Thanks
Thanks
